I am running Caddy alongside IIS to run an AMP application management server that uses port 8080
After some troubleshooting, I’ve found that the “World Wide Web Publishing Service” is what IIS uses, when I turn this service off, I can get Caddy to work, it creates a certificate and I can resolve my DNS using HTTPS.
Unfortunately, I need IIS running to run my websites.
Any ideas on how I can get them both running at the same time? Or is this impossible?
C:\caddy>c:\caddy\caddy.exe reverse-proxy --from amp.watchbound.com --to localhost:8080
2024/11/01 00:12:13.948 ←[33mWARN←[0m admin admin endpoint disabled
2024/11/01 00:12:13.948 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc00040d280"}
2024/11/01 00:12:13.948 ←[34mINFO←[0m http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "proxy", "https_port": 443}
2024/11/01 00:12:13.964 ←[34mINFO←[0m http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "proxy"}
2024/11/01 00:12:13.964 ←[34mINFO←[0m tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc00040d280"}
Error: loading new config: http app module: start: listening on :443: listen tcp :443: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
Setup caddy with NSSM to run as a service. Created a batch script with the below input to run. Worked fine for my purposes *when IIS is not running.
Windows Server 2022 Datacenter
pause
