I run Caddy web server + FrankenPHP application in a docker container.
It runs behind a reverse proxy and has no direct access to the internet. This was OK.
Then my application needed to call external APIs , so I added HTTP_PROXY and HTTPS_PROXY env var defined to the http proxy URL of my organisation, in order to have access to internet.
But then Caddy respond an “Unknown Host” error
indeed a.domain.fr is not defined in DNS ,i try to add it in the docker extra_hosts param, but it has no effect, Caddy seems to really make a DNS resolution like dig would do.
I don’t understand why this DNS resolution is not done or don’t make error , when HTTP_PROXY is not set
Unknown Host
Description: Unable to locate the server named “a.domain.fr” — the server does not have a DNS entry. Perhaps there is a misspelling in the server name, or the server no longer exists. Double-check the name and try again.
docker image based on dunglas/frankenphp:latest-alpine
{$CADDY_GLOBAL_OPTIONS}
frankenphp {
{$FRANKENPHP_CONFIG}
# https://caddyserver.com/docs/caddyfile/directives#sorting-algorithm
order mercure after encode
order vulcain after reverse_proxy
order php_server before file_server
{$CADDY_EXTRA_CONFIG}
{$SERVER_NAME:localhost} {
# Redact the authorization query parameter that can be set by Mercure
format filter {
wrap console
fields {
uri query {
replace authorization REDACTED
root * /app/public
encode zstd gzip
mercure {
# Transport to use (default to Bolt)
transport_url {$MERCURE_TRANSPORT_URL:bolt:///data/mercure.db}
# Publisher JWT key
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
# Subscriber JWT key
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
# Allow anonymous subscribers (double-check that it's what you want)
anonymous
# Enable the subscription API (double-check that it's what you want)
subscriptions
# Extra directives
{$MERCURE_EXTRA_DIRECTIVES}
vulcain
# Add links to the API docs and to the Mercure Hub if not set explicitly (e.g. the PWA)
header ?Link `</docs.jsonld>; rel="http://www.w3.org/ns/hydra/core#apiDocumentation", </.well-known/mercure>; rel="mercure"`
# Disable Topics tracking if not enabled explicitly: https://github.com/jkarlin/topics
header ?Permissions-Policy "browsing-topics=()"
# Matches requests for HTML documents, for static files and for Next.js files,
# except for known API paths and paths with extensions handled by API Platform
@frontend expression `
!path(
'/docs*', '/graphql*', '/bundles*', '/contexts*', '/_profiler*', '/_wdt*',
'*.json*', '*.html', '*.csv', '*.yml', '*.yaml', '*.xml',
'/api*', '/login*', '/logout*', '/forgot-password', '/print*'
|| path('/favicon.ico', '/manifest.json', '/robots.txt', '/_nuxt*', '/sitemap*', '/signatureProductionLibrary*')`
# Comment the following line if you don't want frontend to catch requests for HTML documents.
# In this case, they will be handled by the PHP app.
reverse_proxy @frontend http://{$FRONTEND_UPSTREAM}
php_server
$SERVER_NAME = http://b.domain.fr, http://a.domain.fr, http://localhost
Startup logs :
2024/03/05 13:32:12.487 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
2024/03/05 13:32:12.493 WARN Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "/etc/caddy/Caddyfile", "line": 14}
2024/03/05 13:32:12.499 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/03/05 13:32:12.501 WARN http.auto_https server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv0", "http_port": 80}
2024/03/05 13:32:12.501 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00063c080"}
2024/03/05 13:32:13.905 INFO FrankenPHP started 🐘 {"php_version": "8.3.3"}
2024/03/05 13:32:13.905 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/03/05 13:32:13.905 INFO autosaved config (load with --resume flag) {"file": "/config/caddy/autosave.json"}
2024/03/05 13:32:13.905 INFO serving initial configuration
2024/03/05 13:32:13.912 INFO tls cleaning storage unit {"storage": "FileStorage:/data/caddy"}
2024/03/05 13:32:13.914 INFO tls finished cleaning storage units
Make a curl request :
curl 'https://a.domain.fr/connexion' --compressed -H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:123.0) Gecko/20100101 Firefox/123.0' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8' -H 'Accept-Language: fr,fr-FR;q=0.8,en-US;q=0.5,en;q=0.3' -H 'Accept-Encoding: gzip, deflate, br' -H 'Connection: keep-alive' -H 'Upgrade-Insecure-Requests: 1' -H 'Sec-Fetch-Dest: document' -H 'Sec-Fetch-Mode: navigate' -H 'Sec-Fetch-Site: none' -H 'Sec-Fetch-User: ?1' -H 'Pragma: no-cache' -H 'Cache-Control: no-cache'
response :
<HEAD><TITLE>Unknown Host</TITLE></HEAD>
<BODY BGCOLOR="white" FGCOLOR="black"><H1>Unknown Host</H1><HR>
<FONT FACE="Helvetica,Arial"><B>
Description: Unable to locate the server named "<em>a.domain.fr</em>" --- the server does not have a DNS entry. Perhaps there is a misspelling in the server name, or the server no longer exists. Double-check the name and try again.</B></FONT>
<HR>
<!-- default "Unknown Host" response (504) -->
</BODY>
Caddy logs :
2024/03/07 10:13:36.237 ERROR http.log.access.log0 handled request {"request": {"remote_ip": "10.33.150.1", "remote_port": "61284", "client_ip": "10.33.150.1", "proto": "HTTP/1.1", "method": "GET", "host": "a.domain.fr", "uri": "/connexion", "headers": {"User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:123.0) Gecko/20100101 Firefox/123.0"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"], "Sec-Fetch-User": ["?1"], "Cache-Control": ["no-cache"], "Accept-Language": ["fr,fr-FR;q=0.8,en-US;q=0.5,en;q=0.3"], "Accept-Encoding": ["gzip, deflate, br"], "Cookie": [], "Upgrade-Insecure-Requests": ["1"], "Sec-Fetch-Dest": ["document"], "Sec-Fetch-Site": ["none"], "Pragma": ["no-cache"], "Connection": ["keep-alive"], "Sec-Fetch-Mode": ["navigate"]}}, "bytes_read": 0, "user_id": "", "duration": 0.040428296, "size": 354, "status": 504, "resp_headers": {"Content-Type": ["text/html"], "Vary": ["Accept-Encoding"], "Permissions-Policy": ["browsing-topics=()"], "Date": ["Thu, 07 Mar 2024 10:13:36 GMT"], "Cache-Control": ["no-store"], "Content-Encoding": ["gzip"], "Via": ["1.1 b2-ttheb-prx1"], "Link": ["</docs.jsonld>; rel=\"http://www.w3.org/ns/hydra/core#apiDocumentation\", </.well-known/mercure>; rel=\"mercure\""], "Server": ["Caddy"], "Content-Language": ["en"]}}
