Caddy rewrite not working
caddy:2.3.0-alpine
docker-compose -f docker-compose-caddy.yml up -d
Docker
paste command here
version: "3"
    image: caddy:2.3.0-alpine
      - "2019:2019"
      - app
      - $PWD/caddy_configs:/etc/caddy/caddy_configs
      - $PWD/site:/srv
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
  app:
    external:
import /etc/caddy/caddy_configs/*.caddy
test.site1.co {
    reverse_proxy webserver:7051
https:// {
		on_demand
I have two sub-domains:
I have created a CNAME entry for test.site2.com pointing to test.site1.co
Now, when I visit test.site2.com it opens test.site1.co (which is what should happen in an ideal case)
but what I want instead to happen is upon visiting test.site2.com it should redirect to test.site2.com/new_page but visiting test.site2.com/new_page should just open directly
caddy_1  | {"level":"info","ts":1613413312.354229,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | run: adapting config using caddyfile: parsing caddyfile tokens for 'rewrite': /etc/caddy/caddy_configs/calenvie.caddy:2 - Error during parsing: Wrong argument count or unexpected line ending after 'rewrite'
caddy_1  | {"level":"info","ts":1613413313.733398,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413315.0032415,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413316.4365928,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413318.2655513,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413320.892288,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413325.1765468,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413332.6646836,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413346.630897,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413373.4453888,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413425.7973611,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1  | {"level":"info","ts":1613413486.974338,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
test.site2.com {
    rewrite / {
		to /new_page
You haven’t shared that config file. What are the contents of that file?
That’s not correct syntax. Please take a look at the docs:
I don’t see that you’ve configured the global options for on_demand_tls. Please do so, because otherwise you open yourself up for abuse. Anyone can make a request to your server with any hostname and Caddy will issue a certificate for it, without limit. This means that an attacker could have your server continually issue certificates, eating up storage space and forcing your server to hit rate limits. It’s very important that you configure limits, typically by configuring an ask endpoint so Caddy can ask your app “is this domain ok to get a cert for?”:
This is the complete Caddyfile
test.site1.co {
https:// {
		on_demand
This statement import /etc/caddy/caddy_configs/*.caddy is importing the other config file (calenvie.caddy)
Content in calenvie.caddy
test.site2.com {
    redir / https://test.site2.com/new_page{uri} permanent
This is still not working. Now, there’s no error but I get an empty page rather than the actual page.
I have also tried the following but with no luck:
test.site2.com {
    rewrite / /new_page
This is still on a test server and I am learning Caddy. I will definitely implement the ask endpoint before going to production.
Well you’re not actually doing anything in that site, so of course nothing will be served. You need to enable file_server or reverse_proxy or whatever for it to do something useful.
Caddy will respond to unhandled requests will an empty response with 200 status. This is because Caddy “did what you told it to do”, i.e. nothing; which isn’t an error on Caddy’s part, but a misconfiguration.
Hi
I have updated the Caddyfile to this:
test.site1.co {
https:// {
		on_demand
	handle_path / {
		rewrite / /new_page{path}
Still no luck :frowning:
I want https://test.site2.com to go to https://test.site2.com/new_page and directly going to https://test.site2.com/new_page should also work.
handle_path / will only accept requests to exactly / and nothing else. Path matching in Caddy v2 is exact.
It also doesn’t make sense to use handle_path with no path matcher, because it exists as a shortcut to handle + uri strip_prefix. If you don’t need the strip_prefix logic, then use handle instead.
But in this case you probably don’t even need handle, it doesn’t do anything useful for you here.
I think the misunderstanding you’re having is that you think that site blocks will fall through to the https:// block if they don’t do anything with the request, but that’s not the case. If you make a test.site2.com site block, then you need to handle the request there. The https:// block is for requests to hostnames that you don’t have otherwise configured. So test.site3.com will be handled by https:// because you didn’t define that as a site you’re handling separately.
Thanks a lot (@francislavoie) for your patience and help. Finally, it is working now. Here’s my Caddyfile
test.site1.co {
https:// {
		on_demand
		redir / https://{host}/new_page{uri} permanent
	handle /new_page* {
You can just simplify this to:
You don’t need handle for your usecase, it’s redundant.
