I have a Caddy instance running as a reverse proxy to a Go app that presents an http interface (http only, no https)
GET requests work with no problems, e.g. :
curl https://<my_caddy_hostname>:8083/46df8d1574d/ping
pong
But POST requests fail with a 502, e.g.:
curl -v -X POST https://<my_caddy_hostname>:8083/46df8d1574d/foo
-H ‘Content-Type: application/json’
‘{“app”:“test”,“id”:“test”,“data”:{“foo”:“bar”}}’
gives
* We are completely uploaded and fine
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Tue, 28 Mar 2023 11:20:55 GMT
and on the caddy side…
{"level":"debug","ts":1680002445.846841,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"localhost:49836","total_upstreams":1}
{"level":"debug","ts":1680002455.851198,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:49836","duration":10.004234974,"request":{"remote_ip":"fdf3:5229:af30:5::","remote_port":"28382","proto":"HTTP/2.0","method":"POST","host":"<my_caddy_hostname>:8083","uri":"/46df8d1574d/foo","headers":{"Accept":["*/*"],"Content-Type":["application/json"],"Content-Length":["109"],"X-Forwarded-For":["fdf3:5229:af30:5::"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["<my_caddy_hostname>:8083"],"User-Agent":["curl/7.86.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"<my_caddy_hostname>"}},"error":"EOF"}
{"level":"error","ts":1680002455.851816,"logger":"http.log.error","msg":"EOF","request":{"remote_ip":"fdf3:5229:af30:5::","remote_port":"28382","proto":"HTTP/2.0","method":"POST","host":"<my_caddy_hostname>:8083","uri":"/46df8d1574d/foo","headers":{"Accept":["*/*"],"Content-Type":["application/json"],"Content-Length":["109"],"User-Agent":["curl/7.86.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"<my_caddy_hostname>"}},"duration":10.005012201,"status":502,"err_id":"fivmzbbyg","err_trace":"reverseproxy.statusError (reverseproxy.go:1299)"}
My caddyfile is very simple:
auto_https disable_certs
persist_config off
admin :2019
:443 {
header -Server
tls /ssl/tls.crt /ssl/tls.key
root * /usr/share/caddy/public
encode gzip zstd
php_fastcgi localhost:9000
reverse_proxy /46df8d1574d/* localhost:49836
Just to avoid any confusion, this is running on Kubernetes (K3S) so, please remember that references to “localhost” means “containers within the same pod”, which is why the above Caddyfile works (see Pods | Kubernetes)
