Red Hat Enterprise Linux Server release 7.8 (Maipo)
caddy binary, configured to reverse proxy to webserver on localhost
Python (uwsgi) based web server running on localhost
./caddy_linux_amd64 run
N/A
(common) {
header /* {
-Content-Type
-Server
header Customer-Header "Test"
header -Content-Type
header Content-Type "application/octet-stream"
header /* Content-Type application/octet-stream
192.168.1.70 {
reverse_proxy 127.0.0.1:9090 {
import common
Using Caddy as reverse proxy adds Content-Type (and incorrectly which causes page rendering issues):
curl -k -I -X GET https://192.168.1.70/galaxy/static/dist/libs.chunk.js
HTTP/1.1 200 OK
**Content-Length**: 33604620
**Customer-Header**: Test
**Last-Modified**: Tue, 05 Apr 2022 23:37:09 GMT
**Date**: Thu, 07 Apr 2022 04:34:03 GMT
**Content-Type**: text/plain; charset=utf-8
Using nginx as reverse proxy has no Content-Type:
curl -k -I -X GET http://192.168.1.70/galaxy/static/dist/libs.chunk.js
HTTP/1.1 200 OK
**Server**: nginx
**Date**: Thu, 07 Apr 2022 05:03:50 GMT
**Connection**: keep-alive
Direct from the source:
curl -k -I -X GET http://192.168.1.70:9090/static/dist/libs.chunk.js
HTTP/1.1 200 OK
Content-Length: 33604620
Last-Modified: Tue, 05 Apr 2022 23:37:09 GMT
2022/04/07 15:03:36.029 | DEBUG | tls.handshake | choosing certificate | {identifier: 192.168.1.70, num_choices: 1} |
2022/04/07 15:03:36.029 | DEBUG | tls.handshake | default certificate selection results | {identifier: 192.168.1.70, subjects: [192.168.1.70], managed: true, issuer_key: local, hash: 5da828271d718dd03d564403606794874d94662da1bd55a346fb8012ef16a0b1} |
2022/04/07 15:03:36.029 | DEBUG | tls.handshake | matched certificate in cache | {subjects: [192.168.1.70], managed: true, expiration: 2022/04/08 00:16:42.000, hash: 5da828271d718dd03d564403606794874d94662da1bd55a346fb8012ef16a0b1} |
2022/04/07 15:03:36.034 | DEBUG | http.handlers.reverse_proxy | upstream roundtrip | {upstream: 127.0.0.1:9090, duration: 0.001414629, request: {remote_addr: 192.168.1.149:63737, proto: HTTP/1.1, method: GET, host: 192.168.1.70, uri: /static/dist/libs.chunk.js, headers: {X-Forwarded-For: [192.168.1.149], User-Agent: [curl/7.80.0], Accept: [/], X-Forwarded-Proto: [https]}, tls: {resumed: false, version: 772, cipher_suite: 4865, proto: http/1.1, proto_mutual: true, server_name: }}, headers: {Content-Length: [33604620], Last-Modified: [Tue, 05 Apr 2022 23:37:09 GMT]}, status: 200} |
2022/04/07 15:03:36.036 | ERROR | http.handlers.reverse_proxy | aborting with incomplete response | {error: write tcp 192.168.1.70:443->192.168.1.149:63737: write: connection reset by peer} |
I tried Caddy using http (non-https) too.
Note, the ERROR in the debug output seems to only show when I use the specific curl command with -I to show headers.
If I use:
curl -k https://192.168.1.70/static/dist/libs.chunk.js
The debug output is:
2022/04/07 15:12:21.899 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "127.0.0.1:9090", "duration": 0.000999075, "request": {"remote_addr": "192.168.1.149:49750", "proto": "HTTP/1.1", "method": "GET", "host": "192.168.1.70", "uri": "/static/dist/libs.chunk.js", "headers": {"X-Forwarded-Proto": ["https"], "X-Forwarded-For": ["192.168.1.149"], "User-Agent": ["curl/7.80.0"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "http/1.1", "proto_mutual": true, "server_name": ""}}, "headers": {"Content-Length": ["33604620"], "Last-Modified": ["Tue, 05 Apr 2022 23:37:09 GMT"]}, "status": 200}
