sudo systemctl start caddy
Linux ip-172-31-29-214 4.4.0-1128-aws #142-Ubuntu SMP Fri Apr 16 12:42:33 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Xenial
node-0.t3nx.net {
reverse_proxy / localhost:8080
reverse_proxy /api localhost:5000
reverse_proxy /admin localhost:5000
node-0-frontend.t3nx.net {
reverse_proxy localhost:8080
node-0-backend.t3nx.net {
reverse_proxy localhost:5000
I am trying to use Caddy reverse proxy to serve Flutter web app and also Django REST api. I split them by path since I would like to serve it from different service
I serve frontend Flutter web app using
http-server build/web
I serve backend Django api
gunicorn beauty_coin.wsgi --bind 0.0.0.0:5000 --chdir=beauty_coin
curl [https://node-0.t3nx.net](https://node-0.t3nx.net%60%60%60) responses me the source code of page. This url has no problem
<!-- Please **DO NOT REDACT** any information except credentials. Leave domain names intact! -->
<!-- Please **DO NOT POST TRUNCATED LOG LINES** as systemd is notorious for this. -->
<!-- Please **DO NOT USE WEB BROWSERS.** Use curl -v instead. -->
<!-- Please **DO ENABLE DEBUG MODE FIRST** by adding "debug" to the global options of your Caddyfile. -->
`curl -v [https://node-0.t3nx.net`](https://node-0.t3nx.net%60) responses blank line
❯ curl -v https://node-0.t3nx.net/admin
* Trying 52.74.149.26:443...
* Connected to node-0.t3nx.net (52.74.149.26) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-GCM-SHA256
* subject: CN=node-0.t3nx.net
* start date: Jan 15 17:02:17 2022 GMT
* expire date: Apr 15 17:02:16 2022 GMT
* subjectAltName: host "node-0.t3nx.net" matched cert's "node-0.t3nx.net"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x7fbda800b600)
> GET /admin HTTP/2
> Host: node-0.t3nx.net
> user-agent: curl/7.77.0
> accept: */*
< HTTP/2 301
< date: Sat, 15 Jan 2022 19:11:44 GMT
< location: /admin/
< referrer-policy: same-origin
< server: Caddy
< server: gunicorn
< vary: Origin
< content-length: 0
* Connection #0 to host node-0.t3nx.net left intact
I have tried split the URL into [node-0-frontend.t3nx.net](http://node-0-frontend.t3nx.net) and [node-0-backend.t3nx.net](http://node-0-backend.t3nx.net). It works
But when I merge them together to solve CORS problem in Chrome by using [node-0.t3nx.net](http://node-0.t3nx.net). My backend url does not work.
Django urls.py
from django.contrib import admin
from django.urls import path, include
from rest_framework.authtoken.views import obtain_auth_token
from profiles.api.fbvs import welcome, get_balance, send_transaction
urlpatterns = [
path('admin/', admin.site.urls),
path('api/', include('beauty_coin.api_routers')),
path('api/auth-token/', obtain_auth_token),
path('api/welcome/', welcome),
path('api/balance/', get_balance),
path('api/send-transaction/', send_transaction)
