2.4.6
amd64, Debian 11, Docker
image: caddy:latest
- ${DATADIR}/caddy/Caddyfile:/etc/caddy/Caddyfile
- ${DATADIR}/caddy/data:/data # Optional
- ${DATADIR}/caddy/config:/config # Optional
- TZ=${TZ}
labels:
- "com.centurylinklabs.watchtower.enable=true"
- "com.centurylinklabs.watchtower.monitor-only=true"
# Optional email key for lets encrypt
# email youremail@.........
# Optional staging lets encrypt for testing. Comment out for production.
ha.mini2x14.local {
encode zstd gzip
reverse_proxy http://192.168.88.14:8123
# enable HSTS
# clickjacking protection
#X-Frame-Options DENY
# Content-Security-Policy: default-src 'self'
portainer.mini2x14.local {
encode zstd gzip
reverse_proxy http://portainer:9000
# enable HSTS
In general, everything works. However, in Safari (macOS) I noticed such a problem - in the address bar of the site behind the Caddy, there are no buttons (refresh, share, bookmark, and so on). It looks like the connection is in timeout state, page loading does not complete. In addition, in developer mode, capturing network activity does not stop automatically (although it should after the page has finished loading). With a direct visiting to the proxied server, everything is fine. Haven't noticed this with any other site. Everything is fine in Chrome.I understand that the problem may not be directly related to Caddy, but I can not find anything on this topic. I ask for help in diagnosing the problem (only reproducible when using Caddy as a reverse proxy). Please, advise what to try with Caddy settings to localize the cause (this is my first experience with Caddy).
There are no errors in the logs. Example curl
output:
aleksey@mPro-2x14 ~ % curl -v https://portainer.mini2x14.local
* Trying 192.168.88.14:443...
* Connected to portainer.mini2x14.local (192.168.88.14) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-GCM-SHA256
* subject: [NONE]
* start date: Mar 13 22:08:12 2022 GMT
* expire date: Mar 14 10:08:12 2022 GMT
* subjectAltName: host "portainer.mini2x14.local" matched cert's "portainer.mini2x14.local"
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x7fdcae011e00)
> GET / HTTP/2
> Host: portainer.mini2x14.local
> user-agent: curl/7.77.0
> accept: */*
< HTTP/2 200
< accept-ranges: bytes
< cache-control: max-age=31536000
< date: Mon, 14 Mar 2022 02:07:19 GMT
< last-modified: Wed, 09 Feb 2022 01:01:46 GMT
< referrer-policy: no-referrer-when-downgrade
< server: Caddy
< strict-transport-security: max-age=31536000;
< vary: Accept-Encoding
< x-xss-protection: 1; mode=block
<!doctype html>
</html>%
