2.4.6
Ubuntu Server 20.04.3 LTS x86_64
Docker version 20.10.12, build e91ed57
docker-compose version 1.29.2, build 5becea4c
DNS managed by Namecheap with a simple A record @ → IPv4
Dockerfile
ARG CADDY_VERSION=2.4.6
FROM caddy:${CADDY_VERSION}-builder AS builder
RUN xcaddy build \
--with github.com/lucaslorentz/caddy-docker-proxy/plugin \
--with github.com/caddy-dns/namecheap
CMD ["caddy", "docker-proxy"]
docker-compose.yml
version: '3.7'
build: .
- 443:443
- CADDY_INGRESS_NETWORKS=caddy
- ACME_AGREE=true
- caddy
- caddy_data:/data
external: true
caddy_data: {}
docker-compose.yml (for a simple whoami test image)
version: '3.7'
whoami:
image: jwilder/whoami
- caddy
labels:
caddy: hello.waloschek.me
caddy.reverse_proxy: "{{upstreams 8000}}"
caddy.tls.dns: "namecheap"
caddy.tls.dns.user: "${NAMECHEAP_USER}"
caddy.tls.dns.api_key: "${NAMECHEAP_API_KEY}"
external: true
Not really applicable, gets build internally by caddy-docker-proxy
, but here is the auto generated Caddyfile:
hello.waloschek.me {
reverse_proxy 172.19.0.2:8000
dns namecheap {
api_key ......its_a_secret.......
user ....same....
I am not able to even resolve the host hello.waloschek.me
let alone get a HTTP GET response via https://hello.waloschek.me
using curl:
$ curl -v https://hello.waloschek.me/
* Could not resolve host: hello.waloschek.me
* Closing connection 0
curl: (6) Could not resolve host: hello.waloschek.me
{"level":"info","ts":1641241596.4617794,"logger":"docker-proxy","msg":"Running caddy proxy server"}
{"level":"info","ts":1641241596.4627314,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
{"level":"info","ts":1641241596.46288,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1641241596.462898,"logger":"docker-proxy","msg":"Running caddy proxy controller"}
{"level":"info","ts":1641241596.4635024,"logger":"docker-proxy","msg":"Start","CaddyfilePath":"","LabelPrefix":"caddy","PollingInterval":30,"ProcessCaddyfile":true,"ProxyServiceTasks":true,"IngressNetworks":"[caddy]","DockerSockets":[""],"DockerCertsPath":[""],"DockerAPIsVersion":[""]}
{"level":"info","ts":1641241596.4641638,"logger":"docker-proxy","msg":"Connecting to docker events","DockerSocket":""}
{"level":"info","ts":1641241596.4645758,"logger":"docker-proxy","msg":"IngressNetworksMap","ingres":"map[572518288bd77fcd99fc3522669f167c883d1abd1677ed00da1856db6c5962c4:true]"}
{"level":"info","ts":1641241596.4733803,"logger":"docker-proxy","msg":"Swarm is available","new":false}
{"level":"info","ts":1641241596.473398,"logger":"docker-proxy","msg":"Skipping default Caddyfile because no path is set"}
{"level":"info","ts":1641241596.4734013,"logger":"docker-proxy","msg":"Skipping swarm config caddyfiles because swarm is not available"}
{"level":"info","ts":1641241596.474661,"logger":"docker-proxy","msg":"Skipping swarm services because swarm is not available"}
{"level":"info","ts":1641241596.4755554,"logger":"docker-proxy","msg":"New Caddyfile","caddyfile":"hello.waloschek.me {\n\treverse_proxy 172.19.0.2:8000\n\ttls {\n\t\tdns namecheap {\n\t\t\tapi_key ......its_a_secret.......\n\t\t\tuser ....same....\n\t\t}\n\t}\n}\n"}
{"level":"info","ts":1641241596.4762275,"logger":"docker-proxy","msg":"New Config JSON","json":"{\"apps\":{\"http\":{\"servers\":{\"srv0\":{\"listen\":[\":443\"],\"routes\":[{\"match\":[{\"host\":[\"hello.waloschek.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"172.19.0.2:8000\"}]}]}]}],\"terminal\":true}]}}},\"tls\":{\"automation\":{\"policies\":[{\"subjects\":[\"hello.waloschek.me\"],\"issuers\":[{\"challenges\":{\"dns\":{\"provider\":{\"api_key\":\"......its_a_secret.......\",\"name\":\"namecheap\",\"user\":\"....same....\"}}},\"module\":\"acme\"},{\"challenges\":{\"dns\":{\"provider\":{\"api_key\":\"......its_a_secret.......\",\"name\":\"namecheap\",\"user\":\"....same....\"}}},\"module\":\"zerossl\"}]}]}}}}"}
{"level":"info","ts":1641241596.4763904,"logger":"docker-proxy","msg":"Sending configuration to","server":"localhost"}
{"level":"info","ts":1641241596.477473,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_addr":"127.0.0.1:43136","headers":{"Accept-Encoding":["gzip"],"Content-Length":["657"],"Content-Type":["application/json"],"User-Agent":["Go-http-client/1.1"]}}
{"level":"info","ts":1641241596.4778223,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1641241596.4779835,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1641241596.4779944,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1641241596.4779925,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000444690"}
{"level":"info","ts":1641241596.4782763,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1641241596.4783366,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["hello.waloschek.me"]}
{"level":"info","ts":1641241596.4787734,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1641241596.481878,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1641241596.481893,"logger":"admin.api","msg":"load complete"}
{"level":"info","ts":1641241596.4820142,"logger":"docker-proxy","msg":"Successfully configured","server":"localhost"}
{"level":"info","ts":1641241596.4872177,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
{"level":"info","ts":1641241626.4836822,"logger":"docker-proxy","msg":"Skipping default Caddyfile because no path is set"}
{"level":"info","ts":1641241626.4837227,"logger":"docker-proxy","msg":"Skipping swarm config caddyfiles because swarm is not available"}
{"level":"info","ts":1641241626.4867892,"logger":"docker-proxy","msg":"Skipping swarm services because swarm is not available"}
Accessing the whoami
container directly by its docker IP works without any problems:
$ curl -v 172.19.0.2:8000
* Trying 172.19.0.2:8000...
* TCP_NODELAY set
* Connected to 172.19.0.2 (172.19.0.2) port 8000 (#0)
> GET / HTTP/1.1
> Host: 172.19.0.2:8000
> User-Agent: curl/7.68.0
< HTTP/1.1 200 OK
< Date: Mon, 03 Jan 2022 20:32:11 GMT
< Content-Length: 17
I'm 90faf37f8afd
* Connection #0 to host 172.19.0.2 left intact
Also, exposing whoami:8000
on http://waloschek.me:8000
with a simple docker run [...]
works as well.
The log (see above) shows no signs of problems whatsoever. I’m at loss.
