Caddy Reverse Proxy Headache
I am trying to proxy services behind caddy and then plubish them through subdomains of my domain. I have tried deploying differing versions of the wordpress container, including :latest, and specific versions of php (this chages nothing). I believe this is related to how the wp-config.php file is configured to handle https rewrites through the proxy, since I do expierence a login loop when trying to do so.
This is the site https://allofmy.work
As you can see it, it’s only outputting text
<?php
define('FORCE_SSL_ADMIN', true);
if ($_SERVER['HTTP_X_FORWARDED_PROTO'] == 'https')
     $_SERVER['HTTPS']='on';
  * The base configuration for WordPress
* The wp-config.php creation script uses this file during the
* installation. You don't have to use the web site, you can
* copy this file to "wp-config.php" and fill in the values.
* This file contains the following configurations:
* * MySQL settings
* * Secret keys
* * Database table prefix
* * ABSPATH
* @link https://codex.wordpress.org/Editing_wp-config.php
* @package WordPress
// ** MySQL settings - You can get this info from your web host ** //
/** The name of the database for WordPress */
define('DB_NAME', 'haha');
/** MySQL database username */
define('DB_USER', 'nah');
/** MySQL database password */
define('DB_PASSWORD', 'you thought');
/** MySQL hostname */
define('DB_HOST', 'db');
/** Database Charset to use in creating database tables. */
define('DB_CHARSET', 'utf8mb4');
/** The Database Collate type. Don't change this if in doubt. */
define('DB_COLLATE', '');
 * Authentication Unique Keys and Salts.
 * Change these to different unique phrases!
 * You can generate these using the {@link https://api.wordpress.org/secret-key/1.1/salt/ WordPress.org             secret-key service}
 * You can change these at any point in time to invalidate all existing cookies. This will force all users to     have to log in again.
 * @since 2.6.0
define('AUTH_KEY',         'fdsa;
define('SECURE_AUTH_KEY',  'fdsa);
define('LOGGED_IN_KEY',    'nlbjfdsaN');
define('NONCE_KEY',        'vkYWPmWfdsaTL<R2Pi=PV,Ox|');
define('AUTH_SALT',        'EkbHwfdsa');
define('SECURE_AUTH_SALT', '9!OnH2Ee:fdsag]f');
define('LOGGED_IN_SALT',   ')bfdsa.K(');
define('NONCE_SALT',       'Wj3fdsa');
 * WordPress Database Table prefix.
 * You can have multiple installations in one database if you give each
 * a unique prefix. Only numbers, letters, and underscores please!
$table_prefix  = 'wp_';
 * For developers: WordPress debugging mode.
 * Change this to true to enable the display of notices during development.
 * It is strongly recommended that plugin and theme developers use WP_DEBUG
 * in their development environments.
 * For information on other constants that can be used for debugging,
 * visit the Codex.
 * @link https://codex.wordpress.org/Debugging_in_WordPress
define('WP_DEBUG', false);
/* That's all, stop editing! Happy blogging. */
/** Absolute path to the WordPress directory. */
if ( !defined('ABSPATH') )
	define('ABSPATH', dirname(__FILE__) . '/');
/** Sets up WordPress vars and included files. */
require_once(ABSPATH . 'wp-settings.php');
My relevant config
Here’s what I get when I visit the site:
The website is working, but misconfigured. These are the cause of your lack of styling in the browser:
This is because your Caddyfile has this rewrite:
rewrite {
        if {path} not_match ^\/wp-admin
        to {path} {path}/ /index.php?_url={uri}
But you don’t need to, because Wordpress’ default container runs Apache and handles this rewrite already, so you’re double rewriting. Try without this rewrite entirely.
