Caddy reverse proxy for Vault
Reverse proxy tls authentication problem. According to my Caddyfile configuration after testing with below commands
curl --cert client.crt --key client.key --cacert ca_root.crt -H “X-Vault-Token: hvs.xxx” https://127.0.0.1:8100/v1/sys/metrics?format=prometheus
curl: (60) SSL certificate problem: could not get local issuer certificate
I have the problem “curl: (60) SSL certificate problem: could not get local issuer certificate
More details here: curl - SSL CA Certificates
But according to configuration see link (Links to relevant resources:) everything works fine.
curl: (60) SSL certificate problem: unable to get local issuer certificate
caddy version
v2.9.1
pkg install but isn’t problem with installation
Freebsd & HardenedBSD v. 14.2 but it doesn’t mater
curl Test
curl --cert client.crt --key client.key --cacert ca_root.crt -H "X-Vault-Token:  hvs.xxx"   https://127.0.0.1:8100/v1/sys/metrics?format=prometheus
 curl --cert client.crt --key client.key --cacert ca_root.crt -H "X-Vault-Token:  hvs.xxx"   -k https://127.0.0.1:8100/v1/sys/metrics?format=prometheus
  HELP core_leadership_lost Total time that a high-availability cluster node last maintained leadership
# TYPE core_leadership_lost summary
core_leadership_lost{quantile="0.5"} NaN
core_leadership_lost{quantile="0.9"} NaN
core_leadership_lost{quantile="0.99"} NaN
core_leadership_lost_sum 0
c. My complete Caddy config:
My caddyfile
https://127.0.0.1:8100 {
        tls /mnt/vaultcerts/agent.crt /mnt/vaultcerts/agent.key {
                protocols tls1.2 tls1.3
                alpn h2 http/1.1
        header -Server
        import log_redacted vaultproxy
        # Reverse proxy to Vault
        reverse_proxy https://active.vault.service.consul:8200 {
                header_up Host active.vault.service.consul
                header_up X-Forwarded-For {remote_host}
                header_up X-Forwarded-Port {server_port}
                        versions 2
                        keepalive 65s
                        tls_client_auth /mnt/vaultcerts/agent.crt /mnt/vaultcerts/agent.key
                        tls_trusted_ca_certs /mnt/vaultcerts/ca_root.crt
                        tls_server_name active.vault.service.consul
        # Error handling with fallback to HTTP Cat
        handle_errors {
                rewrite * /{http.error.status_code}
                reverse_proxy https://http.cat {
                        header_up Host http.cat
Are you running this in the /mnt/vaultcerts directory? If not, use --cacert /mnt/vaultcertsca_root.crt
Yes, in the same directory. I’ll check that. But I don’t think that’s the problem, because I’m using Ngnix, for comparison, and there’s no problem. The certificates are generated by Vault in the Nginx configuration, so the problem doesn’t occur.
Caddy is great. My config is fine, the error is due to my ignorance about curl. I’m burning with shame.
