Caddy Reverse Proxy for Authentik
Hey there,
I have successfully deployed Authentik with Docker Compose in my Homelab.
Now I tried deploying it on a Hetzner VPS running Ubuntu 22.04 and Docker.
I have already implemented the DNS record for auth.hebel.schule.
I am running caddy in another docker container and pointed a reverse proxy entry to the Authentik instance.
My problem is, I just can’t get to to the initial setup page of Authentik through my Johann-Peter-Hebel-Schule Secure Login
I had it working a few hours ago but messed it up, so I know at least, it is possible.
Another problem is, I can’t even try on the local IP, since the machine is a remote VPS and I’d rather not setup a Window Manager and all the other things up.
I can post the config files, so maybe someone can point me in the right direction.
One short notice: The logs of the containers show no error, not even in trace mode!
Docker Compose of Authentik (I even tried host network, to rule out networking issues, but that didn’t help.)
  postgresql:
    #container_name: authdb
    #networks:
      #- caddy
     # - backend
    network_mode: host
    image: docker.io/library/postgres:12-alpine
    healthcheck:
      test:
        - CMD-SHELL
        - pg_isready -d $${POSTGRES_DB} -U $${POSTGRES_USER}
      start_period: 20s
      interval: 30s
      retries: 5
      timeout: 5s
      - database:/var/lib/postgresql/data
      POSTGRES_PASSWORD: ${PG_PASS:?database password required}
      POSTGRES_USER: ${PG_USER:-authentik}
      POSTGRES_DB: ${PG_DB:-authentik}
    env_file:
      - .env
  redis:
    #container_name: authredis
    network_mode: host
    #networks:
      #- caddy
     # - backend
    image: docker.io/library/redis:alpine
    command: --save 60 1 --loglevel warning
    healthcheck:
      test:
        - CMD-SHELL
        - redis-cli ping | grep PONG
      start_period: 20s
      interval: 30s
      retries: 5
      timeout: 3s
      - redis:/data
  server:
    network_mode: host
    image: ${AUTHENTIK_IMAGE:-ghcr.io/goauthentik/server}:${AUTHENTIK_TAG:-2024.4.2}
    command: server
    #networks:
      #- caddy
     # - backend
      AUTHENTIK_REDIS__HOST: redis
      AUTHENTIK_POSTGRESQL__HOST: postgresql
      AUTHENTIK_POSTGRESQL__USER: ${PG_USER:-authentik}
      AUTHENTIK_POSTGRESQL__NAME: ${PG_DB:-authentik}
      AUTHENTIK_POSTGRESQL__PASSWORD: ${PG_PASS}
      - ./media:/media
      - ./custom-templates:/templates
    env_file:
      - .env
      - ${COMPOSE_PORT_HTTP:-9000}:9000
      - ${COMPOSE_PORT_HTTPS:-9443}:9443
    depends_on:
      - postgresql
      - redis
  worker:
    #container_name: authworker
    network_mode: host
    #networks:
      #- caddy
     # - backend
    command: worker
    # `user: root` and the docker socket volume are optional.
    # See more for the docker socket integration here:
    # https://goauthentik.io/docs/outposts/integrations/docker
    # Removing `user: root` also prevents the worker from fixing the permissions
    # on the mounted folders, so when removing this make sure the folders have the correct UID/GID
    # (1000:1000 by default)
    user: root
      - ./media:/media
      - ./certs:/certs
    env_file:
      - .env
    depends_on:
      - postgresql
      - redis
  database:
    driver: local
  redis:
    driver: local
#networks:
#  backend:
#    driver: bridge
#  caddy:
#    external: true
.env File
PG_PASS=xx
AUTHENTIK_SECRET_KEY=xx
AUTHENTIK_ERROR_REPORTING__ENABLED=true
# SMTP Host Emails are sent to
AUTHENTIK_EMAIL__HOST=mail.your-server.de
AUTHENTIK_EMAIL__PORT=587
# Optionally authenticate (don't add quotation marks to your password)
AUTHENTIK_EMAIL__USERNAME=xxx@hebel.schule
AUTHENTIK_EMAIL__PASSWORD=xx
# Use StartTLS
AUTHENTIK_EMAIL__USE_TLS=true
# Use SSL
AUTHENTIK_EMAIL__USE_SSL=false
AUTHENTIK_EMAIL__TIMEOUT=10
# Email address authentik will send from, should have a correct @domain
AUTHENTIK_EMAIL__FROM=xxx@hebel.schule
AUTHENTIK_LOG_LEVEL=trace
Caddyfile
    email xxx@hebel.schule
#Authentik WebIF
auth.hebel.schule {
    reverse_proxy authentik-server-1:9000
v2.8.0-rc.1 h1:OkAxqZMDUVP7jGtEpE+sh1NJTv9CkFWsopEmZ2eWAFc=
Docker Compose
Virtual Ubuntu 22.04, Docker, Docker Compose
    build:
      context: .
      dockerfile: Dockerfile
    network_mode: host
    #networks:
      #- caddy
    container_name: caddy2
    #image: caddy:2.8
    cap_add:
      - NET_ADMIN
      - 443:443
      - 443:443/udp
      - /home/wikiadmin/caddy2/Caddyfile:/etc/caddy/Caddyfile:ro
      - /home/wikiadmin/caddy2/site:/srv
      - /home/wikiadmin/caddy2/data:/data
      - /home/wikiadmin/caddy2/config:/config
      #- /home/wikiadmin/caddy/caddy.json:/etc/caddy/caddy.json
#networks:
#  caddy:
#    name: caddy
#    driver: bridge
#Authentik WebIF
auth.hebel.schule {
Any help is appreciated
What’s in your Caddy logs? Enable the debug global option and show your logs.
I just found out. I obviously defined the same network for all the containers.
But I forgot, that I had to create the network manually.
Once I did that, everything was good.
