Caddy results in a Blank Page - What is wrong in the Configuration
My Configuration for host @owui and @bar returns a blank ssl certified page..
The @bar is already in the documentation, anyway that also don’t show the response but the blank page..
The @owui is a open-webui docker container… I tested whether it is working by manually going to zakee.duckdns.org:8080… It did work, but does not show through the reverse proxy…
However the host @ptnr worked, It worked as shown in the following tutorial by the way..
zakee@debserver:~/Docker-Compose/Caddy$ docker compose logs
caddy  | {"level":"info","ts":1741447096.5248005,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
caddy  | {"level":"info","ts":1741447096.5308602,"msg":"adapted config to JSON","adapter":"caddyfile"}
caddy  | {"level":"info","ts":1741447096.5326748,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
caddy  | {"level":"info","ts":1741447096.5338056,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy  | {"level":"info","ts":1741447096.5339386,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy  | {"level":"info","ts":1741447096.5362804,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000291b00"}
caddy  | {"level":"info","ts":1741447096.5387661,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy  | {"level":"info","ts":1741447096.5404227,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
caddy  | {"level":"info","ts":1741447096.5417938,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy  | {"level":"warn","ts":1741447096.5423102,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
caddy  | {"level":"warn","ts":1741447096.5423324,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
caddy  | {"level":"info","ts":1741447096.5423427,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy  | {"level":"info","ts":1741447096.542354,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.zakee.duckdns.org"]}
caddy  | {"level":"info","ts":1741447096.5577765,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"1b75d764-3ddc-4edd-81c1-37d79960af1f","try_again":1741533496.5577736,"try_again_in":86399.9999995}
caddy  | {"level":"info","ts":1741447096.5604632,"logger":"tls","msg":"finished cleaning storage units"}
caddy  | {"level":"info","ts":1741447096.564922,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy  | {"level":"info","ts":1741447096.56506,"msg":"serving initial configuration"}
zakee@debserver:~/Docker-Compose/Caddy$ docker compose exec caddy caddy version
zakee@debserver:~/Docker-Compose/Caddy$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
zakee@debserver:~/Docker-Compose/Caddy$ docker -v
Docker version 28.0.1, build 068a01e
docker compose up -d
    build:
      context: .
      dockerfile: Dockerfile
    env_file:
      - .env
      - DUCKDNS_EMAIL=${DD_EMAIL}
      - DUCKDNS_API_TOKEN=${DD_API_TOKEN}
      - ACME_AGREE=true
      - 443:443
      - config:/config
      - data:/data
#      - ./index.html:/usr/share/caddy/index.html
      - caddy # add other containers onto this network to use dns name
  config:
  data:
# create this first before running the docker-compose - docker network create caddy
    external: true
# For prod you'd want to pin the version: e.g., 2.9.1-builder
FROM caddy:2.9.1-builder-alpine AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/duckdns
FROM caddy:latest
Syntax Used: Common Caddyfile Patterns — Caddy Documentation
*.zakee.duckdns.org {
		dns duckdns {env.DD_API_TOKEN}
		propagation_delay 2m
		resolvers 1.1.1.1
	@ptnr host ptnr.zakee.duckdns.org
	handle @ptnr {
		reverse_proxy https://portainer:9443 {
				tls
				tls_insecure_skip_verify
		@owui host owui.zakee.duckdns.org
		handle @owui {
			reverse_proxy open-webui:8080
		@bar host bar.zakee.duckdns.org
		handle @bar {
			respond "Bar!"
Everything is inside this handle, which is only matching on requests for host ptnr.zakee.duckdns.org. You’re trying to make bar.zakee.duckdns.org work, but bar is not ptnr.
Thank You so much… I failed to notice that there is a bracket of @ptnr which was not closed… Now it works as it should… Have a nice day :heart:.
		resolvers 1.1.1.1
	handle_errors {
		respond "{err.status_code} {err.status_text}"
	handle @ptnr {
		reverse_proxy portainer:9443 {
				tls
	handle @owui {
	handle @bar {
		respond "Bar!"
