v2.5.0 h1:eRHzZ4l3X6Ag3kUt8nj5IxATprhqKq/wToP7OHlXWA0=
caddy start with a caddyfile at root of the project. And I access via https://localhost/
Windows 10 21H2, 19044.1645
caddy start
admin localhost:3019
localhost {
reverse_proxy 127.0.0.1:58806
I give caddy a try last month. At the time things are working fine. And I think Caddy generated a cert that expires on 4/29. And today 5/9, I try to run it again, it looks caddy removed the localhost cert as it’s already expired, and then it tries to renewal it, and report error, that the key file can’t be found.
I used Caddy a few weeks back, and at the time the certs works properly. And on the most recent usage, I see the below logs and error.
What the recommended steps to restore this setup in working order?
I had to remove a few lines from the log before to be allowed to post. for full log, please refer to original github post, mainly the windows path of related resources. (Or: Gist )
2022/05/09 12:10:04.504 INFO admin admin endpoint started {"address": "tcp/localhost:3019", "enforce_origin": false, "origins": ["//localhost:3019", "//[::1]:3019", "//127.0.0.1:3019"]}
2022/05/09 12:10:04.505 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000024cb0"}
2022/05/09 12:10:04.506 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2022/05/09 12:10:04.506 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2022/05/09 12:10:04.562 INFO pki.ca.local root certificate is already trusted by system {"path": "storage:pki/authorities/local/root.crt"}
2022/05/09 12:10:04.562 INFO pki intermediate expires soon; renewing {"ca": "local", "time_remaining": -888682.5628871}
2022/05/09 12:10:04.568 INFO pki renewed intermediate {"ca": "local", "new_expiration": "2022/05/16 12:10:04.000"}
2022/05/09 12:10:04.570 INFO http enabling automatic TLS certificate management {"domains": ["localhost"]}
2022/05/09 12:10:04.595 WARN tls stapling OCSP {"error": "no OCSP stapling for [localhost]: no OCSP server specified in certificate", "identifiers": ["localhost"]}
2022/05/09 12:10:04.598 INFO admin.api load complete
2022/05/09 08:10:04 [INFO] Certificate certificates/local/localhost/localhost.crt expired 370h41m40.6010362s ago; cleaning up
2022/05/09 08:10:04 [INFO] Deleting certificates/local/localhost/localhost.crt because resource expired
2022/05/09 08:10:04 [INFO] Deleting certificates/local/localhost/localhost.key because resource expired
2022/05/09 08:10:04 [INFO] Deleting certificates/local/localhost/localhost.json because resource expired
2022/05/09 08:10:04 [INFO] Deleting certificates/local/localhost because key is empty
Here the localhost key resources are being removed.
2022/05/09 12:10:04.603 INFO tls finished cleaning storage units
2022/05/09 12:10:04.605 INFO admin stopped previous server {"address": "tcp/localhost:2019"}
2022/05/09 12:10:04.608 INFO tls.renew acquiring lock {"identifier": "localhost"}
2022/05/09 12:10:04.609 INFO tls.renew lock acquired {"identifier": "localhost"}
Here is the error when it’s used in renewal.
I tried to do a few caddy untrust, and caddy trust but it’s not getting anywhere.
