When trying to run caddy reload
in a Gitlab CI container, I encounter an error:
Error: sending configuration to instance: performing request: Post "http://localhost:2019/load": dial tcp 127.0.0.1:2019: connect: connection refused
This error does not occur when creating the same container locally.
We use a custom caddy image like so:
ARG CADDY_VERSION=2.8
FROM caddy:${CADDY_VERSION}-builder-alpine AS builder
RUN xcaddy build \
--with github.com/caddyserver/transform-encoder \
--with github.com/hairyhenderson/caddy-teapot-module \
--with github.com/mholt/caddy-l4 \
--with github.com/abiosoft/caddy-json-schema
FROM caddy:${CADDY_VERSION}-alpine
RUN apk add curl jq
With the following Caddyfile:
admin 0.0.0.0:2019
email operations@example.com
log access-json {
format json
include http.log.access.access-logs
output file /var/log/caddy/access-json.log
format filter {
request>headers>Cookie delete
resp_headers delete
log access-common {
format transform `{request>headers>X-Forwarded-For>[0]:request>remote_ip} - {user_id} [{ts}] {request>headers>X-Forwarded-Host:request>host} "{request>method} {request>uri} {request>proto}" {status} {size} "{request>headers>Referer>[0]}" "{request>headers>User-Agent>[0]}"` {
time_format iso8601
output file /var/log/caddy/access-common.log
(base-rm-resp-headers) {
header -server
header -x-commerce-core
header -x-drupal-cache
header -x-drupal-dynamic-cache
header -x-generator
header -x-powered-by
(base-transport-tls-insecure) {
tls_insecure_skip_verify
import Caddyfile.d/*.caddyfile
In out Gitlab CI stage, we simply do the following:
- Use the caddy image built from the above Dockerfile
- Copy the Caddyfile from our repo into /etc/caddy/Caddyfile - the Caddyfile in our repo is 100% identical to the Caddyfile baked into the container image, so this step is not relevant at this point in time.
- Copy a JSON file with mholt/caddy-l4 server definitions from our repo into /etc/caddy/layer4-ssh-proxies.json
- cd /etc/caddy
- caddy version
- caddy reload
At this point the pipeline fails with the error above.
When running the container locally, mounting the repo at /builds/operations/ingress-router/, and executing the same steps, the caddy reload
command works as expected:
docker run -v $PWD/ingress-router:/builds/operations/ingress-router gitlab-reg.example.com/operations/ops-oci-images/infra/caddy:2.8-alpine
{"level":"info","ts":1722918322.7366016,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1722918322.7370393,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1722918322.7374763,"logger":"admin","msg":"admin endpoint started","address":"0.0.0.0:2019","enforce_origin":false,"origins":["//0.0.0.0:2019"]}
{"level":"warn","ts":1722918322.737484,"logger":"admin","msg":"admin endpoint on open interface; host checking disabled","address":"0.0.0.0:2019"}
{"level":"info","ts":1722918322.7377057,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1722918322.737711,"msg":"serving initial configuration"}
and then connecting via docker exec and running the CI steps manually:
docker exec -it caddy sh
/srv # cp -av /builds/operations/ingress-router/caddy/Caddyfile /etc/caddy/Caddyfile
'/builds/operations/ingress-router/caddy/Caddyfile' -> '/etc/caddy/Caddyfile'
/srv # cp -av /builds/operations/ingress-router/caddy/layer4-ssh-proxies.json /etc/caddy/layer4-ssh-proxies.json
'/builds/operations/atech-ingress-router/caddy/layer4-ssh-proxies.json' -> '/etc/caddy/layer4-ssh-proxies.json'
/srv # cd /etc/caddy/
/etc/caddy # ls -lah
total 16K
drwxr-xr-x 1 root root 76 Aug 6 04:01 .
drwxr-xr-x 1 root root 10 Aug 6 03:57 ..
-rw-r--r-- 1 1000 1000 945 Aug 5 06:22 Caddyfile
-rw-r--r-- 1 1000 1000 8.8K Aug 6 01:27 layer4-ssh-proxies.json
/etc/caddy # caddy version
/etc/caddy # caddy reload
2024/08/06 04:02:00.143 INFO using adjacent Caddyfile
2024/08/06 04:02:00.143 WARN No files matching import glob pattern {"pattern": "Caddyfile.d/*.caddyfile"}
2024/08/06 04:02:00.143 INFO adapted config to JSON {"adapter": "caddyfile"}
Full output of Gitlab CI failure.
Running with gitlab-runner 17.2.0 (6428c288)
on gitlab-ci-ldr-02 BawuXMRm, system ID: s_0975065499d9
Preparing the "docker" executor
00:05
Using Docker executor with image gitlab-reg.example.com/operations/ops-oci-images/infra/caddy:2.8-alpine ...
Authenticating with credentials from job payload (GitLab Registry)
Pulling docker image gitlab-reg.example.com/operations/ops-oci-images/infra/caddy:2.8-alpine ...
Using docker image sha256:bfec4a400ec0efa80c1ba5254dbd379f69a89e4a18ce4e2416ce9311a7816ddb for gitlab-reg.example.com/operations/ops-oci-images/infra/caddy:2.8-alpine with digest gitlab-reg.atech.host/operations/ops-oci-images/infra/caddy@sha256:1b3d4e6fd487227d248a71c0e524ec3b86bc5bdc5fb5b05b44029a0a55ee78c6 ...
Preparing environment
00:01
Running on runner-bawuxmrm-project-217-concurrent-1 via gitlab-ci-ldr-02...
Getting source from Git repository
00:01
Fetching changes with git depth set to 20...
Reinitialized existing Git repository in /builds/operations/ingress-router/.git/
Checking out 88cae7ef as detached HEAD (ref is main)...
Skipping Git submodules setup
Executing "step_script" stage of the job script
00:01
Using docker image sha256:bfec4a400ec0efa80c1ba5254dbd379f69a89e4a18ce4e2416ce9311a7816ddb for gitlab-reg.example.com/operations/ops-oci-images/infra/caddy:2.8-alpine with digest gitlab-reg.example.com/operations/ops-oci-images/infra/caddy@sha256:1b3d4e6fd487227d248a71c0e524ec3b86bc5bdc5fb5b05b44029a0a55ee78c6 ...
$ echo "Test configuration of Caddy L4 Proxy JSON."
$ cp -av /builds/operations/ingress-router/caddy/Caddyfile /etc/caddy/Caddyfile
$ cp -av /builds/operations/ingress-router/caddy/layer4-ssh-proxies.json /etc/caddy/layer4-ssh-proxies.json
'/builds/operations/ingress-router/caddy/layer4-ssh-proxies.json' -> '/etc/caddy/layer4-ssh-proxies.json'
$ cd /etc/caddy
$ ls -lah
total 16K
drwxr-xr-x 1 root root 60 Aug 6 03:05 .
drwxr-xr-x 1 root root 19 Aug 6 03:05 ..
-rw-rw-rw- 1 root root 945 Aug 6 02:49 Caddyfile
-rw-rw-rw- 1 root root 8.8K Aug 6 02:49 layer4-ssh-proxies.json
$ caddy version
$ caddy reload
{"level":"info","ts":1722913515.415652,"msg":"using adjacent Caddyfile"}
{"level":"warn","ts":1722913515.417704,"msg":"No files matching import glob pattern","pattern":"Caddyfile.d/*.caddyfile"}
{"level":"info","ts":1722913515.4183245,"msg":"adapted config to JSON","adapter":"caddyfile"}
Cleaning up project directory and file based variables
00:01
ERROR: Job failed: exit code 1
Custom docker image, as above.
Ubuntu 22.04 with Docker 24.0.7
Gitlab CI pipeline, as descibed above. The pipeline fails at caddy reload
inside the container image.
Dockerfile
RUN xcaddy build \
RUN apk add curl jq
admin 0.0.0.0:2019
log access-json {
format json
format filter {
resp_headers delete
log access-common {
time_format iso8601
header -server
header -x-generator
