Caddy reload in Docker?
sudo docker exec -it caddy-caddy-1 caddy reload gives me an error.
2026/10/09 18:57:19.125	ERROR	no config file to load
v2.11.7 h1:yj0Y4fYZGPkSvibBJ1sTWE33xC0fxztVyXEW5iIdUT4=
Docker compose at /mnt/data/Containers/Caddy. I have a Caddyfile in mnt/data/Containers/Caddy/conf. It seems to be working with my first entry in it, but I added a second entry and am getting that error when I try to reload it to apply.
Ubuntu 26.04.1 LTS, x86/x64, Docker compose
    image: caddy:latest
      - "443:443/udp"
      - ./conf:/etc/caddy
      - ./site:/srv
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
immich.michellehm.com {
    reverse_proxy 127.0.0.1:2283
cloud.michellehm.com {
        -Server
    reverse_proxy 127.0.0.1:11000
Container info:
Container ID Image Names Command Created Status Ports
ba25dea2f39b caddy:latest caddy-caddy-1 “caddy run --config …” 21 hours ago Up 21 hours 0.0.0.0:80->80/tcp, [::]:80->80/tcp, 0.0.0.0:443->443/tcp, [::]:443->443/tcp, 0.0.0.0:443->443/udp, [::]:443->443/udp, 2019/tcp
Okay I think I ‘fixed’ it, though I’m not really understanding why this works when the container name shows as caddy-caddy-1, but looking back at the Caddy docker install instructions I saw that to reload you should use:
sudo docker compose exec -w /etc/caddy caddy caddy reload
and not the command from the guide I was following elsewhere (can’t remember where I saw it)
That said, now that I have this ‘working’ - neither of these reverse proxies are working :confused:, I’m getting 502 Bad Gateway on both of them in the browser.
docker exec -it caddy-caddy-1 caddy reload —config /etc/caddy/Caddyfile
— are two hyphens. The editor here turns it into a dash.
Edit: adjust the container name to your container name
I think the 502s might be coming from the upstream addresses. Inside the Caddy container, 127.0.0.1 points to Caddy itself, not your other containers. If they’re on the same Docker network, try using their service names and internal ports instead. Otherwise, use an address Caddy can actually reach.
BreezeDelegate is right about the loopback issue. Also check that the upstream app listens on all interfaces inside its container, not only localhost; it can still fail even when Caddy uses the correct Docker service name and internal port. Keep both services on the same compose network, then reload with the compose exec command that worked.
