Caddy + Pterodactyl allocations API connection problem
I’m trying to set up Caddy as a reverse proxy for a Pterodactyl server (Panel + Wings) that is behind CGNAT, using an exit node.
The panel works fine at panel.danicdn.tech via HTTP reverse proxy to 10.0.0.2:80. Wings is running on 10.0.0.2:8080, and the allocations are on 0.0.0.0:25565. I want Wings to be accessible over HTTP (for the panel) and TCP (for game ports 25565-25999) through Caddy.
Currently, POST requests to Wings at https://wings.danicdn.tech:25565/up fail, and plain HTTP access also does not work. SFTP to the daemon (sftp://panel.danicdn.tech:2022) works fine via FileZilla. Node settings in Pterodactyl: SSL disabled, no proxy, maintenance mode disabled, daemon port 8080, SFTP port 2022.
journalctl -u caddy --no-pager | less +G shows a lot of logs, nothing related to the problem, just certificates being renovated
curl -vL http://wings.danicdn.tech:25565/up
Host wings.danicdn.tech:25565 was resolved.
IPv6: (none)
IPv4: 149.102.131.92
Trying 149.102.131.92:25565…
curl -1sLf ‘``https://dl.cloudsmith.io/public/caddy/stable/gpg.key’`` | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf ‘``https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’`` | sudo tee /etc/apt/sources.list.d/caddy-stable.list
chmod o+r /usr/share/keyrings/caddy-stable-archive-keyring.gpg
chmod o+r /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
Ubuntu 24.04.3 LTS in VPS, connected via Wireguard to Pterodactyl via http
systemctl start caddy
panel.danicdn.tech → 10.0.0.2
panel.danicdn.tech {
reverse_proxy 10.0.0.2:80
wings.danicdn.tech → 10.0.0.2 (HTTP interno)
wings.danicdn.tech {
reverse_proxy http://10.0.0.2:8080
Si Wings no soporta HTTPS correctamente, usa el esquema http:// explícitamente
Proxy TCP para rango de ports de Wings
:25565-25999 {
reverse_proxy 10.0.0.2:25565-25999
transport tcp
dokploy.danicdn.tech → 10.0.0.3
dokploy.danicdn.tech {
reverse_proxy 10.0.0.3:3000
status.danicdn.tech → localhost:3001
status.danicdn.tech {
reverse_proxy localhost:3001
