Caddy proxied traffic in vm appears to come from host's IP instead of original request's IP
Hello, I hope I’m not asking something that’s already answered somewhere, but I didn’t manage to figure it out with infos I found.
I am using caddy to proxy traffic to a virtual machine. In the vm, nginx handles the requests. The problem I have is that the vm identifies the requests as coming from the host’s IP, but I need the vm to get the original requests IP.
I use the following config:
(toVM {
    gzip
    proxy / https://myvm {
        insecure_skip_verify
mysub.domain.tld {
    import toVM
From my understanding the transparent preset should achieve my goal since it sets header_upstream X-Real-IP {remote} but somehow, when I check nginx logs in the vm, any request made appears to be coming from the host’s IP.
Did I misunderstand/misconfigure something?
Have you looked at https://caddyserver.com/docs/http.realip? It sounds like it does exactly what you are wanting.
Hey @Gorian thanks a lot for your answer. I’ve been reading and rereading the http.realip description, and my understanding of it, is that it would restore the IP from a header if caddy was behind a proxy. Did I understand right? Because my case is the opposite: caddy is the proxy, and nginx in the vm is getting the wrong IP address.
It looks something like this:
        user (IP: 11.222.333.444)
          | (request's IP is: 11.222.333.444)
          v
        host (IP: 192.168.xxx.xxx)
          | (request's IP is now: 192.168.xxx.xxx)
          v
   virtual machine => nginx gets host's IP: 192.168.xxx.xxx
and I would like something like this:
          v
          | (request's IP is still appearing to be: 11.222.333.444)
          v
   virtual machine => nginx gets user's IP: 11.222.333.444
I don’t know if that’s possible.
From your answer, I imagine that I could configure the VM’s nginx to restore the IP address from the request headers (the ones transmitted by caddy with the transparent preset).
But since the original problem I have is that fail2ban is identifying all requests as coming from the host’s IP, I doubt modifying nginx config would help since from my understanding fail2ban is before nginx.
So I’m looking for a solution to configure the host so it proxies request to the vm and make them appear as if they were coming from the user’s IP.
Not knowing if it’s possible to configure the host to redirect the IP like I described, and even less knowing how, I finally decided to configure nginx in the vm with ngx_http_realip_module plugin so it restores the original requests IP from the header. It was fairly simple to do.
Thanks @Gorian for putting me on the right track :slight_smile:
