Caddy Prometheus metrics and PHP-FPM
I have Prometheus metrics configured for my Caddyfile, and they are working great. Unfortunately, Caddy does not seem to aggregate http_* metrics for anything, even though there are multiple requests per second coming in. All the go_* and process_* metrics are correct.
No specific errors.
Binaries.
Debian 12.
No specific command.
No specific service config.
  auto_https off
:9200 {
  metrics
http://mydomain.com {
  root * /apps/web/public
  php_fastcgi unix//var/run/php/php-fpm.sock {
    index index.php
    capture_stderr
Output of the metrics endpoint. Note the lack of http_* metrics:
caddy@web-prod01:/home/cloud# curl localhost:2019/metrics
# HELP caddy_admin_http_requests_total Counter of requests made to the Admin API's HTTP endpoints.
# TYPE caddy_admin_http_requests_total counter
caddy_admin_http_requests_total{code="200",handler="load",method="POST",path="/load"} 2
# HELP caddy_reverse_proxy_upstreams_healthy Health status of reverse proxy upstreams.
# TYPE caddy_reverse_proxy_upstreams_healthy gauge
caddy_reverse_proxy_upstreams_healthy{upstream="unix//var/run/php/php-fpm.sock"} 1
# HELP go_build_info Build information about the main Go module.
# TYPE go_build_info gauge
go_build_info{checksum="",path="caddy",version="(devel)"} 1
# HELP go_gc_duration_seconds A summary of the pause duration of garbage collection cycles.
# TYPE go_gc_duration_seconds summary
go_gc_duration_seconds{quantile="0"} 8.3176e-05
Ideally what I want is to be able to gather requests per second, as well as average time of every request.
You need to read this page of the documentation
I did. And specifically this part:
My Caddy metrics endpoint has no caddy_http_request.
It also says:
So, where are the buckets for my handlers?
You missed this part
