Caddy Docker Image latest ( 2.4.5, 2, latest)
I mostly followed a guide on how to deploy a tool called Outline wiki. Please look in the end of this article for links to it
Basically first running
sudo docker network create reverseproxy-nw
and then
sudo docker-compose up -d
See below for my docker-compose file
Docker using docker-compose, on Debian 11 running on Google Cloud VM instnance e2-small (2 vCPUs, 2 GB memory)
version: "3"
reverseproxy-nw:
external: true
image: caddy:latest
- ./data:/data
- 443:443
- reverseproxy-nw
kb.mcgilleus.ca {
reverse_proxy outline:443 {
kbdata.mcgilleus.ca {
reverse_proxy outline_minio:9000 {
3. The problem Iβm having:
I cannot access the website as shown in the guide above.
I have my DNS A records set like this:
A kbdata.mcgilleus..ca 35.203.58.7 TTL:3600
A kb.mcgilleus.ca 35.203.58.7 TTL:3600
a quick curl -v kbdata.mcgilleus.ca gives me this:
click here to expand
* Trying 35.203.58.7:443...
* Connected to kbdata.mcgilleus.ca (35.203.58.7) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: none
* subject: CN=kbdata.mcgilleus.ca
* start date: Oct 19 03:25:53 2021 GMT
* expire date: Jan 17 03:25:52 2022 GMT
* subjectAltName: host "kbdata.mcgilleus.ca" matched cert's "kbdata.mcgilleus.ca"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x562d529739a0)
> GET / HTTP/2
> Host: kbdata.mcgilleus.ca
> user-agent: curl/7.79.1
> accept: */*
< HTTP/2 403
< accept-ranges: bytes
< content-security-policy: block-all-mixed-content
< content-type: application/xml
< date: Tue, 19 Oct 2021 04:59:44 GMT
< server: Caddy
< server: MinIO
< strict-transport-security: max-age=31536000; includeSubDomains
< vary: Origin
< vary: Accept-Encoding
< x-amz-request-id: 16AF55DA0F932A2C
< x-xss-protection: 1; mode=block
< content-length: 226
<?xml version="1.0" encoding="UTF-8"?>
* Connection #0 to host kbdata.mcgilleus.ca left intact
<Error><Code>AccessDenied</Code><Message>Access Denied.</Message><Resource>/</Resource><RequestId>16AF55DA0F932A2C</RequestId><HostId>cc3b7dcd-fa3f-4424-a9b5-6ece2213f462</HostId></Error>%
Clearly there is an issue with accessing and permissions, or at leasy I think so.
(click here to expand) Here is my caddy container logs
aliotique@lucario:~/caddy$ sudo docker-compose logs caddy
Attaching to caddy
caddy | {"level":"info","ts":1634619908.281191,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | 2021/10/19 05:05:08 [WARNING] Unnecessary header_up ('X-Forwarded-Proto' field): the reverse proxy's default behavior is to pass headers to the upstream
caddy | {"level":"warn","ts":1634619908.2844605,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy | {"level":"info","ts":1634619908.2868974,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
caddy | {"level":"info","ts":1634619908.2871525,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1634619908.2872167,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"debug","ts":1634619908.2879457,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
caddy | {"level":"debug","ts":1634619908.2880538,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
caddy | {"level":"info","ts":1634619908.2881026,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["kbdata.mcgilleus.ca","kb.mcgilleus.ca"]}
caddy | {"level":"info","ts":1634619908.2887173,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00033a7e0"}
caddy | {"level":"debug","ts":1634619908.2900875,"logger":"tls","msg":"loading managed certificate","domain":"kbdata.mcgilleus.ca","expiration":1642389952,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
caddy | {"level":"debug","ts":1634619908.2911036,"logger":"tls.cache","msg":"added certificate to cache","subjects":["kbdata.mcgilleus.ca"],"expiration":1642389952,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"f21193e1cec0b183b4cfe13270ef52e121beb80402b1bbfc58c2990da70e57a9"}
caddy | {"level":"info","ts":1634619908.2901967,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"debug","ts":1634619908.2931392,"logger":"tls","msg":"loading managed certificate","domain":"kb.mcgilleus.ca","expiration":1642389943,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
caddy | {"level":"debug","ts":1634619908.2935917,"logger":"tls.cache","msg":"added certificate to cache","subjects":["kb.mcgilleus.ca"],"expiration":1642389943,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"8960355d3dc9ad25c043dc528ef03a85fb86908c40f36228071dde74422157b1"}
caddy | {"level":"info","ts":1634619908.293843,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1634619908.293937,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1634619908.2949057,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"debug","ts":1634619920.6256568,"logger":"tls.handshake","msg":"choosing certificate","identifier":"kbdata.mcgilleus.ca","num_choices":1}
caddy | {"level":"debug","ts":1634619920.6257157,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"kbdata.mcgilleus.ca","subjects":["kbdata.mcgilleus.ca"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"f21193e1cec0b183b4cfe13270ef52e121beb80402b1bbfc58c2990da70e57a9"}
caddy | {"level":"debug","ts":1634619920.625727,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["kbdata.mcgilleus.ca"],"managed":true,"expiration":1642389952,"hash":"f21193e1cec0b183b4cfe13270ef52e121beb80402b1bbfc58c2990da70e57a9"}
caddy | {"level":"debug","ts":1634619920.6446133,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"outline_minio:9000","request":{"remote_addr":"24.201.191.39:48298","proto":"HTTP/2.0","method":"GET","host":"kbdata.mcgilleus.ca","uri":"/","headers":{"Sec-Fetch-User":["?1"],"X-Forwarded-For":["24.201.191.39"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Fetch-Dest":["document"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-Proto":["https"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:93.0) Gecko/20100101 Firefox/93.0"],"Te":["trailers"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Dnt":["1"],"Cache-Control":["max-age=0"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["none"],"X-Forwarded-Host":["kbdata.mcgilleus.ca"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"kbdata.mcgilleus.ca"}},"headers":{"Content-Type":["text/html; charset=utf-8"],"Location":["http://kbdata.mcgilleus.ca:40077"],"Vary":["Origin"],"Date":["Tue, 19 Oct 2021 05:05:20 GMT"],"Content-Length":["68"]},"status":307}
caddy | {"level":"debug","ts":1634619922.7535079,"logger":"tls.handshake","msg":"choosing certificate","identifier":"kbdata.mcgilleus.ca","num_choices":1}
caddy | {"level":"debug","ts":1634619922.753849,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"kbdata.mcgilleus.ca","subjects":["kbdata.mcgilleus.ca"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"f21193e1cec0b183b4cfe13270ef52e121beb80402b1bbfc58c2990da70e57a9"}
caddy | {"level":"debug","ts":1634619922.7539346,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["kbdata.mcgilleus.ca"],"managed":true,"expiration":1642389952,"hash":"f21193e1cec0b183b4cfe13270ef52e121beb80402b1bbfc58c2990da70e57a9"}
caddy | {"level":"debug","ts":1634619922.7740898,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"outline_minio:9000","request":{"remote_addr":"24.201.191.39:48300","proto":"HTTP/2.0","method":"GET","host":"kbdata.mcgilleus.ca","uri":"/","headers":{"User-Agent":["curl/7.79.1"],"Accept":["*/*"],"X-Forwarded-For":["24.201.191.39"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["kbdata.mcgilleus.ca"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"kbdata.mcgilleus.ca"}},"headers":{"X-Amz-Request-Id":["16AF5628BFAF8962"],"X-Content-Type-Options":["nosniff"],"X-Xss-Protection":["1; mode=block"],"Strict-Transport-Security":["max-age=31536000; includeSubDomains"],"Content-Length":["226"],"Content-Security-Policy":["block-all-mixed-content"],"Content-Type":["application/xml"],"Server":["MinIO"],"Vary":["Origin","Accept-Encoding"],"Date":["Tue, 19 Oct 2021 05:05:22 GMT"],"Accept-Ranges":["bytes"]},"status":403}
(click here to expand) Here is my main app (outline) logs:
aliotique@lucario:~/outline$ sudo docker-compose logs outline
Attaching to outline
outline | yarn run v1.22.5
outline | $ sequelize db:migrate --env=production-ssl-disabled
outline |
outline | Sequelize CLI [Node: 14.17.6, CLI: 6.2.0, ORM: 6.3.5]
outline |
outline | Loaded configuration file "server/config/database.json".
outline | Using environment "production-ssl-disabled".
outline |
outline | ERROR: connect ECONNREFUSED 172.19.0.2:5432
outline |
outline | error Command failed with exit code 1.
outline | info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
outline |
outline |
outline | == 20160619080644-initial: migrating =======
outline | == 20160619080644-initial: migrated (0.051s)
outline |
outline | == 20160622043741-add-parent-document: migrating =======
outline | == 20160622043741-add-parent-document: migrated (0.008s)
outline |
outline | == 20160626063409-add-indexes: migrating =======
outline | == 20160626063409-add-indexes: migrated (0.034s)
outline |
outline | == 20160626175224-add-revisions: migrating =======
outline | == 20160626175224-add-revisions: migrated (0.018s)
outline |
outline | == 20160711071958-search-index: migrating =======
outline | == 20160711071958-search-index: migrated (0.013s)
outline |
outline | == 20160726061511-atlas-creator: migrating =======
outline | == 20160726061511-atlas-creator: migrated (0.007s)
outline |
outline | == 20160812145029-document-atlas-soft-delete: migrating =======
outline | == 20160812145029-document-atlas-soft-delete: migrated (0.008s)
outline |
outline | == 20160814083127-paranoia-indeces: migrating =======
outline | == 20160814083127-paranoia-indeces: migrated (0.041s)
outline |
outline | == 20160814095336-add-document-createdById: migrating =======
outline | == 20160814095336-add-document-createdById: migrated (0.007s)
outline |
outline | == 20160814111419-add-document-collaboratorIds: migrating =======
outline | == 20160814111419-add-document-collaboratorIds: migrated (0.007s)
outline |
outline | == 20160815142720-app-collection-urlId: migrating =======
outline | == 20160815142720-app-collection-urlId: migrated (0.009s)
outline |
outline | == 20160816082738-add-revision-index: migrating =======
outline | == 20160816082738-add-revision-index: migrated (0.009s)
outline |
outline | == 20160824061730-add-apikeys: migrating =======
outline | == 20160824061730-add-apikeys: migrated (0.014s)
outline |
outline | == 20160824062457-add-apikey-indeces: migrating =======
outline | == 20160824062457-add-apikey-indeces: migrated (0.012s)
outline |
outline | == 20160911230444-user-optional-slack-id: migrating =======
outline | == 20160911230444-user-optional-slack-id: migrated (0.034s)
outline |
outline | == 20160911232911-user-unique-fields: migrating =======
outline | == 20160911232911-user-unique-fields: migrated (0.044s)
outline |
outline | == 20160911234928-user-password: migrating =======
outline | == 20160911234928-user-password: migrated (0.007s)
outline |
outline | == 20170603185012-add-collection-documentStructure-migration: migrating =======
outline | == 20170603185012-add-collection-documentStructure-migration: migrated (0.009s)
outline |
outline | == 20170604052346-add-views: migrating =======
outline | == 20170604052346-add-views: migrated (0.015s)
outline |
outline | == 20170604052347-add-stars: migrating =======
outline | == 20170604052347-add-stars: migrated (0.014s)
outline |
outline | == 20170712055148-non-unique-email: migrating =======
outline | == 20170712055148-non-unique-email: migrated (0.009s)
outline |
outline | == 20170712072234-uniq-slack-id: migrating =======
outline | == 20170712072234-uniq-slack-id: migrated (0.012s)
outline |
outline | == 20170729215619-emoji: migrating =======
outline | == 20170729215619-emoji: migrated (0.007s)
outline |
outline | == 20170827182423-improve-references: migrating =======
outline | == 20170827182423-improve-references: migrated (0.016s)
outline |
outline | == 20170904202454-allow-null-username: migrating =======
outline | == 20170904202454-allow-null-username: migrated (0.007s)
outline |
outline | == 20171010042938-add-event: migrating =======
outline | == 20171010042938-add-event: migrated (0.014s)
outline |
outline | == 20171016012353-remove-collection-navigationtree: migrating =======
outline | == 20171016012353-remove-collection-navigationtree: migrated (0.007s)
outline |
outline | == 20171017055026-remove-document-html: migrating =======
outline | == 20171017055026-remove-document-html: migrated (0.010s)
outline |
outline | == 20171019071915-user-avatar-url: migrating =======
outline | == 20171019071915-user-avatar-url: migrated (0.007s)
outline |
outline | == 20171023064220-collection-color: migrating =======
outline | == 20171023064220-collection-color: migrated (0.007s)
outline |
outline | == 20171218043717-add-authentications: migrating =======
outline | == 20171218043717-add-authentications: migrated (0.014s)
outline |
outline | == 20171225143838-set-admins: migrating =======
outline | == 20171225143838-set-admins: migrated (0.009s)
outline |
outline | == 20180115021837-add-drafts: migrating =======
outline | == 20180115021837-add-drafts: migrated (0.013s)
outline |
outline | == 20180212033504-add-integrations: migrating =======
outline | == 20180212033504-add-integrations: migrated (0.015s)
outline |
outline | == 20180225203847-document-pinning: migrating =======
outline | == 20180225203847-document-pinning: migrated (0.007s)
outline |
outline | == 20180303193036-suspended-users: migrating =======
outline | == 20180303193036-suspended-users: migrated (0.009s)
outline |
outline | == 20180324214403-serializer-upgrade: migrating =======
outline | == 20180324214403-serializer-upgrade: migrated (0.006s)
outline |
outline | == 20180513041057-add-share-links: migrating =======
outline | == 20180513041057-add-share-links: migrated (0.011s)
outline |
outline | == 20180528233909-google-auth: migrating =======
outline | == 20180528233909-google-auth: migrated (0.039s)
outline |
outline | == 20180528233910-rename-serviceid: migrating =======
outline | == 20180528233910-rename-serviceid: migrated (0.030s)
outline |
outline | == 20180604182823-user-tracking: migrating =======
outline | == 20180604182823-user-tracking: migrated (0.011s)
outline |
outline | == 20180604191743-revoke-share-links: migrating =======
outline | == 20180604191743-revoke-share-links: migrated (0.009s)
outline |
outline | == 20180707220121-more-soft-delete: migrating =======
outline | == 20180707220121-more-soft-delete: migrated (0.008s)
outline |
outline | == 20180707231201-remove-passwords: migrating =======
outline | == 20180707231201-remove-passwords: migrated (0.010s)
outline |
outline | == 20180708231200-serviceid-null: migrating =======
outline | == 20180708231200-serviceid-null: migrated (0.009s)
outline |
outline | == 20180808061353-cleanup: migrating =======
outline | == 20180808061353-cleanup: migrated (0.026s)
outline |
outline | == 20180819054252-disable-sharing: migrating =======
outline | == 20180819054252-disable-sharing: migrated (0.008s)
outline |
outline | == 20181031015046-add-subdomain-to-team: migrating =======
outline | == 20181031015046-add-subdomain-to-team: migrated (0.015s)
outline |
outline | == 20181124000438-add-notifications: migrating =======
outline | == 20181124000438-add-notifications: migrated (0.025s)
outline |
outline | == 20181215192422-document-embeds: migrating =======
outline | == 20181215192422-document-embeds: migrated (0.007s)
outline |
outline | == 20181227001547-collection-permissions: migrating =======
outline | == 20181227001547-collection-permissions: migrated (0.015s)
outline |
outline | == 20190404035736-add-archive: migrating =======
outline | == 20190404035736-add-archive: migrated (0.007s)
outline |
outline | == 20190423051708-add-search-indexes: migrating =======
outline | == 20190423051708-add-search-indexes: migrated (0.017s)
outline |
outline | == 20190606035733-events: migrating =======
outline | == 20190606035733-events: migrated (0.025s)
outline |
outline | == 20190704070630-welcome-docs: migrating =======
outline | == 20190704070630-welcome-docs: migrated (0.009s)
outline |
outline | == 20190706213213-backlinks: migrating =======
outline | == 20190706213213-backlinks: migrated (0.020s)
outline |
outline | == 20190811231511-maintainers: migrating =======
outline | == 20190811231511-maintainers: migrated (0.014s)
outline |
outline | == 20191118023010-cascade-delete: migrating =======
outline | == 20191118023010-cascade-delete: migrated (0.010s)
outline |
outline | == 20191119023010-cascade-backlinks: migrating =======
outline | == 20191119023010-cascade-backlinks: migrated (0.010s)
outline |
outline | == 20191119023011-cascade-parent-documents: migrating =======
outline | == 20191119023011-cascade-parent-documents: migrated (0.010s)
outline |
outline | == 20191119023012-cascade-shares: migrating =======
outline | == 20191119023012-cascade-shares: migrated (0.010s)
outline |
outline | == 20191119023013-cascade-backlinks2: migrating =======
outline | == 20191119023013-cascade-backlinks2: migrated (0.010s)
outline |
outline | == 20191121035144-guest-invite: migrating =======
outline | == 20191121035144-guest-invite: migrated (0.011s)
outline |
outline | == 20191211044318-create-groups: migrating =======
outline | == 20191211044318-create-groups: migrated (0.021s)
outline |
outline | == 20191211044319-create-group-users: migrating =======
outline | == 20191211044319-create-group-users: migrated (0.021s)
outline |
outline | == 20191228031525-edit-presence: migrating =======
outline | == 20191228031525-edit-presence: migrated (0.007s)
outline |
outline | == 20200104233831-attachments: migrating =======
outline | == 20200104233831-attachments: migrated (0.020s)
outline |
outline | == 20200122083721-create-collection-groups: migrating =======
outline | == 20200122083721-create-collection-groups: migrated (0.023s)
outline |
outline | == 20200316040755-document-editor-version: migrating =======
outline | == 20200316040755-document-editor-version: migrated (0.010s)
outline |
outline | == 20200328175012-cascade-delete: migrating =======
outline | == 20200328175012-cascade-delete: migrated (0.011s)
outline |
outline | == 20200330053639-document-version: migrating =======
outline | == 20200330053639-document-version: migrated (0.010s)
outline |
outline | == 20200519032353-text-backup: migrating =======
outline | == 20200519032353-text-backup: migrated (0.009s)
outline |
outline | == 20200522054958-collection-icon: migrating =======
outline | == 20200522054958-collection-icon: migrated (0.007s)
outline |
outline | == 20200723055414-add-published-to-shares: migrating =======
outline | == 20200723055414-add-published-to-shares: migrated (0.008s)
outline |
outline | == 20200727051157-add-templates: migrating =======
outline | == 20200727051157-add-templates: migrated (0.010s)
outline |
outline | == 20200812170227-remove-collection-type: migrating =======
outline | == 20200812170227-remove-collection-type: migrated (0.008s)
outline |
outline | == 20200915010511-create-search-queries: migrating =======
outline | == 20200915010511-create-search-queries: migrated (0.020s)
outline |
outline | == 20200926204620-add-missing-indexes: migrating =======
outline | == 20200926204620-add-missing-indexes: migrated (0.022s)
outline |
outline | == 20201028043021-reverse-document-id-index: migrating =======
outline | == 20201028043021-reverse-document-id-index: migrated (0.010s)
outline |
outline | == 20201103050534-custom-domains: migrating =======
outline | == 20201103050534-custom-domains: migrated (0.011s)
outline |
outline | == 20201106122752-i18n: migrating =======
outline | == 20201106122752-i18n: migrated (0.007s)
outline |
outline | == 20201206210619-update-attachment-cols: migrating =======
outline | == 20201206210619-update-attachment-cols: migrated (0.008s)
outline |
outline | == 20201211080408-attachment-no-cascade: migrating =======
outline | == 20201211080408-attachment-no-cascade: migrated (0.008s)
outline |
outline | == 20201230031607-collection-sort: migrating =======
outline | == 20201230031607-collection-sort: migrated (0.007s)
outline |
outline | == 20210110143902-collection-rename-creator-id: migrating =======
outline | == 20210110143902-collection-rename-creator-id: migrated (0.017s)
outline |
outline | == 20210208062816-disable-collection-sharing: migrating =======
outline | == 20210208062816-disable-collection-sharing: migrated (0.008s)
outline |
outline | == 20210218111237-add-collection-index: migrating =======
outline | == 20210218111237-add-collection-index: migrated (0.009s)
outline |
outline | == 20210226232041-authentication-providers: migrating =======
outline | == 20210226232041-authentication-providers: migrated (0.039s)
outline |
outline | == 20210310051804-passport: migrating =======
outline | == 20210310051804-passport: migrated (0.009s)
outline |
outline | == 20210314173941-isViewer: migrating =======
outline | == 20210314173941-isViewer: migrated (0.007s)
outline |
outline | == 20210327005406-read-only-collections: migrating =======
outline | == 20210327005406-read-only-collections: migrated (0.010s)
outline |
outline | == 20210418053152-share-last-viewed: migrating =======
outline | == 20210418053152-share-last-viewed: migrated (0.007s)
outline |
outline | == 20210426055334-nested-document-sharing: migrating =======
outline | == 20210426055334-nested-document-sharing: migrated (0.007s)
outline |
outline | == 20210430024222-marketing-tracking: migrating =======
outline | == 20210430024222-marketing-tracking: migrated (0.006s)
outline |
outline | == 20210716064654-introduce-previousTitles: migrating =======
outline | == 20210716064654-introduce-previousTitles: migrated (0.008s)
outline |
outline | == 20210716071454-search-index-previousTitles: migrating =======
outline | == 20210716071454-search-index-previousTitles: migrated (0.009s)
outline |
outline | == 20210716162923-events-indexes: migrating =======
outline | == 20210716162923-events-indexes: migrated (0.012s)
outline |
outline | == 20210730042450-remove-unused-indexes: migrating =======
outline | == 20210730042450-remove-unused-indexes: migrated (0.016s)
outline |
outline | == 20210730044247-remove-backup-column: migrating =======
outline | == 20210730044247-remove-backup-column: migrated (0.008s)
outline |
outline | == 20210730210120-add-fileOperations: migrating =======
outline | == 20210730210120-add-fileOperations: migrated (0.075s)
I thought it could have been an issue with directory permissions, so I ran
sudo chmod -R 755 caddy/
sudo chmod -R 755 outline/
I tried redoing everything and changing every single variable in my Outline config files, but it all leads to me suspecting my caddy configuration to be the problem. I tried it on a fresh VM and the errors persist.
Apologies for my lack of experience. Any help is really, really apreciated!
> Deploying Outline with Docker and Caddy
Outline wiki website
