Caddy Plugin / Binary with Docker
Hello. I was wondering how to get a Caddy plugin (specifically cloudflare) when deploying Caddyv2 with docker? Specifically because I’m using cloudflare origin ca certificates right now on my website but any browser says its not a trust-worthy certificate since it’s self-certified. However, I realized if I use let’s encrypt with dns-acme, it should provide a trustworthy certificate. I’m not sure it’s listed on the docs / I’m not understanding the docs properly. Basically, my question is is it possible to use a caddy+cloudflare with docker compose? If so, can someone explain to me how to achieve this with docker compose?
N/A
Caddy v2.6.4 through docker compose
OS Ubuntu 22.04
Docker Compose
docker compose -f caddy-compose.yml up -d
version: "3.7"
    image: caddy:latest
      - "443:443/udp"
      - $PWD/site:/srv
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
    external: true
  caddy_config:
N/A
https://hub.docker.com/_/caddy
The docs on https://hub.docker.com/_/caddy explain how to write a Dockerfile which builds Caddy with the plugins you need. Replace image: in your docker-compose.yml with build: pointing to your Dockerfile.
I don’t have a docker file however. I have a docker-compose.yml. Is there any way to do it with a compose? Sorry, is there a way you could througly explain how to do the docker file + docker compose setup? I’m decently new to docker so I’m not sure I understand what you’re saying.
It’s not one or the other, you need both files. The docker-compose.yml file is a definition of all the services you want to run (it’s a replacement for running a bunch of docker run commands in sequence), and a Dockerfile is instructions to build a single image. They serve separate purposes.
I suggest you do some more reading about how Docker works, look at Docker official documentation, etc.
