Caddy overwrites Content-Type headers from upstream
I’m trying to setup M/Monit inside a docker-compose configuration together with Caddy.
When i set everything up, the Content-Type for application files (.js, .css) gets set to text/plain.
I’d contacted M/Monit to confirm if it was M/Monit doing that or not, and they’d said that M/Monit sends correct headers, they’d tested it on Nginx and Apache and everything worked, so it must be Caddy.
As you can see the request succeeds, but because of the combination of X-Content-Type-Options nosniff and Content-Type text/plain the console returns a MIME-type mismatch error.
path: {domain}/lib/js/application.js
HTTP/2 200
accept-ranges: bytes
alt-svc: h3=":443"; ma=2592000
content-security-policy: frame-ancestors 'self'
content-type: text/plain
date: Fri, 21 Mar 2025 09:24:07 GMT
etag: "1738060188-461"
last-modified: Tue, 28 Jan 2025 10:29:48 GMT
permissions-policy: geolocation=(),microphone=()
referrer-policy: same-origin
server: Caddy
server: mmonit/4.3.4
strict-transport-security: max-age=63072000; includeSubDomains
x-content-type-options: nosniff
x-frame-options: SAMEORIGIN
x-xss-protection: 1; mode=block
content-length: 461
X-Firefox-Spdy: h2
there are no errors or logs since the request succeeds with 200 as far as Caddy is concerned
Dockerfile
FROM caddy:latest
Linux 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Docker version 26.1.3, build 26.1.3-0ubuntu1~24.04.1
docker-compose version 1.29.2, build unknown
docker-compose --env_file ./.env up
docker-compose.yml
    build:
      context: "${CADDY_BIN}"
    container_name: "${COMPOSE_PROJECT_NAME}_caddy"
    restart: "unless-stopped"
    depends_on:
      - synapse
      - keycloak
      - "${HOST_MACHINE_UNSECURE_HOST_PORT}:80"
      - "${HOST_MACHINE_SECURE_HOST_PORT}:443"
      - 2019:2019
      - ${CADDY_CONFIG}:/etc/caddy/Caddyfile
      - ${CADDY_LOG_DIR}:/var/log/caddy
      - "./data/caddy/:/caddydata:rw"
      DOMAIN_NAME: ${DOMAIN_NAME}
      ALLOWED_IP: ${ALLOWED_IP}
      XDG_DATA_HOME: "/caddydata"
    extra_hosts:
      - "host.docker.internal:host-gateway"
  keycloak:
    user: "0:1001"
    build:
      context: "${KC_BIN}"
    container_name: "${COMPOSE_PROJECT_NAME}_keycloak"
    depends_on:
      - kc-db
    expose:
      - 8080
      - 8448
    healthcheck:
      test: ["CMD", "curl", "-f", "http://localhost:8080/health/ready"]
      interval: 15s
      timeout: 2s
      retries: 15
      - "./config/certs/kc.${DOMAIN_NAME}:/certs"
      KC_BOOTSTRAP_ADMIN_USERNAME: "${KC_USERNAME}"
      KC_BOOTSTRAP_ADMIN_PASSWORD: "${KC_PASSWORD}"
      KC_HOSTNAME: "kc.${DOMAIN_NAME}"
      KC_HOSTNAME_PORT: "${KC_HTTP_PORT}"
      KC_HOSTNAME_STRICT_BACKCHANNEL: "true"
      KC_HEALTH_ENABLED: "true"
      KC_LOG_LEVEL: info
      KC_HTTPS_CERTIFICATE_FILE: "/certs/kc.${DOMAIN_NAME}.crt"
      KC_HTTPS_CERTIFICATE_KEY_FILE: "/certs/kc.${DOMAIN_NAME}.key"
      POSTGRES_PASSWORD: "${POSTGRES_PASSWORD}"
      POSTGRES_USER: "${KC_POSTGRES_USER}"
      POSTGRES_DB: "${KC_POSTGRES_DATABASE}"
    command: ["start-dev", "--http-port", "${KC_HTTP_PORT}", "--https-port", "${KC_HTTPS_PORT}"]
  coturn:
    user: "0:1001"
    build:
      network: host
      context: "${COTURN_BIN}"
    container_name: "${COMPOSE_PROJECT_NAME}_coturn"
      - "${COTURN_CONFIG}:/etc/turnserver.conf:ro"
      - "${COTURN_DATA}:/srv/coturn"
      - "./config/certs/turn.${DOMAIN_NAME}/turn.${DOMAIN_NAME}.key:/etc/ssl/private/turnkey.key:ro"
      - "./config/certs/turn.${DOMAIN_NAME}/turn.${DOMAIN_NAME}.crt:/etc/ssl/certs/turncert.crt:ro"
      COTURN_USERNAME: ${COTURN_USER}
      COTURN_PASSWORD: ${COTURN_PASSWORD}
    network_mode: host
  synapse:
    build:
      context: "${SYNAPSE_BIN}"
    container_name: "${COMPOSE_PROJECT_NAME}_synapse"
    expose:
      - 8008
    depends_on:
      - syn-db
      - keycloak
      - coturn
      - ${SYNAPSE_DATA}:/data:rw
      POSTGRES_PASSWORD: "${SYNAPSE_POSTGRES_PASSWORD}"
      POSTGRES_USER: "${SYNAPSE_POSTGRES_USER}"
      POSTGRES_DATABASE: "${SYNAPSE_POSTGRES_DATABASE}"
      SYNAPSE_SERVER_NAME: "${SYNAPSE_SERVER_NAME}"
      SYNAPSE_REPORT_STATS: "yes"
      #SYNAPSE_HTTP_PORT: 8008
      #SYNAPSE_CONFIG_DIR: /data
      #SYNAPSE_CONFIG_PATH: /data/homeserver.yaml
      #SYNAPSE_DATA_DIR: /data
      SYNAPSE_VOIP_TURN_MAIN_URL: "stun:turn.${DOMAIN_NAME}:5349"
      SYNAPSE_VOIP_TURN_USERNAME: ${COTURN_USER}
      SYNAPSE_VOIP_TURN_PASSWORD: ${COTURN_PASSWORD}
    extra_hosts:
  syn-db:
    image: postgres:latest
    container_name: "${COMPOSE_PROJECT_NAME}_${DATABASE}-synapse"
    expose:
      - 5432
      - "${SYNAPSE_POSTGRES_INITDB_DIR}:/docker-entrypoint-initdb.d"
      - "${SYNAPSE_POSTGRES_DATA_DIR}:/var/lib/postgres/"
      - "${SYNAPSE_POSTGRES_LOG_DIR}:/var/log/postgres/"
      POSTGRES_DB: "${SYNAPSE_POSTGRES_DATABASE}"
      POSTGRES_INITDB_ARGS: "--encoding=UTF-8 --lc-collate=C --lc-ctype=C"
        #healthcheck:
        #  test: ["CMD-SHELL", "pg_isready", "-U", "${SYNAPSE_POSTGRES_USER}"]
        #  interval: 1s
        #  timeout: 5s
        #  retries: 10
  kc-db:
    container_name: "${COMPOSE_PROJECT_NAME}_${DATABASE}-kc"
    expose:
      - 5432
      - "${KC_POSTGRES_INITDB_DIR}:/docker-entrypoint-initdb.d"
      - "${KC_POSTGRES_DATA_DIR}:/var/lib/postgres/"
      - "${KC_POSTGRES_LOG_DIR}:/var/log/postgres/"
        #healthcheck:
        #  test: ["CMD-SHELL", "pg_isready", "-U", "${KC_POSTGRES_USER}"]
        #  interval: 1s
        #  timeout: 5s
        #  retries: 10
  mmonit:
    image: jchonig/mmonit:4.3.4
    container_name: m_monit
    hostname: m_monit
  #  log_driver: "syslog"
  #  log_opt:
  #    syslog-tag: monit
     - ./monit.conf.d:/opt/mmonit-4.3.4/conf
     - /srv:/hostsrv:ro
     - /data:/data:ro
     - /cache:/cache:ro
     - /root:/hostroot:ro
     - /archive:/archive:ro
     - /backups:/backups:ro
    cap_add:
     - SYS_PTRACE
    security_opt:
     - apparmor:unconfined
    expose:
     - 8080
    depends_on:
      - monit
  monit:
    user: "911"
    image: maltyxx/monit:latest
    container_name: monit
    hostname: monit
      - ./monit.conf.d/monitrc:/etc/monitrc
    expose:
      - 2812
{$DOMAIN_NAME} {
        root * {$DOCUMENT_ROOT}
        encode zstd gzip
        header /* {
                # Require HTTPS for subdomains, too
                # Disable MIME type sniffing
                # Don't allow embedding in other sites
                X-Frame-Options sameorigin
                # Only send the origin to other sites
                Referrer-Policy strict-origin-when-cross-origin
                # As strict as possible without breaking the site
                # Content-Security-Policy "default-src https:; font-src https: data:; img-src https: data: 'self' about:; script-src 'unsafe-inline' https: data:; style-src 'unsafe-inline' https:; connect-src https: data: 'self'"
                # Disable powerful features we don't need
                Permissions-Policy "geolocation=(), camera=(), microphone=() interest-cohort=()"
        respond /.git/* "Access denied" 403 {
                close
        header /.well-known/matrix/server {
                Content-Type application/json
        respond /.well-known/matrix/server 200 {
                body {"m.server":"matrix.localhost:443"}
                close
        header /.well-known/matrix/client {
        respond /.well-known/matrix/client 200 {
                body {"m.homeserver":{"base_url":"https://matrix.localhost"}}
                close
matrix.{$DOMAIN_NAME} {
        # @blocked not client_ip {$ALLOWED_IP} # add more, space separated
        # respond @blocked "Access Denied {client_ip}" 403
        @site {
                path *
                not path .git
        reverse_proxy @site synapse:8008 {
                        read_buffer 300KiB
                        write_buffer 300KiB
                        dial_timeout 30s
                        read_timeout 60s
                        write_timeout 60s
                flush_interval 10s
                request_buffers 16MB
                response_buffers 16MB
                stream_timeout 120s
                stream_close_delay 30s
kc.{$DOMAIN_NAME} {
        @site {
                path *
                not path .git
        reverse_proxy @site keycloak:8448 {
                        read_buffer 300KiB
                        write_buffer 300KiB
                        dial_timeout 30s
                        read_timeout 60s
                        write_timeout 60s
                        tls_server_name kc.{$DOMAIN_NAME}
                flush_interval 10s
                stream_timeout 120s
turn.{$DOMAIN_NAME} {
        @site {
                path *
                not path .git
        reverse_proxy @site coturn:5349 {
                        read_buffer 300KiB
                        write_buffer 300KiB
                        dial_timeout 30s
                        read_timeout 60s
                        write_timeout 60s
                        tls_server_name turn.{$DOMAIN_NAME}
                flush_interval 10s
                stream_timeout 120s
monitor.{$DOMAIN_NAME} {
        @site {
                path *
                not path .git
        reverse_proxy @site mmonit:8080 {
                        read_buffer 300KiB
                        write_buffer 300KiB
                        dial_timeout 30s
                        read_timeout 60s
                        write_timeout 60s
                flush_interval 10s
                stream_timeout 120s
This might be a longer response than necessary, so if you just want to see a possible solution, scroll to the end of my post :slightly_smiling_face:
I don’t believe Caddy would mess with proxied Content-Type headers.
For example:
Caddyfile:
	http_port 8080
:8080 {
	reverse_proxy https://www.w3schools.com {
		header_up Host www.w3schools.com
Run Caddy:
$ caddy run --config Caddyfile
Check headers:
## JavaScript
$ curl -sI https://www.w3schools.com/lib/common-deps.js | grep -iE '^content-type'
content-type: application/javascript
$ curl -sI http://localhost:8080/lib/common-deps.js | grep -iE '^content-type'
Content-Type: application/javascript
## CSS
$ curl -sI https://www.w3schools.com/lib/w3schools32.css | grep -iE '^content-type'
content-type: text/css
$ curl -sI http://localhost:8080/lib/w3schools32.css | grep -iE '^content-type'
Content-Type: text/css
As you can see, the proxied data retains the original Content-Type.
Instead of relying on what Monit folks say, I’d check it myself. Instead of running:
curl -I {domain}/lib/js/application.js
try talking directly to Monit:
curl -I {monit}:8080/lib/js/application.js
and see what Monit actually returns.
If needed, you can enforce the Content-Type header in Caddy. In fact, to mess it up on purpose, I’d have to explicitly override it:
	http_port 8080
:8080 {
		header_down -Content-Type
	@css path *.css
	header @css Content-Type "text/css3"
	@js path *.js
	header @js Content-Type "application/javascript5"
Check the enforced headers:
Content-Type: application/javascript5
Content-Type: text/css3
you were right, M/Monit’s localhost returns text/plain within the docker container, i’ll go ask them, though imma keep this thread open for now cuz maybe there’s something in my Caddy config that’s wrong
The Docker image is likely missing the mailcap package.
