Caddy only gives a nop
I configured multiple reverse entries - however a Synology Webserver doesnt work via Caddy.
I configured the upstream https, ip address, custom port (7001).
I only get a nop returned.
# Reverse Proxy Domain: "3f737aa2-b93a-4af7-2584-7560190f0489"
file.my.domain {
	log 3f737aa2-5288-4af7-2565-7560190f0489
	tls /var/db/caddy/data/caddy/certificates/temp/65d767a6b7244.pem /var/db/caddy/data/caddy/certificates/temp/65d767a6b7244.key
		reverse_proxy https://192.168.1.1:7001 {
				tls_insecure_skip_verify
It works flawless for other servers, therefore I dont see any issue in the FW config.
07T16:27:39Z","logger":"http.log.access.3f737aa2-b93a-4af7-b72d-7560190f0489","msg":"NOP","request":{"remote_ip":"192.168.1.2","remote_port":"60993","client_ip":"192.168.1.2","proto":"HTTP/2.0","method":"GET","host":"file.my.domain","uri":"/favicon.ico","headers":{"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36"],"Cookie":["REDACTED"],"Accept-Language":["en-GB,en;q=0.7"],"Sec-Fetch-Site":["same-origin"],"Sec-Ch-Ua":["\"Not(A:Brand\";v=\"99\", \"Brave\";v=\"133\", \"Chromium\";v=\"133\""],"Sec-Ch-Ua-Mobile":["?0"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Dest":["image"],"Priority":["u=1, i"],"Dnt":["1"],"Referer":["https://file.my.domain/"],"Sec-Fetch-Mode":["no-cors"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Gpc":["1"],"Sec-Ch-Ua-Platform":["\"macOS\""]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"file.my.domain"}},"bytes_read":0,"user_id":"","duration":0.000002745,"size":0,"status":0,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
caddy version
Part of opnsense
opnsense firewall
Testing with curl and manually setting the hostname to the FW LAN interface to make sure no DNS errors interfere.
curl -k --resolve file.my.domain:443:192.168.1.10 https://file.my.domain
# DO NOT EDIT THIS FILE -- OPNsense auto-generated file
# caddy_user=root
# Global Options
		include http.log.access.3f737aa2-b93a-4af7-b72d-7560190f0489
		output net unixgram//var/run/caddy/log.sock {
		format json {
			time_format rfc3339
	servers {
		protocols h1 h2
	auto_https off
	grace_period 10s
	import /usr/local/etc/caddy/caddy.d/*.global
# Reverse Proxy Configuration
# Reverse Proxy Domain: "79179cc0-6ab4-4a49-9d79-5d58cf46062a"
drive.my.domain {
	@a20a6fb3-09f4-4765-bd5e-8b34362d52bd_drivemydomain {
		not client_ip 173.245.48.0/20 103.21.244.0/22 103.22.200.0/22 103.31.4.0/22 141.101.64.0/18 108.162.192.0/18 190.93.240.0/20 188.114.96.0/20 197.234.240.0/22 198.41.128.0/17 162.158.0.0/15 104.16.0.0/13 104.24.0.0/14 172.64.0.0/13 131.0.72.0/22 10.0.0.0/8
	handle @a20a6fb3-09f4-4765-bd5e-8b34362d52bd_drivemydomain {
		abort
		reverse_proxy https://192.168.1.1:10003 {
# Reverse Proxy Domain: "cfb6ccd1-1006-453b-92f6-1d449b125935"
dsm.my.domain {
	@a20a6fb3-09f4-4765-bd5e-8b34362d52bd_dsmmydomain {
	handle @a20a6fb3-09f4-4765-bd5e-8b34362d52bd_dsmmydomain {
		abort
		reverse_proxy https://192.168.1.1:5001 {
# Reverse Proxy Domain: "a76af138-0c5c-453d-80d0-e21bd176672a"
photos.kazoku.my {
		reverse_proxy https://192.168.1.1:5003 {
# Reverse Proxy Domain: "b14eb5d4-db81-4be4-9aaa-089c6be2e465"
pve.my.domain {
	@a20a6fb3-09f4-4765-bd5e-8b34362d52bd_pvemydomain {
	handle @a20a6fb3-09f4-4765-bd5e-8b34362d52bd_pvemydomain {
		abort
		reverse_proxy https://192.168.1.111:8006 {
# Reverse Proxy Domain: "ff9fe08a-f2e8-41ec-a80b-96f0a130b051"
misp.my.domain {
	@a20a6fb3-09f4-4765-bd5e-8b34362d52bd_mispmydomain {
	handle @a20a6fb3-09f4-4765-bd5e-8b34362d52bd_mispmydomain {
		abort
		reverse_proxy https://10.0.20.11:443 {
# Reverse Proxy Domain: "3f737aa2-b93a-4af7-b72d-7560190f0489"
file.my.domain {
	log 3f737aa2-b93a-4af7-b72d-7560190f0489
import /usr/local/etc/caddy/caddy.d/*.conf
Any ideas are highly appreciated.
It’s because there is no handler/route configured for file.wicked.design, only for file.my.domain.
Thx matt. Sorry, this was ment to be replaced. There is a corresponding rule for file.wicked.design aka file.my.domain
PS: curl, ping, telnet etc. from the FW to the synology works as well.
Only going through caddy
PPS: Why am I replying too quickly and have to wait 35 minutes?!?
We’ve been fighting aggressive spam originating from Jio and Airtel, and the rate limiter helps slowing them down.
Thx for the info Mohammed
PS: I also just added a new, NPM based webservice, and it works flawless.
Is there any known issue with Synologys DSM based services?
There shouldn’t. I have Synology and proxy some services over Caddy just fine.
Strange. I deleted all of the rules, readded them, doesnt help.
All the other caddy entries work fine. Totally lost currently.
