Let’s be honest, Caddy doesn’t “just work”. The website and tutorials are akin to, “Here’s a car. It just works! Oh, by the way, you’ll need to build and install an engine before you can drive it. Duh.”
Many thanks to all the users who helped steer me in the right direction. For the record, @matt, “have you tried turning it off and back on again” … not helpful. Stick to developing Caddy. We love you for that. The following tutorial makes a few assumptions:
- You want Caddy to run automatically on boot
- Your Pi is running Raspbian Stretch or Raspbian Stretch Lite (released late 2017)
- You’re hosting a web server at home, forwarding ports 80 and 443 from your router
- You’re using a real, fully qualified domain (e.g. mysite.com)
- You own your domain’s SSL certificate and key
- Enter commands as root or with sudo
- Example IP 192.168.1.100
- Prepare your files.
mkdir /etc/ssl/caddy /etc/caddy /var/www
Add your certificates to /etc/ssl/caddy
Add your website files (HTML, CSS, JS, etc) to /var/www/mysite
If your certificate authority provides root and intermediate certificates, cat them into a single bundle, but make sure the BEGIN and END statements are on their own lines. Read more about bundles here. Example:
cat mysite.crt Root.crt Intermediate.crt > mysite_bundle.pem
- Download Caddy. The RPi 3, Zero, and Zero W should have ARM6 architecture. If the tar.gz file won’t open properly, try: gzip -d [file]. Use the setcap command to allow Caddy to run on ports 80 and 443.
wget https://caddyserver.com/download/linux/arm6
mv arm6 arm6.tar.gz
tar zxvf arm6.tar.gz
mv caddy /usr/local/bin/caddy
mv init/linux-systemd/caddy.service /etc/systemd/system/caddy.service
setcap 'CAP_NET_BIND_SERVICE=+eip' /usr/local/bin/caddy
- Caddy comes with a systemd init script to start Caddy on boot, but we need to tweak it.
nano /etc/systemd/system/caddy.service
Edit the ExecStart line from “-agree=true” to “-agree=false”, which will prevent Caddy from downloading ACME certificates (we have our own). Add the commands below to let the www-data user run the script properly.
- Edit your Caddyfile.
nano /etc/caddy/Caddyfile
If you need to test Caddy locally, without any domains or certifications, use the following:
localhost:2015 192.168.1.100:2015 {
root /var/www/local
Otherwise edit the Caddyfile for your domain:
mysite.com:80, www.mysite.com:80 {
redir mysite.com:443
mysite.com:443, www.mysite.com:443 {
root /var/www/mysite
tls /etc/ssl/caddy/mysite_bundle.pem /etc/ssl/caddy/mysite.key
- In Raspbian Stretch, the www-data user is already created and added to the www-data group by default. Simply give it ownership of the relevant files and set permissions. Refer to the Readme file under /init/linux-systemd/ in the arm6.tar.gz download for specific permissions.
chown www-data:www-data /usr/local/bin/caddy
chown www-data:www-data /etc/systemd/system/caddy.service
chown www-data:www-data /etc/caddy/Caddyfile
chown -R www-data:www-data /etc/ssl/caddy
chown -R www-data:www-data /var/www
- Use the following commands to enable, start, and restart the Caddy service
systemctl daemon-reload
systemctl enable caddy.service
systemctl start caddy.service
systemctl restart caddy.service
- Use the following commands to make sure Caddy is running correctly
systemctl status caddy.service
journalctl -u caddy.service
