Caddy on OPNsense - cannot get it to work
I have OPNsense running on my network running with the following:
  1. OPNsense (as proxmox VM)
  2. AdGuard Home (plugin)
  3. Unbound (plugin)
  4. Crowdsec (plugin)
  5. Kea DHCP (plugin)
I have it all running well together. Then as I started getting annoyed with my homelab setup and trying to remember ports, etc, I setup a caddy LXC in proxmox. Used unbound and set its over-rides to split off some local network addresses to point to my caddy lxc. Had the caddy LXC running fine. Everything works as intended. But as I spin up and down lxc/vm’s quite a bit, its a headache to set a static ip in kea (also I have a spreadsheet for quick and simple access to know what ip numbers are avail, etc), then set up an override hostname in unbound. Then I have to SSH in to proxmox so I can pcm enter into the lxc. Then I have to manually edit the caddyfile. Then wait for a min or two for it to setup the https and have it accessible.
So my hope was to be able to skip a few of those steps and also have an easy access gui to add/change/delete reverse proxy hostnames by changing from a caddy instance in an lxc to the opnsense plugin.
In opnsense, I disabled my overrides in unbound and followed all instructions as per the website for the plugin.
Caddy Plugin:
  • is enabled with a valid ACME email address
  • (advanced) http 1.1,2,3 all enabled with ports 80 + 443 (opnsense gui using 8443)
  • DNS provider of cloudflare set with custom api token (zone.zone and zone.dns), set resolvers to 1.1.1.1
  • LAN and WAN firewall rules set for ipv4 and ipv6
debug log to be cleared out as too large to fit due to unrelated error in a device trying to find a non-existing lxc
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"ha.epserver.co.uk"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"events","msg":"event","name":"tls_get_certificate","id":"c1b79d2b-55e0-420d-87a1-acf54bf017b2","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"ha.epserver.co.uk","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.32.0.22","Port":36368,"Zone":""},"LocalAddr":{"IP":"77.98.48.62","Port":443,"Zone":""}}}}
2025-02-18T11:09:06	Error	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"http.stdlib","msg":"http: TLS handshake error from 10.32.0.22:36362: no certificate available for 'ha.epserver.co.uk'"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.32.0.22","remote_port":"36362","server_name":"ha.epserver.co.uk","remote":"10.32.0.22:36362","identifier":"ha.epserver.co.uk","cipher_suites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0001,"load_or_obtain_if_necessary":true,"on_demand":false}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.*"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.uk"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.co.uk"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.epserver.co.uk"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"events","msg":"event","name":"tls_get_certificate","id":"7d173564-a4f2-490f-afd7-16cd70878b67","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"ha.epserver.co.uk","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.32.0.22","Port":36362,"Zone":""},"LocalAddr":{"IP":"77.98.48.62","Port":443,"Zone":""}}}}
2025-02-18T11:09:06	Error	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"http.stdlib","msg":"http: TLS handshake error from 10.32.0.22:36352: no certificate available for 'ha.epserver.co.uk'"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.32.0.22","remote_port":"36352","server_name":"ha.epserver.co.uk","remote":"10.32.0.22:36352","identifier":"ha.epserver.co.uk","cipher_suites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0001,"load_or_obtain_if_necessary":true,"on_demand":false}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"events","msg":"event","name":"tls_get_certificate","id":"ed157eea-37af-47de-8b68-c5422c4cbb60","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"ha.epserver.co.uk","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.32.0.22","Port":36352,"Zone":""},"LocalAddr":{"IP":"77.98.48.62","Port":443,"Zone":""}}}}
2025-02-18T11:09:06	Error	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"http.stdlib","msg":"http: TLS handshake error from 10.32.0.22:36340: no certificate available for 'ha.epserver.co.uk'"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.32.0.22","remote_port":"36340","server_name":"ha.epserver.co.uk","remote":"10.32.0.22:36340","identifier":"ha.epserver.co.uk","cipher_suites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0001,"load_or_obtain_if_necessary":true,"on_demand":false}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"events","msg":"event","name":"tls_get_certificate","id":"4551e857-ae27-4aa6-9544-dc4e4af5f362","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"ha.epserver.co.uk","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.32.0.22","Port":36340,"Zone":""},"LocalAddr":{"IP":"77.98.48.62","Port":443,"Zone":""}}}}
2025-02-18T11:09:06	Error	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"http.stdlib","msg":"http: TLS handshake error from 10.32.0.22:39904: no certificate available for 'ha.epserver.co.uk'"}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.32.0.22","remote_port":"39904","server_name":"ha.epserver.co.uk","remote":"10.32.0.22:39904","identifier":"ha.epserver.co.uk","cipher_suites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0001,"load_or_obtain_if_necessary":true,"on_demand":false}
2025-02-18T11:09:06	Debug	caddy	 "debug","ts":"2025-02-18T11:09:06Z","logger":"events","msg":"event","name":"tls_get_certificate","id":"5e3fde1f-50f6-4922-a554-ed1e06d25de4","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"ha.epserver.co.uk","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.32.0.22","Port":39904,"Zone":""},"LocalAddr":{"IP":"77.98.48.62","Port":443,"Zone":""}}}}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"dynamic_dns","msg":"no IP address change; no update needed"}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"dynamic_dns.ip_sources.simple_http","msg":"lookup","type":"IPv4","endpoint":"https://icanhazip.com","ip":"77.98.48.62"}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"admin","msg":"stopped previous server","address":"unix//var/run/caddy/caddy.sock|0220"}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"admin.api","msg":"load complete"}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","msg":"autosaved config (load with --resume flag)","file":"/var/db/caddy/config/caddy/autosave.json"}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"events","msg":"event","name":"cached_managed_cert","id":"9537988c-98aa-419c-9c13-d9ed1450cc4f","origin":"tls","data":{"sans":["*.epnet.work"]}}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"tls.cache","msg":"added certificate to cache","subjects":["*.epnet.work"],"expiration":"2025-05-19T07:56:11Z","managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"30e1f5672e30b0252405c2a1c6a82eacf2c32e4c50269ee57ff8baf8754522e8","cache_size":1,"cache_capacity":10000}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.epnet.work"]}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
2025-02-18T11:09:03	Warning	caddy	 "warn","ts":"2025-02-18T11:09:03Z","logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
2025-02-18T11:09:03	Warning	caddy	 "warn","ts":"2025-02-18T11:09:03Z","logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":false}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"dynamic_dns","msg":"beginning IP address check"}
2025-02-18T11:09:03	Debug	caddy	 "debug","ts":"2025-02-18T11:09:03Z","logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["*.epnet.work"]},{}]}},"http":{"http_port":80,"https_port":443,"grace_period":10000000000,"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}],"logs":{"should_log_credentials":true}},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"10.32.0.5:8096"}]}]}]}]}]}],"match":[{"host":["emby2"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{},"logs":{"should_log_credentials":true},"protocols":["h1","h2","h3"]}}}}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x870794080"}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"admin","msg":"admin endpoint started","address":"unix//var/run/caddy/caddy.sock|0220","enforce_origin":false,"origins":["","//127.0.0.1","//::1"]}
2025-02-18T11:09:03	Informational	caddy	 "info","ts":"2025-02-18T11:09:03Z","logger":"admin.api","msg":"received request","method":"POST","host":"127.0.0.1","uri":"/load","remote_ip":"","remote_port":"","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["1176"],"Content-Type":["application/json"],"User-Agent":["Go-http-client/1.1"]}}
2025-02-18T11:09:02	Informational	caddy	 "info","ts":"2025-02-18T11:09:02Z","logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0x87076a600"}
2025-02-18T11:09:02	Debug	caddy	 "debug","ts":"2025-02-18T11:09:02Z","logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["*.epnet.work"]},{}]}},"http":{"http_port":80,"https_port":443,"grace_period":10000000000,"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}],"logs":{"should_log_credentials":true}},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"10.32.0.5:8096"}]}]}]}]}]}],"match":[{"host":["emby2"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{},"logs":{"should_log_credentials":true},"protocols":["h1","h2","h3"]}}}}
2025-02-18T11:09:02	Informational	caddy	 "info","ts":"2025-02-18T11:09:02Z","logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
2025-02-18T11:09:02	Informational	caddy	 "info","ts":"2025-02-18T11:09:02Z","logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
2025-02-18T11:09:02	Informational	caddy	 "info","ts":"2025-02-18T11:09:02Z","logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x87076a600"}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","logger":"admin","msg":"stopped previous server","address":"unix//var/run/caddy/caddy.sock|0220"}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","logger":"admin.api","msg":"load complete"}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","msg":"autosaved config (load with --resume flag)","file":"/var/db/caddy/config/caddy/autosave.json"}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0x8708d5900"}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","logger":"http","msg":"servers shutting down; grace period initiated","duration":10}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","logger":"admin","msg":"admin endpoint started","address":"unix//var/run/caddy/caddy.sock|0220","enforce_origin":false,"origins":["","//127.0.0.1","//::1"]}
2025-02-18T11:08:58	Informational	caddy	 "info","ts":"2025-02-18T11:08:58Z","logger":"admin.api","msg":"received request","method":"POST","host":"127.0.0.1","uri":"/load","remote_ip":"","remote_port":"","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["173"],"Content-Type":["application/json"],"User-Agent":["Go-http-client/1.1"]}}
os-caddy - 1.8.2
OPNsense
N/A
  "apps": {
    "dynamic_dns": {
      "dns_provider": {
        "api_token": "<token>",
        "name": "cloudflare"
      "domains": {
        "emby2": [
      "versions": {
        "ipv4": true,
        "ipv6": false
    "http": {
      "grace_period": 10000000000,
      "http_port": 80,
      "https_port": 443,
      "servers": {
        "srv0": {
          "listen": [
            ":443"
          "logs": {
            "should_log_credentials": true
          "protocols": [
            "h1",
            "h2",
            "h3"
          "routes": [
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "routes": [
                              "handle": [
                                  "routes": [
                                      "handle": [
                                          "handler": "reverse_proxy",
                                          "upstreams": [
                                              "dial": "10.32.0.5:8096"
                      "match": [
                          "host": [
                            "emby2"
              "match": [
                  "host": [
                    "*.epnet.work"
              "terminal": true
    "tls": {
      "automation": {
        "policies": [
            "issuers": [
                "challenges": {
                  "dns": {
                    "provider": {
                    "resolvers": [
                      "1.1.1.1"
                  "http": {
                    "alternate_port": 80
                  "tls-alpn": {
                    "alternate_port": 443
                "email": "<email>",
                "module": "acme"
            "subjects": [
              "*.epnet.work"
  "logging": {
    "logs": {
      "default": {
        "encoder": {
          "format": "json",
          "time_format": "rfc3339"
        "level": "DEBUG",
        "writer": {
          "address": "unixgram//var/run/caddy/log.sock",
          "output": "net"
# DO NOT EDIT THIS FILE -- OPNsense auto-generated file
# caddy_user=root
# Global Options
		output net unixgram//var/run/caddy/log.sock {
		format json {
			time_format rfc3339
		level DEBUG
	http_port 80
	https_port 443
	servers {
		protocols h1 h2 h3
		log_credentials
	dynamic_dns {
		provider cloudflare <token>
		domains {
			emby2
		versions ipv4
	email psfrwrd.ricostuart@gmail.com
	grace_period 10s
	import /usr/local/etc/caddy/caddy.d/*.global
# Reverse Proxy Configuration
# Reverse Proxy Domain: "3a71227a-3469-4d49-b195-e012883cfd43"
*.epnet.work {
		issuer acme {
			dns cloudflare <token>
			resolvers 1.1.1.1
	@3fbe7e3e-d1a2-4ab0-8f07-8f0af3f35d62 {
		host emby2
	handle @3fbe7e3e-d1a2-4ab0-8f07-8f0af3f35d62 {
			reverse_proxy 10.32.0.5:8096 {
import /usr/local/etc/caddy/caddy.d/*.conf
2
Why does it search a certificate for
ha.epserver.co.uk
in the logs?
In your caddyfile you configured
emby2.epnet.work
Maybe 10.32.0.22:36340 is https:// and not http://? You could try setting it to https and enable tls_insecure_skip_verify
It seems you enable all options in global Caddy. let’s focus on protocol you have protocol h3 enabled This is HTTP/3 uses QUIC instead of TCP+TLS. and use UDP protocol. Try disable h3 protocol.
