I am trying to run the image wordpress:php8.0-fpm
and have caddy running on the host.
Can this be done? Do I need to share path the php files are served from between php_fpm and caddy?
As I have seen that others run caddy in a container as well and share the volume for the php files between the containers.
With my current setup of forwarding port 9001 from the host into the container for php_fpm I have the issue that http requests to / are not rewritten to index.php properly.
curl -vL http://phptest.localhost/
gives an error. See log.
curl -vL http://phptest.localhost/index.php
no error and the file from the container is returned.
root@vm1 /s/phptest# curl -vL http://phptest.localhost/
* Trying 127.0.0.1:80...
* Connected to phptest.localhost (127.0.0.1) port 80 (#0)
> GET / HTTP/1.1
> Host: phptest.localhost
> User-Agent: curl/7.88.1
< Connection: close
< Location: https://phptest.localhost/
< Server: Caddy
< Date: Mon, 04 Nov 2024 22:24:04 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://phptest.localhost/'
* Trying 127.0.0.1:443...
* Connected to phptest.localhost (127.0.0.1) port 443 (#1)
* ALPN: offers h2,http/1.1
* CApath: /etc/ssl/certs
* ALPN: server accepted h2
* subject: [NONE]
* start date: Nov 4 20:33:12 2024 GMT
* expire date: Nov 5 08:33:12 2024 GMT
* subjectAltName: host "phptest.localhost" matched cert's "phptest.localhost"
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: phptest.localhost]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0xaaaaee4baaf0)
> GET / HTTP/2
> accept: */*
< HTTP/2 404
< server: Caddy
< content-length: 0
< date: Mon, 04 Nov 2024 22:24:04 GMT
* Connection #1 to host phptest.localhost left intact
When I create a index.php contaning echo "Hello from index.php on the host system 👾 :)";
on the host in the same path, caddy will now correctly access the index.php from the container with the content echo "I am traped in this container heeeelp..."
But this cant be a solution?
I have tried to add rewrite or handle configurations but so far with no success.
Calls to specific paths always work as intended curl -vL http://phptest.localhost/index.php
or curl -vL http://phptest.localhost/db_test.php
I have also installed caddy inside the wordpress fpm container and these issues are not present when using the same caddy configuration and making the http request from inside the container.
root@vm1 /s/phptest# mv index.php_old index.php
root@vm1 /s/phptest# cat index.php
<?php
> GET / HTTP/1.1
< Connection: close
< Server: Caddy
< Date: Mon, 04 Nov 2024 22:28:12 GMT
< Content-Length: 0
* subject: [NONE]
* using HTTP/2
* h2h3 [:path: /]
* Using Stream ID: 1 (easy handle 0xaaaadfc2faf0)
> GET / HTTP/2
> accept: */*
< HTTP/2 200
< content-type: text/html; charset=UTF-8
< server: Caddy
< x-powered-by: PHP/8.0.30
< content-length: 60
< date: Mon, 04 Nov 2024 22:28:12 GMT
PHP executing...
2024/11/04 22:57:39.578 INFO http.log.access handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "50246", "proto": "HTTP/1.1", "method": "GET", "host": "phptest.localhost", "uri": "/", "headers": {"User-Agent": ["curl/7.88.1"], "Accept": ["*/*"]}}, "user_id": "", "duration": 0.00004508, "size": 0, "status": 308, "resp_headers": {"Server": ["Caddy"], "Connection": ["close"], "Location": ["https://phptest.localhost/"], "Content-Type": []}}
2024/11/04 22:57:39.632 INFO http.log.access handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "59568", "proto": "HTTP/2.0", "method": "GET", "host": "phptest.localhost", "uri": "/", "headers": {"Accept": ["*/*"], "User-Agent": ["curl/7.88.1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "phptest.localhost"}}, "user_id": "", "duration": 0.00217768, "size": 60, "status": 200, "resp_headers": {"X-Powered-By": ["PHP/8.0.30"], "Content-Type": ["text/html; charset=UTF-8"], "Server": ["Caddy"], "Alt-Svc": ["h3=\":443\"; ma=2592000"]}}
2024/11/04 22:58:19.361 INFO http.log.access handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "56064", "proto": "HTTP/1.1", "method": "GET", "host": "phptest.localhost", "uri": "/", "headers": {"User-Agent": ["curl/7.88.1"], "Accept": ["*/*"]}}, "user_id": "", "duration": 0.00003784, "size": 0, "status": 308, "resp_headers": {"Server": ["Caddy"], "Connection": ["close"], "Location": ["https://phptest.localhost/"], "Content-Type": []}}
2024/11/04 22:58:19.433 ERROR http.log.access handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "49962", "proto": "HTTP/2.0", "method": "GET", "host": "phptest.localhost", "uri": "/", "headers": {"User-Agent": ["curl/7.88.1"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "phptest.localhost"}}, "user_id": "", "duration": 0.00015248, "size": 0, "status": 404, "resp_headers": {"Server": ["Caddy"], "Alt-Svc": ["h3=\":443\"; ma=2592000"]}}
apt on debian 12:
apt policy caddy
Installed: 2.6.2-5
Candidate: 2.6.2-5
Version table:
*** 2.6.2-5 500
500 http://debian.anexia.at/debian bookworm/main arm64 Packages
100 /var/lib/dpkg/status
debian 12
nerdctl & containerd with wordpress:php8.0-fpm
root@vm1 /s/phptest# nerdctl ps -a
0a7144ad7c4d docker.io/library/wordpress:php8.0-fpm "docker-entrypoint.s…" 44 hours ago Up 0.0.0.0:9001->9000/tcp wp-jessica-wordpress-1
On the host:
root@vm1 /s/phptest# caddy run --config /etc/caddy/Caddyfile
compose.yaml
wordpress:
image: wordpress:php8.0-fpm
WORDPRESS_DB_HOST: db:3306
WORDPRESS_DB_NAME: wordpress_db
WORDPRESS_DB_USER: wordpress_user
WORDPRESS_DB_PASSWORD: wordpress_password
- wp_data:/var/www/html
- "9001:9000" # Expose PHP-FPM port 9000 to the host at port 9001
db:
image: mariadb:latest
MYSQL_DATABASE: wordpress_db
MYSQL_USER: wordpress_user
MYSQL_PASSWORD: wordpress_password
MYSQL_ROOT_PASSWORD: root_password
- wp_db_data:/var/lib/mysql
wordpress_data:
db_data:
phptest.localhost {
root * /srv/phptest/
# port 9001 is forwarded into a container:
# nerdctl ps -a
# 0a7144ad7c4d docker.io/library/wordpress:php8.0-fpm
# / "docker-entrypoint.s…" 42 hours ago Up
# / 0.0.0.0:9001->9000/tcp wordpress-1
php_fastcgi localhost:9001
log
