Caddy on Docker (Portainer) to allow HTTPS for VaultWarden
Caddy V2.4.6 (docker)
Caddy is installed on Docker (Portainer), on a local network (ubuntu-server).
  • Hardware is a NUC running Proxmox
  • Caddy is installed on an ubuntu VM running Docker.
  • VaultWarden is installed as a separate container in Docker too.
I have a separate RasperryPi running PiHole
Run from Portainer with the following:
CMD = caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
Volumes:
/var/lib/docker/volumes/caddy/config >> /config
/var/lib/docker/volumes/caddy/data >> /data
/var/lib/docker/volumes/caddy/Caddyfile| >> /etc/caddy/Caddyfile
/var/lib/docker/volumes/caddy/site >> /usr/share/caddy
Paste command here.
have tried:
vault.ubuntu-server {
reverse_proxy localhost:8000
and also tried:
vault.localhost {
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I am unable to have Caddy serve VaultWarden as HTTPS. VaultWarden is on the same server, using port 8000 mapped to 80 in Portainer. VaultWarden opens ok, but I need to enable SSL to be able to set-up and continue
No errors as such. Just can’t get Caddy to work with this set-up
I have tried several CaddyFile options.
Caddy will have logs. Check the container’s log outputs.
Did you bind Caddy to ports 80 and 443 on the host machine?
Do you have your local DNS server (I assume pihole) resolving that hostname to the IP address of your server?
I can’t suggest anything without actually seeing evidence of the errors. Check your logs, explain what’s not working. Make a request with curl -v to show what happens.
And please place your logs and config within code blocks in your post, between the lines with ``` backticks. Code blocks will makes sure formatting is preserved. It’s hard to read otherwise. (Also see the help topic template, you were meant to paste your logs within those code fences where it says “Paste config here”)
Hi - thank you Francis for responding.
I think that Caddy is kind of working but I don’t think the CaddyFile is correct. Yes, I bind ports 80 and 443 on the host machine. Yes, the local DNS is Pi-hole and this is resolving back to the Caddy server.
The issue is that Chrome is saying the connection is Not Secure when connecting both internally (with Pihole DNS forwarding to Caddy) or externally (where the web-server A Host points to Caddy IP).
This is an example of the CaddyFile where ‘service’ is accessible from within the network (local.lan) and externally (example.com):
local_certs
service.local.lan {
reverse_proxy 192.168.X.Y:8000
service.example.com {
But in both cases, I get Not Secure. I think that this is issuing local certs in both cases, so need to only issue local certs to the local version (local.lan) and not to external. But, not sure how do do this within the CaddyFile.
Right, the local_certs global option just makes Caddy issue local certs for all sites regardless of whether it’s a public domain or not. It’s more meant as a quick switch to flip when testing things to avoid hitting public ACME issuers.
Instead, you should use the tls internal directive on any sites you want to use local certs.
As I said, please use backticks for code blocks when posting config or logs. Whitespace gets lost otherwise, making it harder to read.
You used block quotes. Use code blocks, which involves putting 3 backticks on the lines immediately preceding and following the logs/config.
it ends up looking like this
There’s also a button in the reply editor that looks like </>
That’s strange, but harmless.
I tried to load https://vault.dsewell.co.uk myself, and it seems to work fine (HTTPS, with a valid publicly trusted cert). So you should be good to go.
Thank you for your help :slight_smile: :grin:
Sorry for the very poor use of markup :frowning:
