Caddy `on_demand_tls` with Cloudflare DNS
My apps allows users to setup custom domains with a CNAME record. I use cloudflare DNS along with the proxy enabled and with Full encryption mode
My Caddyfile looks like the following.
  on_demand_tls {
    ask http://localhost:8001/caddy/ask
https:// {
    on_demand
  reverse_proxy  localhost:8001
api.getnoto.app {
  reverse_proxy  127.0.0.1:8001
*.getnoto.page {
The problem is that the requests won’t work, the browser would yield ERR_SSL_VERSION_OR_CIPHER_MISMATCH error. But it works perfectly fine when I disable the DNS proxy (Which I cannot, since it exposes my real IP)
How do I make it work?
I couldn’t find any meaning full logs even after running Caddy in debug mode. But the following are my application logs
INFO:     172.18.0.1:42728 - "GET /caddy/ask?domain=172.31.24.112 HTTP/1.1" 403 Forbidden
INFO:     172.18.0.1:54676 - "GET /caddy/ask?domain=dummy.acme.corp HTTP/1.1" 200 OK
The first request is with CF proxy enabled, the second one is with it disabled. I am assuming caddy is not getting the correct incoming domain but it’s getting the Cloudflare IP, is there a way to configure caddy to handle this behaviour?
It’s the default installing with no plugins, with the steps outlined here Install — Caddy Documentation
Ubuntu 22.04 running on a chunky EC2 instance
caddy start
  on_demand_tls {
https:// {
    on_demand
  handle /caddy/ask {
    respond "This path is blocked." 403
  handle /healthz {
api.getnoto.app {
  handle /caddy/ask {
  handle /healthz {
*.getnoto.page {
It’s impossible to use On-Demand TLS with an HTTP-layer proxy.
If Cloudflare had a TCP proxying mode, it would be possible to use their proxy. But they don’t do that.
So you have to turn off Cloudflare proxying.
The reason is that Cloudflare is terminating TLS when acting as a proxy, so Caddy doesn’t receive the original TLS handshake, which is what triggers cert issuance.
If Cloudflare doesn’t have a certificate for the given domain (and it wouldn’t, for all the CNAMEs) then it can’t complete the initial TLS handshake, so nothing makes it through to Caddy.
Why would this be a problem? That’s how you have to do it.
Thanks a lot for such a quick response, as a fellow OSS maintainer, I really appreciate it.
Yeah, I had the same doubt, just wanted to know for sure.
It potentially exposes my app to DDOS, without the proxy there is no DDOS protection. Perhaps you’re right, there’s no alternative,. I saw there’s a SSL for SaaS offering from Cloudflare, but it’s safe to assume that is a lot of $$$$.
Regardless, thanks for the info.
You can mitigate the risk by scaling out Caddy to multiple servers. As long as they all share the same storage (e.g. Redis or whatever other storage plugin) then the Caddy instances will coordinate when issuing certs.
You should have somekind of firewall in front of Caddy so that you can react to abusive clients and block their IP for some time.
