Caddy on_demand LetsEncypt with Custom SSL On_demand
I want to use this Config in caddy
:443 {
        # Fetch custom certificate if available
        get_certificate http://localhost:9000/get-cert
        # Enable on-demand TLS for domains without custom certificates
        on_demand
        # Optional: Set ask endpoint to validate domains
        ask http://localhost:9000/validate-domain
I want to Achieve the following using caddy:
We are implementing a solution where we automatically generate SSL certificates for customers who do not have their own custom SSL certificates. For these customers, we use Let’s Encrypt’s on-demand SSL certificates.
For customers who already provide their own custom SSL certificates, we simply utilize their existing certificates. These should be also on demand using
Is it possible to host both solutions on the single instance using above caddy file?
PS: I tried doing that but, only one(ask or Get_certificate) is working.
Any Solution will be appreciated.
Thanks
