1. Output of caddy version
2.4.6-4.fc36
Fedora 36
systemd
baremetal
Caddy installed from official fedora repo
systemctl start caddy
# caddy.service
Description=Caddy web server
After=network.target
Type=notify
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ProtectHome=true
# As an alternative to editing the above site block, you can add your own site
# block files in the Caddyfile.d directory, and they will be included as long
# as they use the .caddyfile extension.
import Caddyfile.d/*.caddyfile
/etc/caddy/Caddyfile.d/00global.caddyfile
# TLS Options
email "ssladmin@example.org"
/etc/caddy/Caddyfile.d/a.example.org.caddyfile
a.example.org {
bind 203.0.113.2 2001:db8::2
respond "Welcome to a.example.org"
/etc/caddy/Caddyfile.d/b.example.org.caddyfile
http://b.example.org {
bind 203.0.113.3
respond "Welcome to b.example.org"
The IP addresses used in this example are based on RFC 5737 (IPv4) and RFC 3849 (IPv6).
I have a system with 10 IP addresses:
- 203.0.113.1
- 203.0.113.2
- 203.0.113.3
- 203.0.113.4
- 203.0.113.5
- 2001:db8::1
- 2001:db8::2
- 2001:db8::3
- 2001:db8::4
- 2001:db8::5
IP address 203.0.113.1 is used by Apache web server.
I now have 3 websites:
a.example.org, should be available via HTTP and HTTPS and served via
203.0.113.2
and2001:db8::2
b.example.org, should only be available via HTTP and served via
203.0.113.3
c.example.org, should be available via HTTPS only and served via
203.0.113.4
and2001:db8::4
I came up with shown config files. Without b.example.org.caddyfile
in place, a.example.org
works as expected. I.e. caddy is only listening on 203.0.113.2
and 2001:db8::2
for both, HTTP and HTTPS and does not clash with Apache.
But once I add config for b.example.org
like shown, caddy stops listening on 203.0.113.2:80
and [2001:db8::2]:80
# ss -tlnp | grep -F 'caddy'
LISTEN 0 4096 203.0.113.3:80 0.0.0.0:* users:(("caddy",pid=31890,fd=10))
LISTEN 0 4096 203.0.113.2:443 0.0.0.0:* users:(("caddy",pid=31890,fd=7))
LISTEN 0 4096 127.0.0.1:2019 0.0.0.0:* users:(("caddy",pid=31890,fd=3))
LISTEN 0 4096 [2001:db8::2]:443 [::]:* users:(("caddy",pid=31890,fd=8))
Connection test:
$ curl -kL --resolve a.example.org:80:203.0.113.2 http://a.example.org/
curl: (7) Failed to connect to a.example.org port 80 after 2115 ms: Connection refused
But a.example.org
is accessible via 203.0.113.3
$ curl -kL --resolve a.example.org:80:203.0.113.3 http://a.example.org/
This raises an additional question: I don’t want that caddy serves a.example.org via any other listener.
I also don’t want that caddy arbitrary redirects sites I did not add to caddy:
$ dig +short caddyserver.com
165.227.20.207
$ curl -vkL --resolve badsite.example.org:80:165.227.20.207 http://badsite.example.org/
* Added badsite.example.org:80:165.227.20.207 to DNS cache
* Hostname badsite.example.org was found in DNS cache
* Trying 165.227.20.207:80...
* Connected to badsite.example.org (165.227.20.207) port 80 (#0)
> GET / HTTP/1.1
> Host: badsite.example.org
> User-Agent: curl/7.83.1
< Connection: close
< Location: https://badsite.example.org/
< Server: Caddy
< Date: Wed, 21 Dec 2022 15:58:55 GMT
< Content-Length: 0
* Closing connection 0
