Caddy not working through SystemCTL
Running caddy with sudo systemctl start caddy, appears to start caddy but my website is not working when I try to access it. It works when I run manually:
In this thread the issue was the lack of permissions to the caddy user. I checked as well and it seems good:
ls -la /etc/caddy/Caddyfile \\ -rw-r--r-- 1 caddy caddy 742 Dec 2 19:19 /etc/caddy/Caddyfile
ls -la /var/www/html/ \\ -rwxr-xr-x 1 caddy caddy 1497 Oct 1 13:37 index.html
I have not seen any error messages, it loooks to be running fine.
ubuntu@ip-172-31-37-189:~$ sudo systemctl status caddy
● caddy.service - Caddy
     Loaded: loaded (/usr/lib/systemd/system/caddy.service; disabled; preset: enabled)
     Active: active (running) since Tue 2024-12-03 18:24:40 UTC; 4min 14s ago
   Main PID: 12662 (caddy)
      Tasks: 6 (limit: 1130)
     Memory: 9.9M (peak: 11.8M)
        CPU: 71ms
             └─12662 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: HOME=/var/lib/caddy
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: INVOCATION_ID=85aaef45b6434db68198f5155dc8d6df
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: JOURNAL_STREAM=8:77128
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: SYSTEMD_EXEC_PID=12662
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: MEMORY_PRESSURE_WATCH=/sys/fs/cgroup/system.slice/caddy.service/memory.pressure
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: MEMORY_PRESSURE_WRITE=c29tZSAyMDAwMDAgMjAwMDAwMAA=
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: {"level":"info","ts":1733250280.0189543,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: {"level":"info","ts":1733250280.021471,"msg":"adapted config to JSON","adapter":"caddyfile"}
Dec 03 18:24:40 ip-172-31-37-189 caddy[12662]: {"level":"info","ts":1733250280.0219426,"msg":"redirected default logger","from":"stderr","to":"/var/log/caddy/website-access-log.log"}
Dec 03 18:24:40 ip-172-31-37-189 systemd[1]: Started caddy.service - Caddy.
3. Caddy version: v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
4. How I installed and ran Caddy: installed with linux package and have been running so far with:
sudo caddy run --config /etc/caddy/Caddyfile
But this occupies the terminal so I wanted to use systemctl
Ubuntu, ec2 machine
                output file /var/log/caddy/website-access-log.log
# Redirect all www traffic to non-www
www.website.com {
        redir https://website.com{uri} # Ensure the `www` subdomain redirects to the root domain
website.com {
        root * /var/www/html # Path to your React app's build folder
        #Route is used to ensure that first reverse proxy is executed and only resort to try files if its not an api call
        route {
                reverse_proxy /api/* localhost:8080
                # Redirect all routes not matching files to index.html for client-side routing
                try_files {path} /index.html # This allows React Router to take over for non-file URLs
                # Serve static files (React app)
type or paste code here
What does that mean? In what way is it not working? Show evidence of that. Show an example request with curl -v. Show debug logs. See Keep Caddy Running — Caddy Documentation
By not working I mean I get the error:
# This site can’t provide a secure connection
**website.com** sent an invalid response.
With curl
curl -v website.com
* Host website.com:80 was resolved.
* IPv6: (none)
* IPv4: 3.66.134.133
*   Trying 3.66.134.133:80...
* Connected to website.com (3.66.134.133) port 80
> GET / HTTP/1.1
> Host: website.com
> User-Agent: curl/8.9.1
* Request completely sent off
< Connection: close
< Location: https://website.com/
< Server: Caddy
< Date: Thu, 05 Dec 2024 19:18:50 GMT
< Content-Length: 0
The logs in the log file show this:
{"level":"debug","ts":1733426243.48332,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.com"}
{"level":"debug","ts":1733426243.483323,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1733426243.48333,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"130.226.165.154","remote_port":"51013","server_name":"website.com","remote":"130.226.165.154:51013","identifier":"website.com","cipher_suites":[47802,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1733426243.483383,"logger":"http.stdlib","msg":"http: TLS handshake error from 130.226.165.154:51013: no certificate available for 'website.com'"}
{"level":"debug","ts":1733426243.5265095,"logger":"events","msg":"event","name":"tls_get_certificate","id":"89a16f86-7ea3-4ea4-997f-8a709bba3d11","origin":"tls","data":{"client_hello":{"CipherSuites":[64250,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"website.com","SupportedCurves":[51914,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[6682,772,771],"RemoteAddr":{"IP":"130.226.165.154","Port":51014,"Zone":""},"LocalAddr":{"IP":"172.31.37.189","Port":443,"Zone":""}}}}
{"level":"debug","ts":1733426243.5265455,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"website.com"}
{"level":"debug","ts":1733426243.5265503,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.com"}
{"level":"debug","ts":1733426243.5265534,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1733426243.5265641,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"130.226.165.154","remote_port":"51014","server_name":"website.com","remote":"130.226.165.154:51014","identifier":"website.com","cipher_suites":[64250,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1733426243.5266166,"logger":"http.stdlib","msg":"http: TLS handshake error from 130.226.165.154:51014: no certificate available for 'website.com'"}
You only made an HTTP request to Caddy, and it responded as expected with an HTTP->HTTPS redirect. Use curl -v https://website.com instead.
Are sure sure that’s all your logs? Please post everything, there must be errors earlier relating to cert issuance.
* Host website.com:443 was resolved.
* IPv6: (none)
*   Trying 3.66.134.133:443...
* Connected to website.com (3.66.134.133) port 443
* schannel: disabled automatic use of client certificate
* ALPN: curl offers http/1.1
* schannel: next InitializeSecurityContext failed: SEC_E_ILLEGAL_MESSAGE (0x80090326) - This error usually occurs when a fatal SSL/TLS alert is received (e.g. handshake failed). More detail may be available in the Windows System event log.
* closing connection #0
curl: (35) schannel: next InitializeSecurityContext failed: SEC_E_ILLEGAL_MESSAGE (0x80090326) - This error usually occurs when a fatal SSL/TLS alert is received (e.g. handshake failed). More detail may be available in the Windows System event log.
Here is the entire log.
{"level":"info","ts":1733432880.1155927,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1733432880.115596,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["www.website.com","website.com"]}
{"level":"error","ts":1733432880.1157107,"msg":"unable to create folder for config autosave","dir":"/var/lib/caddy/.config/caddy","error":"mkdir /var/lib/caddy: permission denied"}
{"level":"info","ts":1733432880.1162271,"msg":"serving initial configuration"}
{"level":"warn","ts":1733432880.116334,"logger":"tls","msg":"unable to get instance ID; storage clean stamps will be incomplete","error":"mkdir /var/lib/caddy: permission denied"}
{"level":"error","ts":1733432880.1163802,"logger":"tls","msg":"could not clean default/global storage","error":"unable to acquire storage_clean lock: creating lock file: open /var/lib/caddy/.local/share/caddy/locks/storage_clean.lock: no such file or directory"}
{"level":"info","ts":1733432880.1163857,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1733432880.117486,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0008f0380"}
{"level":"error","ts":1733432880.1176958,"logger":"tls","msg":"job failed","error":"www.website.com: obtaining certificate: failed storage check: mkdir /var/lib/caddy: permission denied - storage is probably misconfigured"}
{"level":"error","ts":1733432880.117776,"logger":"tls","msg":"job failed","error":"website.com: obtaining certificate: failed storage check: mkdir /var/lib/caddy: permission denied - storage is probably misconfigured"}
{"level":"debug","ts":1733432897.852266,"logger":"events","msg":"event","name":"tls_get_certificate","id":"fa619a89-cb1a-49de-ba8b-913a64304930","origin":"tls","data":{"client_hello":{"CipherSuites":[51914,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"website.com","SupportedCurves":[14906,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[56026,772,771],"RemoteAddr":{"IP":"130.226.165.154","Port":55590,"Zone":""},"LocalAddr":{"IP":"172.31.37.189","Port":443,"Zone":""}}}}
{"level":"debug","ts":1733432897.852313,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"website.com"}
{"level":"debug","ts":1733432897.8523188,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.com"}
{"level":"debug","ts":1733432897.852322,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1733432897.8523285,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"130.226.165.154","remote_port":"55590","server_name":"website.com","remote":"130.226.165.154:55590","identifier":"website.com","cipher_suites":[51914,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1733432897.8523846,"logger":"http.stdlib","msg":"http: TLS handshake error from 130.226.165.154:55590: no certificate available for 'website.com'"}
{"level":"debug","ts":1733432897.8526075,"logger":"events","msg":"event","name":"tls_get_certificate","id":"4505e6c0-deba-4d93-ad43-b9053473ed60","origin":"tls","data":{"client_hello":{"CipherSuites":[56026,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"website.com","SupportedCurves":[60138,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[6682,772,771],"RemoteAddr":{"IP":"130.226.165.154","Port":55591,"Zone":""},"LocalAddr":{"IP":"172.31.37.189","Port":443,"Zone":""}}}}
{"level":"debug","ts":1733432897.8526366,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"website.com"}
{"level":"debug","ts":1733432897.8526423,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.com"}
{"level":"debug","ts":1733432897.8526454,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1733432897.8526497,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"130.226.165.154","remote_port":"55591","server_name":"website.com","remote":"130.226.165.154:55591","identifier":"website.com","cipher_suites":[56026,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1733432897.852673,"logger":"http.stdlib","msg":"http: TLS handshake error from 130.226.165.154:55591: no certificate available for 'website.com'"}
{"level":"debug","ts":1733432897.8953831,"logger":"events","msg":"event","name":"tls_get_certificate","id":"332753f7-cb60-40c9-a00d-0689dee3cf91","origin":"tls","data":{"client_hello":{"CipherSuites":[64250,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"website.com","SupportedCurves":[43690,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[10794,772,771],"RemoteAddr":{"IP":"130.226.165.154","Port":55593,"Zone":""},"LocalAddr":{"IP":"172.31.37.189","Port":443,"Zone":""}}}}
{"level":"debug","ts":1733432897.8954122,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"website.com"}
{"level":"debug","ts":1733432897.8954175,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.com"}
{"level":"debug","ts":1733432897.895421,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1733432897.895434,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"130.226.165.154","remote_port":"55593","server_name":"website.com","remote":"130.226.165.154:55593","identifier":"website.com","cipher_suites":[64250,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1733432897.8954718,"logger":"http.stdlib","msg":"http: TLS handshake error from 130.226.165.154:55593: no certificate available for 'website.com'"}
{"level":"debug","ts":1733432897.8959491,"logger":"events","msg":"event","name":"tls_get_certificate","id":"ebc421aa-0fdc-4ef1-ab5c-664656407f70","origin":"tls","data":{"client_hello":{"CipherSuites":[19018,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"website.com","SupportedCurves":[51914,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[27242,772,771],"RemoteAddr":{"IP":"130.226.165.154","Port":55592,"Zone":""},"LocalAddr":{"IP":"172.31.37.189","Port":443,"Zone":""}}}}
{"level":"debug","ts":1733432897.8960395,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"website.com"}
{"level":"debug","ts":1733432897.8960888,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.com"}
{"level":"debug","ts":1733432897.896112,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1733432897.8961537,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"130.226.165.154","remote_port":"55592","server_name":"website.com","remote":"130.226.165.154:55592","identifier":"website.com","cipher_suites":[19018,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1733432897.8963072,"logger":"http.stdlib","msg":"http: TLS handshake error from 130.226.165.154:55592: no certificate available for 'website.com'"}
This is what I get once I initialize and make one attempt to connect to the website
Check the permissions for /var/lib/caddy. It should have user:group caddy:caddy
It seems that the directory /var/lib/caddy does not even exist. How should I proceed?
Sorry for the delay - you can just create it, make sure it’s owned by caddy:caddy as I said (use chown to change its permissions) then restart Caddy.
