Caddy not working at all for any reverse proxy after recent updates
Caddy doesn’t work after latest update - no reverse proxies are resolved.
Error: sending configuration to instance: performing request: Post "http://localhost:2019/load": dial tcp 127.0.0.1:2019: connect: connection refused
(when trying to reload caddy file)
v2.7.6
via bash/apt
Ubuntu 22.04.4 LTS x86-64
sudo caddy reload --config /etc/caddy/Caddyfile
# domain name.
https://www.olliemon.co.uk {
	root * /usr/share/caddy
	# php_fastcgi localhost:9000#
	route /ombi* {
		reverse_proxy 127.0.0.1:5000
map.olliemon.co.uk {
	reverse_proxy 127.0.0.1:8123
plex.olliemon.co.uk {
	reverse_proxy 127.0.0.1:32400
webmin.olliemon.co.uk {
	reverse_proxy 127.0.0.1:10000
amp.olliemon.co.uk {
	reverse_proxy 127.0.0.1:8080
bluemap.olliemon.co.uk {
	reverse_proxy 127.0.0.1:8100
home.olliemon.co.uk {
	reverse_proxy 192.168.0.195:8123
print.olliemon.co.uk {
	reverse_proxy 192.168.0.71 {
		header_up X-Scheme {scheme}
obico.olliemon.co.uk {
	reverse_proxy 127.0.0.1:3334 {
Please follow these instructions for using Caddy when you’ve installed it with apt:
Caddy is probably not running, so you can’t reload. It probably failed to start with an error. Check the logs for the error.
When I try and restart/reload with systemctl, I get the error as follows:
Error loading initial config: loading new config
We need to see your full logs. Not just part of one line.
Follow the instructions at the link above, it shows you the command to use to see your full logs.
I’ve worked it out in the meantime - Caddy was unable to bind to any of the HTTP or HTTPS ports because NGINX had taken them. This is despite me uninstalling and purging NGINX prior to this. I can only assume that it is a dependency for another package I have installed.
Is there any way of forcing caddy to “load” first in the order of systemctl services to prevent this happening again if NGINX sneaks back otno the system?
