Caddy not working as proxy for Azure IoTHub
I am trying to use Caddy as reverse proxy for Azure IoTHub and trying to send message to IoTHub using https, mqtt, amqp, amqp_ws,mqtt_ws. I am getting error when I send message via https.
I get below error
    "Message": "ErrorCode:ServerError;InternalServerError",
    "ExceptionMessage": "Tracking ID:84787584d1a1428cab1e72dc1187be47-G:0-TimeStamp:11/23/2024 16:29:17"
**Request details**
https://localhost:443/devices/<device-id>/messages/events?api-version=2021-04
method:POST
message body
    "name":"testmsg"
Headers
Authorization:<working auth- this works when I send direct message without caddy to this IoTHub device>
Content-Type:application/json
**Error on Caddy console**
2024/11/23 16:33:34.618 ←[35mDEBUG←[0m  http.stdlib     http: TLS handshake error from [::1]:58223: EOF
2024/11/23 16:33:34.619 ←[35mDEBUG←[0m  events  event   {"name": "tls_get_certificate", "id": "7dcb23f3-8a82-4295-adc6-d50c4b424733", "origin": "tls", "data": {"client_hello":{"CipherSuites":[4865,4866,4867,49199,49195,49200,49196,49191,52393,52392,49161,49171,49162,49172,156,157,47,53],"ServerName":"localhost","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":null,"SupportedVersions":[772,771,770,769],"RemoteAddr":{"IP":"::1","Port":58224,"Zone":""},"LocalAddr":{"IP":"::1","Port":443,"Zone":""}}}}
2024/11/23 16:33:34.620 ←[35mDEBUG←[0m  tls.handshake   choosing certificate    {"identifier": "localhost", "num_choices": 1}
2024/11/23 16:33:34.620 ←[35mDEBUG←[0m  tls.handshake   default certificate selection results   {"identifier": "localhost", "subjects": ["localhost"], "managed": true, "issuer_key": "local", "hash": "09641b28975d89acab5749d2ad7815a96741bb190eb6bae859996a9944d147d2"}
2024/11/23 16:33:34.620 ←[35mDEBUG←[0m  tls.handshake   matched certificate in cache    {"remote_ip": "::1", "remote_port": "58224", "subjects": ["localhost"], "managed": true, "expiration": "2024/11/24 04:29:09.000", "hash": "09641b28975d89acab5749d2ad7815a96741bb190eb6bae859996a9944d147d2"}
2024/11/23 16:33:34.622 ←[35mDEBUG←[0m  http.handlers.reverse_proxy     selected upstream       {"dial": "iothubname.azure-devices.net:443", "total_upstreams": 1}
2024/11/23 16:33:35.747 ←[35mDEBUG←[0m  http.handlers.reverse_proxy     upstream roundtrip      {"upstream": "<iothubname>.azure-devices.net:443", "duration": 1.1240946, "request": {"remote_ip": "::1", "remote_port": "58224", "client_ip": "::1", "proto": "HTTP/1.1", "method": "POST", "host": "localhost:443", "uri": "/devices/<device-id>/messages/events?api-version=2021-04", "headers": {"User-Agent": ["PostmanRuntime/7.42.0"], "Authorization": ["REDACTED"], "Cache-Control": ["no-cache"], "X-Forwarded-Proto": ["https"], "Content-Length": ["28"], "X-Forwarded-For": ["::1"], "Accept-Encoding": ["gzip, deflate, br"], "X-Forwarded-Host": ["localhost:443"], "Content-Type": ["application/json"], "Accept": ["*/*"], "Postman-Token": ["token"]}, "tls": {"resumed": false, "version": 771, "cipher_suite": 49195, "proto": "", "server_name": "localhost"}}, "headers": {"Date": ["Sat, 23 Nov 2024 16:33:35 GMT"], "Content-Length": ["155"], "Content-Type": ["application/json; charset=utf-8"], "Server": ["Microsoft-HTTPAPI/2.0"], "X-Ms-Request-Id": ["reqid"], "Iothub-Errorcode": ["ServerError"]}, "status": 500}
I downloaded caddy from Caddy website
Windows 10 Enterprise x64-based processor
caddy.exe run
Not docker installation, running Caddy directly
localhost:443 {
    reverse_proxy https://iothubname.azure-devices.net {
		header_up Authorization
			dial_timeout 10s
			response_header_timeout 30s
			tls_insecure_skip_verify
		protocols tls1.2 tls1.2
        output file caddy_access.log
Remove this stuff from your config, it doesn’t do anything useful for you.
This error is coming from your upstream app. Doesn’t look like a problem with Caddy itself. You’ll need to get help from the authors/community for your upstream app.
Thanks a lot for responding. I am able to send messages to that same IoTHub without Caddy using same channel as Postman. But when I set up Caddy and try to send messages via Caddy(using postman) then I am getting this error. This makes me think that my configuration is wrong.
Thanks
Really looking for some help on this.
Other than removing the parts Francis mentioned, I’m not sure how else we could advise you.
The 500 error isn’t from Caddy, it comes from the upstream server. You’ll need to get specific help with that app to determine what it wants/needs, if it needs something special. Caddy functions as an almost entirely transparent proxy (assuming you don’t misconfigure it).
