Caddy does not enable http3 for my site but instead HTTP2. Initially, when I was working with the same example, HTTP3 was enabled.
Runs as a service
cent os 7, systemd
caddy start
my domain {
respond "Protocol is {http.request.proto}"
reverse_proxy localhost:3000
output file /var/log/caddy/one.log
# handle vs handle_path
# handle /socket/* {
# reverse_proxy localhost:8081 # http://chat:8006/;
# handle_path /api/* {
# reverse_proxy localhost:8082
# # reverse_proxy http://apserver:3000/;
Use of HTTP/3 by browsers isn’t a guarantee. They first try connecting over TCP, and if that was fast enough, there’s no reason to try connecting over UDP.
You’d have to try using a client that only tries connecting with HTTP/3 to check. You can do that with a build of curl that includes --http3 support, but that might not be included in the build you have on your system.
You can use a docker image including curl with HTTP/3 to make a test request. Try this, with your domain instead:
$ docker run -it --rm ymuski/curl-http3 curl -vs -D/dev/stdout -o/dev/null --http3 https://caddyserver.com
* Trying 165.227.20.207:443...
* CApath: none
* subjectAltName: host "caddyserver.com" matched cert's "caddyserver.com"
* Connected to caddyserver.com (165.227.20.207) port 443 (#0)
* using HTTP/3
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: caddyserver.com]
* h2h3 [user-agent: curl/7.88.1-DEV]
* h2h3 [accept: */*]
* Using HTTP/3 Stream ID: 0 (easy handle 0x5600c27ad920)
> GET / HTTP/3
> Host: caddyserver.com
> accept: */*
< HTTP/3 200
HTTP/3 200
< content-length: 39108
< server: Caddy
server: Caddy
{ [5281 bytes data]
* Connection #0 to host caddyserver.com left intact
Okay. I will be using this method to check from now on.
But I want my site to only use http3
I also increase buffer size of my system according to this link. HTTP3 is enabled heree.
But my site still stays in http2.
Logs
2023/04/06 04:38:30.339 INFO http enabling HTTP/3 listener {"addr": ":443"}
2023/04/06 04:38:30.340 INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details.
current sysctl values
net.core.rmem_default = 212992
net.core.rmem_max = 212992
net.ipv4.tcp_rmem = 4096 87380 6291456
net.ipv4.udp_rmem_min = 4096
Okay, that’s a different question then.
You can use the servers global option to set protocols to only h3
servers {
protocols h3
Keep in mind though that this might not really be viable in production because HTTP/3 client support is still somewhat low, and the ACME TLS-ALPN challenge probably wouldn’t work because I don’t think ACME issuers connect over HTTP/3 yet (I might be wrong about that, haven’t checked lately).
Yes. I have seen this solution. Also tried, my site was not loading when I forced it to use http3. Will check once again.
But I don’t know where can I verify if ACME issuers have support for Http3
Around 4-5 days back…the eg which I tried in caddy, was showing http3. The problem started when I changed my sysctl settings. I don’t know.
I am getting this output. Just tried to run caddy as usual. haven’t seen this error before.
HTTP/3 requested for non-HTTPS URL
Make sure to use https:// in front of the URL.
My site still chooses http1.1. I dont know why. It is just a simple webpage.
* Connected to port 443 (#0)
* ALPN: offers http/1.1
} [5 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* CApath: none
{ [5 bytes data]
* TLSv1.2 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
} [1 bytes data]
{ [21 bytes data]
{ [3856 bytes data]
{ [79 bytes data]
{ [36 bytes data]
} [36 bytes data]
* ALPN: server accepted http/1.1
* subject: CN=domain
* start date: Mar 29 03:20:12 2023 GMT
* expire date: Jun 27 03:20:11 2023 GMT
* subjectAltName: host "domain" matched cert's "domain"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* using HTTP/1.1
} [5 bytes data]
> GET / HTTP/1.1
> Host: dev.test.kapil.chefgarden.asia
> User-Agent: curl/7.88.1-DEV
{ [5 bytes data]
{ [130 bytes data]
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Accept-Ranges: bytes
< Access-Control-Allow-Headers: *
< Access-Control-Allow-Methods: *
< Access-Control-Allow-Origin: *
< Alt-Svc: h3=":443"; ma=2592000
< Content-Type: text/html; charset=utf-8
< Date: Mon, 10 Apr 2023 13:40:11 GMT
< Etag: W/"11ab-cPbqkVR6PVxxrHRjFeRLF0HXHjs"
< Referrer-Policy: no-referrer-when-downgrade
< Server: Caddy
Server: Caddy
< Strict-Transport-Security: max-age=31536000; includeSubdomains; preload;
< Vary: Accept-Encoding
< X-Content-Type-Options: no sniff
< X-Frame-Options: DENY
< X-Powered-By: Express
< Transfer-Encoding: chunked
matt
(Matt Holt)
April 10, 2023, 5:27pm
10
Unfortunately we’re unable to assist further if you redact the domain name (and the command you use to connect). (See the forum rules and help template instructions)
@matt Okay. Got it.
docker run -it --rm ymuski/curl-http3 curl -vs -D/dev/stdout -o/dev/null --http3 https://dev.test.kapil.chefgarden.asia
* Trying 109.123.247.255:443...
* CApath: none
* Connected to dev.test.kapil.chefgarden.asia (109.123.247.255) port 443 (#0)
} [5 bytes data]
} [512 bytes data]
* CApath: none
{ [5 bytes data]
{ [122 bytes data]
} [1 bytes data]
{ [21 bytes data]
{ [3856 bytes data]
{ [79 bytes data]
{ [36 bytes data]
} [36 bytes data]
* subject: CN=dev.test.kapil.chefgarden.asia
* subjectAltName: host "dev.test.kapil.chefgarden.asia" matched cert's "dev.test.kapil.chefgarden.asia"
* using HTTP/1.1
} [5 bytes data]
> GET / HTTP/1.1
{ [5 bytes data]
{ [130 bytes data]
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Date: Tue, 11 Apr 2023 03:37:44 GMT
< Server: Caddy
Server: Caddy
I see HTTP/3:
$ docker run -it --rm ymuski/curl-http3 curl -vs -D/dev/stdout -o/dev/null --http3 https://dev.test.kapil.chefgarden.asia
* CApath: none
} [5 bytes data]
} [512 bytes data]
* CApath: none
* using HTTP/3
* h2h3 [:path: /]
* h2h3 [:authority: dev.test.kapil.chefgarden.asia]
* Using HTTP/3 Stream ID: 0 (easy handle 0x565150969930)
> GET / HTTP/3
> accept: */*
< HTTP/3 200
HTTP/3 200
< vary: Accept-Encoding
< date: Tue, 11 Apr 2023 13:59:14 GMT
< etag: W/"11ab-cPbqkVR6PVxxrHRjFeRLF0HXHjs"
< server: Caddy
server: Caddy
< referrer-policy: no-referrer-when-downgrade
< x-frame-options: DENY
< access-control-allow-headers: *
< x-powered-by: Express
< strict-transport-security: max-age=31536000; includeSubdomains; preload;
< accept-ranges: bytes
< access-control-allow-origin: *
< access-control-allow-methods: *
{ [2415 bytes data]
* Connection #0 to host dev.test.kapil.chefgarden.asia left intact
Does your local machine/firewall block outgoing UDP traffic?
No…There is no issue with firewall/outgoing UDP.
Thanks for your response
Well, this is definitely a “works for me” situation. I don’t know what to tell you. I can even load your site with HTTP/3. So there’s no problem with Caddy, it’s a problem with your local machine not being able to make HTTP/3 requests to your server, somehow.
matt
(Matt Holt)
April 11, 2023, 11:27pm
15
Could be a box in between you and your server blocking/dropping/degrading UDP packets. But it’s clearly working (for me too).
Another doubt I had…When I check in HTTP3check.net , I see that QUIC is not enabled. Is this an error? If yes, how can I correct it?
That website is not reliable. They only try an older draft revision of the QUIC protocol. We’ve reached out to them in the past to ask them to fix it, but they still haven’t yet.
