I wonder if someone is able to help with this issue.
v2.2.0 h1:sMUFqTbVIRlmA8NkFnNt9l7s0e+0gw+7GPIrhty905A=
systemctl start caddy
Just running on vanilla Ubuntu droplet
Here is the contents of /etc/systemd/system/caddy.service
After=network.target
When I start caddy using caddy run as the root user (the user I compiled and installed Caddy as), everything is fine. Caddy works.
When I run systemctl start caddy caddy doesn’t run. I can only presume that this is because systemctl runs caddy as the caddy user? But why might this be failing? From what I can tell, I have followed every step in the build and install instructions.
I see the following error in syslog:
Oct 4 19:52:00 systemd[1]: Started Caddy.
Oct 4 19:52:00 caddy[1299]: caddy.HomeDir=/var/lib/caddy
Oct 4 19:52:00 caddy[1299]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 4 19:52:00 caddy[1299]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 4 19:52:00 caddy[1299]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 4 19:52:00 caddy[1299]: caddy.Version=v2.2.0
Oct 4 19:52:00 caddy[1299]: runtime.GOOS=linux
Oct 4 19:52:00 caddy[1299]: runtime.GOARCH=amd64
Oct 4 19:52:00 caddy[1299]: runtime.Compiler=gc
Oct 4 19:52:00 caddy[1299]: runtime.NumCPU=1
Oct 4 19:52:00 caddy[1299]: runtime.GOMAXPROCS=1
Oct 4 19:52:00 caddy[1299]: runtime.Version=go1.14.3
Oct 4 19:52:00 caddy[1299]: os.Getwd=/
Oct 4 19:52:00 caddy[1299]: LANG=C.UTF-8
Oct 4 19:52:00 caddy[1299]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 4 19:52:00 caddy[1299]: HOME=/var/lib/caddy
Oct 4 19:52:00 caddy[1299]: LOGNAME=caddy
Oct 4 19:52:00 caddy[1299]: USER=caddy
Oct 4 19:52:00 caddy[1299]: INVOCATION_ID=ec2dcb2f46414308920590079793cf71
Oct 4 19:52:00 caddy[1299]: JOURNAL_STREAM=9:25713
Oct 4 19:52:00 caddy[1299]: {"level":"info","ts":1601841120.8948157,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 4 19:52:00 caddy[1299]: {"level":"info","ts":1601841120.8987932,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Oct 4 19:52:00 caddy[1299]: {"level":"info","ts":1601841120.8991697,"logger":"caddy.storage.redis","msg":"TLS Storage are using Redis, on 127.0.0.1:6379"}
Oct 4 19:52:00 caddy[1299]: run: loading initial config: loading new config: loading storage module: loading module 'redis': provision caddy.storage.redis: dial tcp 127.0.0.1:6379: connect: connection refused
Oct 4 19:52:00 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Oct 4 19:52:00 systemd[1]: caddy.service: Failed with result 'exit-code'.
Just running it with caddy run. I’m at a bit of a loss to be honest.
