I’m reposting this as my previous thread was hijacked by an unrelated discussion.
I’m trying to get caddy to create certificates for subdomains of a domain I own (khome.space). As recently as late July I was able to have caddy create certificates for a number of subdomains (like code.khome.space) but as of a couple of days ago caddy can’t get a certificate for photos.khome.space.
It looks like something in the stack is sending space to Porkbun as the zone to check, which is incorrect. space. is a public TLD, I can’t own it outright.
I’m using what I believe is a common image for caddy and Porkbun, the included caddy-dns/porkbun module only reads the auth keys from the caddy file, there is no special logic for parsing zones.
I checked the image history and rolled back to the version available on July 21 (which is the last date I got a new cert from Let’s Encrypt for a subdomain, code.khome.space specifically), the behavior of using space was happened with that tag too.
DNS retrieve calls to Porkbun in the terminal return the correct information, from what I can tell, so this rules out Porkbun API problems.
curl -X POST https://api.porkbun.com/api/json/v3/dns/retrieve/khome.space -d '{"apikey":"KEY","secretapikey":"SECRET"}'
"status": "SUCCESS",
"cloudflare": "enabled",
"records": [
"id": "543967828",
"name": "*.khome.space",
"type": "A",
"content": "98.110.63.44",
"ttl": "600",
"prio": "0",
"notes": ""
"id": "543968568",
"name": "khome.space",
"type": "A",
"ttl": "600",
"prio": "0",
"notes": ""
"id": "575171121",
"name": "libdns-set-address-new.khome.space",
"type": "A",
"content": "1.1.1.1",
"ttl": "900",
"prio": "0",
"notes": ""
"id": "575170213",
"name": "libdns-set-address.khome.space",
"type": "A",
"ttl": "900",
"prio": "0",
"notes": ""
"id": "543967827",
"type": "NS",
"content": "curitiba.porkbun.com",
"ttl": "86400",
"prio": null,
"notes": null
"id": "543967826",
"type": "NS",
"content": "fortaleza.porkbun.com",
"ttl": "86400",
"prio": null,
"notes": null
"id": "543967824",
"type": "NS",
"content": "maceio.porkbun.com",
"ttl": "86400",
"prio": null,
"notes": null
"id": "543967825",
"type": "NS",
"content": "salvador.porkbun.com",
"ttl": "86400",
"prio": null,
"notes": null
"id": "575171109",
"name": "libdns.set-sub-new.khome.space",
"type": "TXT",
"content": "libdns_test_modify_sub_new_txt",
"ttl": "900",
"prio": "0",
"notes": ""
"id": "575170199",
"name": "libdns.set-sub.khome.space",
"type": "TXT",
"content": "libdns_test_modify_sub_txt",
"ttl": "900",
"prio": "0",
"notes": ""
"requestId": "01a00584-3589-78fa-984d-17a04cf5ef71"
Relevant logs from caddy.
2026-08-15 12:52:11.979 error {"level":"error","ts":1786812730.707065,"logger":"tls.obtain","msg":"will retry","error":"[photos.khome.space] Obtain: [photos.khome.space] solving challenges: presenting for challenge: adding temporary record for zone \"space.\": Invalid http response status, {\"status\":\"ERROR\",\"message\":\"Invalid domain.\",\"code\":\"INVALID_DOMAIN\",\"next_action\":{\"type\":\"fix_request\",\"hint\":\"The domain name is invalid. Check the formatting.\",\"retryable\":false},\"requestId\":\"01a00656-8b78-7116-b47b-4d729fc80fc4\"} for endpoint /dns/create/space (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/288924784/46504239194) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":62.464773454,"max_duration":2592000}
2026-08-15 12:52:11.979 debug {"level":"debug","ts":1786812730.7070408,"logger":"events","msg":"event","name":"cert_failed","id":"0be473bf-cb67-4001-8bce-f9c9a1a2b639","origin":"tls","data":{"error":{},"identifier":"photos.khome.space","issuers":["acme-v02.api.letsencrypt.org-directory"],"renewal":false}}
2026-08-15 12:52:11.979 error {"level":"error","ts":1786812730.7069876,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"photos.khome.space","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[photos.khome.space] solving challenges: presenting for challenge: adding temporary record for zone \"space.\": Invalid http response status, {\"status\":\"ERROR\",\"message\":\"Invalid domain.\",\"code\":\"INVALID_DOMAIN\",\"next_action\":{\"type\":\"fix_request\",\"hint\":\"The domain name is invalid. Check the formatting.\",\"retryable\":false},\"requestId\":\"01a00656-8b78-7116-b47b-4d729fc80fc4\"} for endpoint /dns/create/space (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/288924784/46504239194) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
2026-08-15 12:52:11.979 error {"level":"error","ts":1786812730.6338983,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"photos.khome.space","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.photos.khome.space\" (usually OK if presenting also failed)"}
2026-08-15 12:52:11.978 debug {"level":"debug","ts":1786812729.943845,"logger":"tls.issuance.acme.dns_manager.dns_manager","msg":"creating DNS record","dns_name":"_acme-challenge.photos.khome.space","zone":"space.","record_name":"_acme-challenge.photos.khome","record_type":"TXT","record_data":"yxIZNwyNy7SP3WfPGoSKghz2lkdjGf_obQlgBRlh6s4","record_ttl":0}
2026-08-15 12:52:11.978 info {"level":"info","ts":1786812729.9437807,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"photos.khome.space","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
v2.11.4 h1:XKxkMTgNSizEvKG6QHue6cAsFOteU2qA61w2tKkCWi0=
I copied your compose file, included below.
image: srstone/caddy-porkbun:latest
cap_add:
- NET_ADMIN
- "443:443/udp"
- ../certs:/data
- ./config:/config
- CADDY_ADMIN=:2019
- PORKBUN_API_KEY=KEY
- PORKBUN_API_SECRET_KEY=SECRET
Synology DS923+, DSM 7.4.1-90080
Synology Container Manager
Arcane for container management
I manage this and other containers on my home lab with Arcane, though the behavior is the same if I start the container with docker compose up -d caddy.
See above.
admin :2019
acme_dns porkbun {
api_key {env.PORKBUN_API_KEY}
api_secret_key {env.PORKBUN_API_SECRET_KEY}
:2022 {
route {
caddy_admin_ui
reverse_proxy localhost:2019 {
header_up Host localhost:2019
(logging) {
format console
(debug-404) {
header X-Debug-Karpodinis-Net "testing"
respond "Not Found" 404
# Have caddy manage a certificate for my moquitto broker.
# This isn't actually a domain I'd want to have a service behind
# but I definitely want to secure communications between my zigbee
# devices and the broker.
mqtt.khome.space {
reverse_proxy :9001 http://10.0.0.34:9001
zwave.khome.space {
import logging
reverse_proxy http://10.0.0.34:8091
archive.khome.space {
import logging
reverse_proxy http://10.0.0.34:3050 {
header_down Referrer-Policy "strict-origin-when-cross-origin"
notes.khome.space {
import logging
reverse_proxy http://10.0.0.34:5230
https://chore.khome.space {
import logging
reverse_proxy http://10.0.0.34:2021
https://home.khome.space {
import logging
reverse_proxy http://10.0.0.34:3060
https://cloud.khome.space {
import logging
rewrite https://cloud.khome.space/.well-known/openid-configuration https://cloud.khome.space/index.php/apps/openidconnect/config
reverse_proxy http://10.0.0.34:5050
https://workout.khome.space {
import logging
reverse_proxy http://10.0.0.34:3005
auth.khome.space {
import logging
reverse_proxy http://10.0.0.34:9000
http://media.khome.space {
import logging
reverse_proxy http://10.0.0.34:8096
budget.khome.space {
import logging
reverse_proxy http://10.0.0.34:5006
https://fit.khome.space {
import logging
reverse_proxy http://10.0.0.34:3004
code.khome.space {
import logging
reverse_proxy http://10.0.0.34:3000
http://ha.khome.space {
import logging
reverse_proxy http://10.0.0.34:8123
http://projects.khome.space {
import logging
reverse_proxy http://10.0.0.34:3456
http://board.khome.space {
import logging
reverse_proxy http://10.0.0.34:7575
alexander.khome.space {
# Logging import, I do this everywhere
import logging
# Serve resume file
handle /resume* {
# Set the root directory for file service to my resume directory
root * /volume1/homes/Alex/resumes
# All requests satisfied by the above matcher should be rewritten to
# serve resume.pdf in the root directory
rewrite * /resume.pdf
# gzip the file before sending
# Tell the browser not to cache the file, just in case I've updated it
# This isn't great, but I don't have a reliable way to find the latest file
# from a list of files and tell the browser to download it.
# I should probably update this to map to the latest file to reduce the change
# that a caller would fail to overwrite their local copy with the server copy?
header Cache-Control "no-store"
# Tell caddy to operate like a file server
# Redirect to LinkedIn
handle /linkediin {
redir https://www.linkedin.com/in/alexander-karpodinis-31792547/ permanent
# Redirect to GitHub
handle /github {
redir https://www.github.com/akarpodinis permanent
# Block everything else
import debug-404
money.khome.space {
import logging
reverse_proxy http://10.0.0.34:52675
docker.khome.space {
import logging
reverse_proxy http://10.0.0.34:3552
telemetry.khome.space {
import logging
logging.khome.space {
import logging
reverse_proxy http://10.0.0.34:52989
games.khome.space {
import logging
reverse_proxy http://10.0.0.34:5092
photos.khome.space {
import logging
reverse_proxy http://10.0.0.34:2283
Type here
"records": [
"id": "543967828",
"type": "A",
"ttl": "600",
"prio": "0",
"notes": ""
"id": "543968568",
"type": "A",
"ttl": "600",
"prio": "0",
"notes": ""
"id": "575171121",
"type": "A",
"ttl": "900",
"prio": "0",
"notes": ""
"id": "575170213",
"type": "A",
"ttl": "900",
"prio": "0",
"notes": ""
"id": "543967827",
"type": "NS",
"ttl": "86400",
"prio": null,
"notes": null
"id": "543967826",
"type": "NS",
"ttl": "86400",
"prio": null,
"notes": null
"id": "543967824",
"type": "NS",
"ttl": "86400",
"prio": null,
"notes": null
"id": "543967825",
"type": "NS",
"ttl": "86400",
"prio": null,
"notes": null
"id": "575171109",
"type": "TXT",
"ttl": "900",
"prio": "0",
"notes": ""
"id": "575170199",
"type": "TXT",
"ttl": "900",
"prio": "0",
"notes": ""
cap_add:
- NET_ADMIN
- "443:443/udp"
- ../certs:/data
- ./config:/config
- CADDY_ADMIN=:2019
Synology DS923+, DSM 7.3.2-86009 Update 4
See above.
admin :2019
acme_dns porkbun {
:2022 {
route {
caddy_admin_ui
(logging) {
format console
(debug-404) {
mqtt.khome.space {
zwave.khome.space {
import logging
import logging
notes.khome.space {
import logging
import logging
import logging
import logging
import logging
auth.khome.space {
import logging
import logging
import logging
import logging
code.khome.space {
import logging
import logging
import logging
import logging
import logging
# Serve resume file
handle /resume* {
handle /linkediin {
handle /github {
import debug-404
money.khome.space {
import logging
import logging
import logging
import logging
games.khome.space {
import logging
import logging
Type here
