I’ve tried with
and
v2.4.0-beta.1 h1:Ed/tIaN3p6z8M3pEiXWJL/T8JmCqV62FrSJCHKquW/I=
Using brew services with this plist
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>KeepAlive</key>
<true/>
<key>Label</key>
<string>homebrew.mxcl.caddy</string>
<key>ProgramArguments</key>
<array>
<string>/usr/local/opt/caddy/bin/caddy</string>
<string>run</string>
</array>
<key>RunAtLoad</key>
<true/>
<key>StandardOutPath</key>
<string>/usr/local/var/log/caddy.log</string>
<key>StandardErrorPath</key>
</dict>
</plist>
brew services start caddy
Mac OSX 11.2.1, 2019 Macbook Pro
curl http://localhost:2019/config/
"apps": {
"http": {
"servers": {
"cloud": {
"listen": [
":443",
":80"
"routes": [
"handle": [
"handler": "acme_server"
"handler": "reverse_proxy",
"transport": {
"protocol": "http"
"upstreams": [
"dial": ":1337"
"match": [
"host": [
"thing.local.lifx.co"
"tls": {
"automation": {
"policies": [
"issuers": [
"ca": "https://step-ca.local.lifx.co:666/acme/acme/directory",
"module": "acme"
"subjects": [
For the purposes of this test, I’m running python -m http.server 1337
When I try something like
step ca certificate "thing.local.lifx.co" server.crt server.key --provisioner acme
It tries to do a GET on http://thing.local.lifx.co/.well-known/acme-challenge/QX2K0JYcvPC22mimNh0MqWkDScoXoSFq and Caddy passes it onto the reverse_proxy
As far as I can tell, Caddy should be catching this before my reverse_proxy and returning information that is then given to step-ca.
Caddy will repeat this line
"level": "error",
"ts": 1613909043.799864,
"logger": "tls.issuance.acme",
"msg": "looking up info for HTTP challenge",
"host": "thing.local.lifx.co",
"error": "no information found to solve challenge for identifier: thing.local.lifx.co"
And step will say
time="2021-02-21T23:04:03+11:00"
level=info
duration=4.640762ms
duration-ns=4640762
fields.time="2021-02-21T23:04:03+11:00"
method=POST
name=ca
nonce=ZEFGQnNnMU9DUUJYczZCU29jWTZqdzRMN1ZWSlRGNUY
path=/acme/acme/challenge/hHdanv3Ag6hOgIUPVKwmx9WptnYphdc6
protocol=HTTP/2.0
referer=
remote-address=127.0.0.1
request-id=c0p4ocucie6ggdsqtq1g
response="{\"type\":\"http-01\",\"status\":\"pending\",\"token\":\"QX2K0JYcvPC22mimNh0MqWkDScoXoSFq\",\"url\":\"https://step-ca.local.lifx.co:666/acme/acme/challenge/hHdanv3Ag6hOgIUPVKwmx9WptnYphdc6\",\"error\":{\"type\":\"urn:ietf:params:acme:error:connection\",\"detail\":\"error doing http GET for url http://thing.local.lifx.co/.well-known/acme-challenge/QX2K0JYcvPC22mimNh0MqWkDScoXoSFq with status code 404\"}}"
size=381
status=200
user-agent=Go-http-client/2.0
user-id=
And the server will say
::ffff:127.0.0.1 - - [21/Feb/2021 23:04:03] code 404, message File not found
::ffff:127.0.0.1 - - [21/Feb/2021 23:04:03] "GET /.well-known/acme-challenge/QX2K0JYcvPC22mimNh0MqWkDScoXoSFq HTTP/1.1" 404 -
I spent a couple hours desperately googling .well-known and acme-challenge and related things and afaict it should “just work” and yet caddy doesn’t seem to recognise this path.
If I tell the reverse_proxy to ignore this path, then caddy will just return an empty reply and I get similar problems.
