Ello,
I use Caddy as a reverse proxy, but it isn’t responding to any of my requests anymore. It connects, but times out on http, but won’t even connect to https. This is a recent issue, and I’m not quite sure what is happening
C:\Users\lawso>curl -vL thatrandompi.xyz
* Host thatrandompi.xyz:80 was resolved.
* IPv6: (none)
* IPv4: 144.6.98.26
* Trying 144.6.98.26:80...
* Connected to thatrandompi.xyz (144.6.98.26) port 80
> GET / HTTP/1.1
> Host: thatrandompi.xyz
> User-Agent: curl/8.9.1
* Request completely sent off
* Recv failure: Connection was reset
* closing connection #0
curl: (56) Recv failure: Connection was reset
C:\Users\lawso>curl -vL https://thatrandompi.xyz
* Host thatrandompi.xyz:443 was resolved.
* IPv6: (none)
* IPv4: 144.6.98.26
* Trying 144.6.98.26:443...
* connect to 144.6.98.26 port 443 from 0.0.0.0 port 18210 failed: Timed out
* Failed to connect to thatrandompi.xyz port 443 after 21078 ms: Could not connect to server
curl: (28) Failed to connect to thatrandompi.xyz port 443 after 21078 ms: Could not connect to server
caddy | {"level":"info","ts":1729639571.4709463,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
caddy | {"level":"warn","ts":1729639571.4714034,"logger":"caddyfile","msg":"Unnecessary header_up X-Forwarded-For: the reverse proxy's default behavior is to pass headers to the upstream"}
caddy | {"level":"warn","ts":1729639571.471412,"logger":"caddyfile","msg":"Unnecessary header_up X-Forwarded-Proto: the reverse proxy's default behavior is to pass headers to the upstream"}
caddy | {"level":"info","ts":1729639571.4730887,"msg":"adapted config to JSON","adapter":"caddyfile"}
caddy | {"level":"warn","ts":1729639571.4731326,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy | {"level":"info","ts":1729639571.474466,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
caddy | {"level":"info","ts":1729639571.4748147,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004b2c80"}
caddy | {"level":"info","ts":1729639571.4749014,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1729639571.4749603,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"warn","ts":1729639571.475005,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
caddy | {"level":"info","ts":1729639571.476195,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy | {"level":"info","ts":1729639571.4766748,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1729639571.4769409,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1729639571.4769833,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["thatrandompi.xyz","premiers.thatrandompi.xyz","mail.thatrandompi.xyz","hass.thatrandompi.xyz","ssh.thatrandompi.xyz","testing.thatrandompi.xyz","docker.thatrandompi.xyz","flame.thatrandompi.xyz","notlawson.thatrandompi.xyz","absentee.thatrandompi.xyz"]}
caddy | {"level":"info","ts":1729639571.4810016,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1729639571.4812045,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1729639571.4811532,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"620455d3-e964-4394-af8a-3335d7c65628","try_again":1729725971.4811513,"try_again_in":86399.999999577}
caddy | {"level":"info","ts":1729639571.4813263,"logger":"tls","msg":"finished cleaning storage units"}
2.8.4 is the version in my Dockerfile
Custom Docker image, in Docker compose. Ubuntu.
FROM caddy:2.8.4-builder AS builder
RUN xcaddy build \
--with github.com/aksdb/caddy-cgi/v2
FROM caddy:2.8.4
We use a Google WiFi Mesh
docker compose up -d
build: .
network_mode: host
privileged: true
restart: always
- caddy_data:/data
- caddy_config:/config
- /home/server_files/notlawson/server_files/homepage:/usr/homepage
- /home/server_files/notlawson/sever_files/sites:/usr/sites
caddy_data:
caddy_config:
order cgi before respond
notlawson.thatrandompi.xyz {
root * /usr/homepage
thatrandompi.xyz {
respond "Caddy is online"
hass.thatrandompi.xyz {
reverse_proxy localhost:8123 {
header_up Host {host}
header_up X-Forwarded-For {remote_host}
ssh.thatrandompi.xyz {
reverse_proxy localhost:8182
testing.thatrandompi.xyz {
reverse_proxy localhost:5000
mail.thatrandompi.xyz {
redir https://thatrandompi.xyz
docker.thatrandompi.xyz {
reverse_proxy https://localhost:9443 {
tls_insecure_skip_verify
absentee.thatrandompi.xyz {
reverse_proxy localhost:5052
http://watchtower.thatrandompi.xyz {
reverse_proxy localhost:8900
premiers.thatrandompi.xyz {
cgi /update /home/notlawson/server_files/premiers/update.sh
flame.thatrandompi.xyz {
reverse_proxy localhost:5005
Not really sure, sorry.
I can connect to my server while on my home network just fine, just externally it fails.
My router is port forwarding the respective ports (80, 443), but an open port checker shows that there is only the SSH port open.
Thanks in advance,
Lawson
