2.1.1
/usr/bin/caddy run --config /opt/app-root/etc/Caddyfile
Docker
b. My Config
# Where caddy should listen
:2015
# Turn on the Web/file server
templates
# The site root
root * /opt/app-root/src
# Because we should
encode zstd gzip
# This rewrite rule may be required to get React apps
# to deal with trailing slashes properly.
#@filter {
# not path_regexp ^\/0.0.0.0
# file {
# try_files {path} {path}/ /?url={uri}
#rewrite @try_files {http.matchers.file.relative}
# On OCP we should log to stdout so Prometheus can
# slurp up the logs for human consumption.
#errors stdout
output stdout
level info
Caddy does not seem to be replacing the template {{env "MY_ENV_VAR"}} in .js files. Use to work fine with the old Caddy v1 with {{.env.MY_ENV_VAR}}.
