1. Output of caddy version:
(I’m using one of the built ones for duckdns compatibility)
Ubuntu Server 20.04 (could be 22?), running on the server not on Docker. Systemd starts and stops caddy as needed.
sudo systemctl start caddy
sudo systemctl restart caddy
Description=Caddy Server Startup
ExecStart=/usr/bin/bash /etc/caddy/caddystart.sh
subd.duckdns.org {
output file /var/lib/caddy/caddy.log
file_server browse
dns duckdns {env.DUCKDNS_API_KEY}
192.168.1.100:1832 {
file_server browse
(the second directive is just for testing to make sure it is actually pulling a server up/listening. Not actually needed)
I’m trying to setup DuckDNS to have a domain I can access externally. When I curl -v subd.duckdns.org though, it entirely times out and I cannot figure out why.
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4337976,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"warn","ts":1666907307.4356751,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":14}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4367824,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4371047,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4371262,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv1","https_port":443}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4371347,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4372017,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000251260"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4377127,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4388268,"logger":"tls","msg":"finished cleaning storage units"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4543984,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4546928,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.454734,"logger":"http","msg":"enabling HTTP/3 listener","addr":":1832"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4549508,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4550729,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4551122,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.455192,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4552002,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["192.168.1.100","homehosted.duckdns.org"]}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"warn","ts":1666907307.455622,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [192.168.1.100]: no OCSP server specified in certificate","identifiers":["192.168.1.100"]}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4571497,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 27 21:48:27 homesrv caddy[170813]: {"level":"info","ts":1666907307.4572194,"msg":"serving initial configuration"}
Oct 27 21:53:32 homesrv caddy[170813]: {"level":"info","ts":1666907612.5953991,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"183.158.76.24","remote_port":"36008","proto":"HTTP/1.0","method":"GET","host":"","uri":"/boaform/admin/formLogin?username=ec8&psd=ec8","headers":{}},"user_id":"","duration":0.000101655,"size":0,"status":308,"resp_headers":{"Server":["Caddy"],"Connection":["close"],"Location":["https:///boaform/admin/formLogin?username=ec8&psd=ec8"],"Content-Type":[]}}
And my curl command:
* Trying 1.2.3.4:443...
* connect to 1.2.3.4 port 443 failed: Connection timed out
* Failed to connect to subd.duckdns.org port 443 after 130223 ms: Connection timed out
* Closing connection 0
curl: (28) Failed to connect to subd.duckdns.org port 443 after 130223 ms: Connection timed out
I’ve already tried a myriad of things, including nmap scans to make sure the port is open (it is) as well as making sure my VPN doesn’t conflict with the port forwarding. I use Mullvad VPN and have followed their guide to set nftables rules to allow some traffic to go through my home domain.
The caddy “Get Started” page
None of this will be relevant; view my first comment on this post.
