In short
I’m trying to use a s3 storage module with caddy
Example Caddyfile like
storage s3 {
bucket caddy
region us-gov-west-1
But I keep getting this error
Error: adapting config using caddyfile: parsing caddyfile tokens for 'storage': wrong argument count or unexpected line ending after <storage s3 line number>
Note: I’ve tried this with the s3 module by certmagic and it didn’t work either so I tried rolling my own and naming it sthree instead of s3 because I was worried about an issue with parsing numbers but that doesn’t seem to be the case either. My s3 module, heavily borrowed from certmagic’s, is here GitHub - owens3364/caddy-s3: Super basic dead simple S3 storage module for use with Caddy but I don’t believe that is the issue since I get the same error with both storage modules.
And my full Caddyfile is pasted below.
Built with 2.10.2
sh-5.2$ ./caddy version
Linux arm64 t4g.micro AWS EC2 Instance with proper IAM roles and networking for S3 access.
I don’t use a run command, just a service, however
build command
# build-caddy.sh
#!/bin/bash
set -euxo pipefail
GOOS=linux GOARCH=arm64 ~/go/bin/xcaddy build \
--with github.com/corazawaf/coraza-caddy/v2 \
--with github.com/caddy-dns/route53@v1.6.0-beta.1 \
--with github.com/caddyserver/cache-handler \
--with github.com/darkweak/storages/otter/caddy \
--with github.com/mholt/caddy-ratelimit \
--with github.com/owens3364/caddy-s3@cbaf3df
Additional info - caddy binary lives at /usr/local/bin/caddy on the machine and Caddyfile and env vars are in /etc/caddy/Caddyfile and /etc/caddy/caddy.env, respectively.
Description=Caddy Web Server
After=network.target
EnvironmentFile=/etc/caddy/caddy.env
ExecStart=/usr/local/bin/caddy run --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile
Restart=always
User=root
Group=root
admin off
email {$GHES_SUPPORT_EMAIL}
order coraza_waf first
order cache before rewrite
output file /var/log/caddy/coraza.log
format json
level info
include "http.handlers.waf"
storage sthree {
bucket {$S3_BUCKET_NAME}
region {$S3_BUCKET_REGION}
(waf) {
coraza_waf {
load_owasp_crs
directives `
Include @coraza.conf-recommended
Include @crs-setup.conf.example
Include @owasp_crs/*.conf
SecDefaultAction "phase:3,log,auditlog,pass"
SecDefaultAction "phase:4,log,auditlog,pass"
SecDefaultAction "phase:5,log,auditlog,pass"
SecRuleEngine On
SecAuditEngine On
SecAuditLogParts ABIJDEFHZ
SecAuditLog /var/log/caddy/modsec_audit.log
SecAuditLogFormat json
SecResponseBodyAccess On
SecRequestBodyLimit 52428800
SecRequestBodyNoFilesLimit 1048576
SecRequestBodyInMemoryLimit 1048576
SecRule REQUEST_COOKIES:_fi_sess ".*" "id:100001,phase:1,pass,nolog,ctl:ruleRemoveTargetById=942100;REQUEST_COOKIES:_fi_sess"
SecRule GEO:COUNTRY_CODE "!@eq US" "id:100002,phase:1,deny,status:403,log,auditlog,msg:'Non-US Blocked'"
SecRule REQUEST_URI "@beginsWith /git-upload-pack" "phase:2,nolog,pass,ctl:requestBodyLimit=262144000"
handle_errors 403 {
header X-Blocked "true"
respond "Your request was blocked. Request ID: {http.request.uuid}"
{$GHES_DOMAIN}, *.{$GHES_DOMAIN} {
rate_limit {
zone individual {
key {remote_host}
window 10s
events 5000
zone overall {
key static
window 1m
events 30000
import waf
dns route53 {
region {$GHES_DOMAIN_REGION}
reverse_proxy {$GHES_PRIVATE_URL} {
tls_insecure_skip_verify
header_up X-Forwarded-Proto https
@assets host {$GHES_CACHEABLE_SUBDOMAIN}.{$GHES_DOMAIN}
cache {
allowed_http_verbs GET
otter
ttl 24h
timeout {
backend 10s
cache 10ms
X-Frame-Options "DENY"
Referrer-Policy "no-referrer"
Other Notes
- I’ve validated that Caddy has all the env vars and have tried harcoding them with and without quotes.
- I’ve tried all kinds of variations of
storage s3- putting it outside the globals, doing storage.s3, doing storage { s3 { // inner settings } } (with proper line formatting) - everything I could think of. Also triedsthreefor all this instead ofs3.
This seems to be a super weird error and I can’t figure out what’s causing it.
Caddy list-modules
sh-5.2$ ./caddy list-modules
admin.api.load
admin.api.metrics
admin.api.pki
admin.api.reverse_proxy
caddy.adapters.caddyfile
caddy.config_loaders.http
caddy.filesystems
caddy.listeners.http_redirect
caddy.listeners.proxy_protocol
caddy.listeners.tls
caddy.logging.cores.mock
caddy.logging.encoders.append
caddy.logging.encoders.console
caddy.logging.encoders.filter
caddy.logging.encoders.filter.cookie
caddy.logging.encoders.filter.delete
caddy.logging.encoders.filter.hash
caddy.logging.encoders.filter.ip_mask
caddy.logging.encoders.filter.query
caddy.logging.encoders.filter.regexp
caddy.logging.encoders.filter.rename
caddy.logging.encoders.filter.replace
caddy.logging.encoders.json
caddy.logging.writers.discard
caddy.logging.writers.file
caddy.logging.writers.net
caddy.logging.writers.stderr
caddy.logging.writers.stdout
caddy.network_proxy.none
caddy.network_proxy.url
caddy.storage.file_system
events
http
http.authentication.hashes.bcrypt
http.authentication.providers.http_basic
http.encoders.gzip
http.encoders.zstd
http.handlers.acme_server
http.handlers.authentication
http.handlers.copy_response
http.handlers.copy_response_headers
http.handlers.encode
http.handlers.error
http.handlers.file_server
http.handlers.headers
http.handlers.intercept
http.handlers.invoke
http.handlers.log_append
http.handlers.map
http.handlers.metrics
http.handlers.push
http.handlers.request_body
http.handlers.reverse_proxy
http.handlers.rewrite
http.handlers.static_response
http.handlers.subroute
http.handlers.templates
http.handlers.tracing
http.handlers.vars
http.ip_sources.static
http.matchers.client_ip
http.matchers.expression
http.matchers.file
http.matchers.header
http.matchers.header_regexp
http.matchers.host
http.matchers.method
http.matchers.not
http.matchers.path
http.matchers.path_regexp
http.matchers.protocol
http.matchers.query
http.matchers.remote_ip
http.matchers.tls
http.matchers.vars
http.matchers.vars_regexp
http.precompressed.br
http.precompressed.gzip
http.precompressed.zstd
http.reverse_proxy.selection_policies.client_ip_hash
http.reverse_proxy.selection_policies.cookie
http.reverse_proxy.selection_policies.first
http.reverse_proxy.selection_policies.header
http.reverse_proxy.selection_policies.ip_hash
http.reverse_proxy.selection_policies.least_conn
http.reverse_proxy.selection_policies.query
http.reverse_proxy.selection_policies.random
http.reverse_proxy.selection_policies.random_choose
http.reverse_proxy.selection_policies.round_robin
http.reverse_proxy.selection_policies.uri_hash
http.reverse_proxy.selection_policies.weighted_round_robin
http.reverse_proxy.transport.fastcgi
http.reverse_proxy.transport.http
http.reverse_proxy.upstreams.a
http.reverse_proxy.upstreams.multi
http.reverse_proxy.upstreams.srv
pki
tls
tls.ca_pool.source.file
tls.ca_pool.source.http
tls.ca_pool.source.inline
tls.ca_pool.source.pki_intermediate
tls.ca_pool.source.pki_root
tls.ca_pool.source.storage
tls.certificates.automate
tls.certificates.load_files
tls.certificates.load_folders
tls.certificates.load_pem
tls.certificates.load_storage
tls.client_auth.verifier.leaf
tls.ech.publishers.dns
tls.get_certificate.http
tls.get_certificate.tailscale
tls.handshake_match.local_ip
tls.handshake_match.remote_ip
tls.handshake_match.sni
tls.handshake_match.sni_regexp
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.leaf_cert_loader.file
tls.leaf_cert_loader.folder
tls.leaf_cert_loader.pem
tls.leaf_cert_loader.storage
tls.permission.http
tls.stek.distributed
tls.stek.standard
Standard modules: 127
admin.api.souin
cache
caddy.storage.sthree
dns.providers.route53
http.handlers.cache
http.handlers.rate_limit
http.handlers.waf
storages.cache.otter
Non-standard modules: 8
Unknown modules: 0
Lastly
If anyone wants to give feedback on my actual Caddyfile configuration I’d appreciate that. I’ve never done this before so while I believe it’s all right maybe there’s a better way.
Thanks for the assistance!
