Docker version 19.03.11, build 42e35e61f3
docker-compose version 1.17.1, build unknown
sudo docker-compose -f docker-compose-base.yml up
Dockerfile:
FROM caddy:2-builder AS builder
RUN xcaddy build \
--with github.com/caddy-dns/route53
FROM caddy:2
Docker compose file:
version: "3"
node:
image: "node:12"
working_dir: /home/node/app
- ./:/home/node/app
command: "node serv.js"
env_file:
- .env
build: .
- caddy_data:/data
- caddy_config:/config
caddy_data:
caddy_config:
email email@example.com
*.{$WILDCARD_DOMAIN} {
dns route53 {
max_retries 10
reverse_proxy {$ELB_HOST} {
header_up +codomain {host}
reverse_proxy /app* {$ELB_HOST} {
header_up +service admin-ui
reverse_proxy /embed* {$ELB_HOST} {
header_up +codomain {host} # TODO: remove codomain since host gets passed through
header_up +service embed
uri /app/_next* strip_prefix /app
uri /app/static* strip_prefix /app
output stdout
For this request https://app.{$WILDCARD_DOMAIN}.com/app/_next/static/runtime/main-87b364dedc78de6f0c78.js no service header get set.
I expect service header to be set to admin-ui for the backend server.
These are headers I received in my node app:
host: 'app.{$WILDCARD_DOMAIN}.com',
'user-agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:84.0) Gecko/20100101 Firefox/84.0',
accept: 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8',
'accept-encoding': 'gzip, deflate, br',
'accept-language': 'en-US,en;q=0.5',
'cache-control': 'max-age=0',
codomain: 'app.{$WILDCARD_DOMAIN}.com',
cookie: 'REDACTED',
te: 'trailers',
'upgrade-insecure-requests': '1',
'x-forwarded-for': 'REDACTED IP',
'x-forwarded-proto': 'https'
It appears it’s matching reverse_proxy with the implicit wildcard due to the uri directive because when I comment out the following, it doesn’t even send traffic to the backend:
I’m not sure how to get around that.
