Caddy not obtaining cert when using custom ACME server
We run an internal ACME CA and internal web services available to employees on our network (i.e. not exposed to the public internet, and not using globally resolvable FQDNs).
The internal ACME server has existed for a while and many internal apps are using it using other ACME clients (win-acme, cert bot etc).
We have a new app deployment that has been in testing/development for a while using either http or self-signed certs, and we are in the process of sorting out certs and final config management before going live.
Attempting to get Caddy integrated with our internal ACME infra has led to us getting a crash-bug.
Expected behavior:
Caddy on start would attempt to get a certificate from the ACME server, and if successful allow the website to be accessed while presenting the certificate. If unsuccessful, it should continue running (not crash), and log an error.
Observed Behavior:
When Caddy is launched with a config that would cause it to request a cert from the internal CA, it immediately crashes.
Troubleshooting step 1
Adding “tls internal” to the website config
Expected Behaviour:
Caddy would generate a self signed cert, run and allow the website to be accessed with an untrusted cert warning.
Observed Behavior:
Caddy operates as expected and website can be accessed, with an untrusted cert warning.
Troubleshooting step 2
Removing custom ACME directives from Caddyfile
Expected Behavior:
Caddy on start would attempt to get a certificate from a public ACME server (i.e. lets encrypt), fail as there is no public DNS record for the server website name and the server is not publicly exposed. Caddy would log this process, handle the error and continue running, however the website won’t be available.
Observed Behavior:
Caddy operates as expected, logs show the attempt and failure to get the cert.
Troubleshooting step 3
Replacing acme_ca with https://fake.com/Directory
Expected Behavior:
Caddy on start would attempt to get a certificate from the configured ACME server, fail as no such CA exists. Caddy would log this process, handle the error and continue running, however the website won’t be available.
Observed Behavior:
Yes, our lab/test network uses Contoso as a domain because we’re a mostly Windows/Microsoft shop. This gets swapped to a real domain using Hierra in prod.
Result of systemctl status caddy
    Process: 252398 ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile (code=exited, status=0/SUCCESS)
    Process: 252403 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
   Main PID: 252403 (code=exited, status=1/FAILURE)
     Status: "loading new config: http app module: start: finalizing automatic HTTPS: managing certificates for [mbcinstweblab04.managed.contoso.com.au]: automate: manage [mbcinstweblab04.managed.contoso.com.au]: mbcinstweblab04.managed.contoso.com.au: caching certificate: certificate has no names
        CPU: 93ms
Logs after restarting the systemd service.
tail -n 20 /var/log/caddy/caddy.log
{"level":"info","ts":1744324945.9093757,"msg":"serving initial configuration"}
{"level":"info","ts":1744324979.7846282,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1744324979.784707,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1744324979.7849,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0000293b0"}
{"level":"info","ts":1744324979.7849376,"logger":"admin","msg":"stopped previous server","address":":2019"}
{"level":"info","ts":1744324979.7849438,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1744324979.844852,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1744324979.8449085,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1744324979.8451698,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002e0cb0"}
{"level":"info","ts":1744324979.845179,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002e0cb0"}
{"level":"info","ts":1744324979.898288,"logger":"admin","msg":"admin endpoint started","address":":2019","enforce_origin":true,"origins":["//localhost"]}
{"level":"warn","ts":1744324979.8983526,"logger":"admin","msg":"admin endpoint on open interface; host checking disabled","address":":2019"}
{"level":"info","ts":1744324979.898535,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1744324979.8985467,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1744324979.89882,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1744324979.8990006,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1744324979.8990371,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1744324979.899042,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["mbcinstweblab04.managed.contoso.com.au"]}
{"level":"info","ts":1744324979.8994277,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002893b0"}
{"level":"info","ts":1744324979.8994398,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002893b0"}
Custom Puppet module that pulls from EPEL repo.
Result of dnf info caddy:
Installed Packages
Version      : 2.6.4
Release      : 2.el9
Architecture : x86_64
Source       : caddy-2.6.4-2.el9.src.rpm
Repository   : @System
From repo    : epel
Summary      : Web server with automatic HTTPS
URL          : https://caddyserver.com
License      : Apache-2.0 AND BSD-2-Clause AND BSD-3-Clause AND MIT AND BSD-2-Clause-Views AND ISC AND CC0-1.0 AND MPL-2.0
Description  : Caddy is the web server with automatic HTTPS.
Run using SystemD
Alma 9
systemctl restart caddy
 systemctl cat caddy
# /usr/lib/systemd/system/caddy.service
# caddy.service
Description=Caddy web server
After=network.target
Type=notify
ProtectHome=true
# THIS FILE IS MANAGED BY PUPPET
  http_port 80
  https_port 443
  admin :2019 {
  origins localhost
  enforce_origin
  persist_config off
  log default {
  output file /var/log/caddy/caddy.log {
    roll_size 100MiB
    roll_keep 10
    roll_local_time
  acme_ca https://contosoca04.contoso.com.au/acme/contoso-acme-internal/directory
import Caddyfile.d/*.conf
https://mbcinstweblab04.managed.contoso.com.au {
#      tls internal
      root * /opt/redmine/public
      @notStatic {
            not file
      reverse_proxy @notStatic localhost:3000
N/A
It’s not crashing. It refuses to run because the certificate it receives from you ACME server is invalid. How is Caddy supposed to run with an invalid certificate for the domain name it’s managing? What certificate should it present? There’s no good way for Caddy to run if the CA gives it an invalid certificate as Caddy is booting.
I believe this reveals a bug in your internal ACME server. Can you check if the generated certificates have names? I think the openssl command is openssl x509 -in <cert_pem_file> -noout -text.
I think you’re correct, the cert has an empty subject and the SANs field.
The ACME server is Step CA, so I might need to investigate why that is returning ‘blank’ certs. The certs .json file in the Caddy. local folder only lists a SAN and not a Subject, so I wonder if Step-CA is not processing signing requests that omit the subject name.
Caddy should still handle it gracefully rather than crashing the entire process.
Again, it’s not crashing, rather refusing to run with broken data. Tell me what do you expect Caddy to do? I’m serious, because there’s no way for Caddy to proceed its operations and serve the site when the cert is completely unusable.
The behaviour is different to what happens in other scenarios i.e, if Caddy fails to get a cert at all. If it fails to get a cert, (i.e if acme_ca is set to https://notaRealCA.fake/Directoy), then Caddy gracefully handles the error - the affected website is not served, however the Caddy process continues to run and other configured sites continue to work.
I’m not disagreeing that the affected site shouldn’t be served if the cert is invalid invalid, but the entire process stopping and impacting other configured sites is not expected behaviour.
