I’m trying to reverse proxy Ombi V3. It loads the page but doesn’t show any content. It just loads the background. any ideas that may cause this?
proxy /ombi 192.168.1.17:5000 {
Have you configured Ombi’s Base URL setting to /ombi
A common problem is having this set to something other than what you’re using as the proxy base path in Caddy, which would cause Ombi to link to assets (JS, CSS, images) outside of /ombi
(which would likely be 404’d by Caddy, breaking the site).
This is what I added to my Caddy file for Ombi.
rewrite / {
r ^/dist/([0-9\d*]).js
to /ombi/dist/{1}.js
Can confirm this rewrite worked for me
Solid copy
I’m having similar issues with a few similar apps I’m trying to reverse proxy to, would something like this help for the following?
Organizr
Mylar
Tautulli
Pi-Hole
Portainer
An example of what I’m seeing is below
Log snippet
172.10.0.1 - - [12/Apr/2018:10:58:27 +0000] "GET /organizr HTTP/2.0" 200 11610
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/bootstrap/dist/css/bootstrap.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/font-awesome/css/font-awesome.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/mdi/css/materialdesignicons.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/selects/cs-select.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/selects/cs-skin-elastic.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/Waves/dist/waves.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/metisMenu/dist/metisMenu.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/google-material-color/dist/palette.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/malihu-custom-scrollbar-plugin/jquery.mCustomScrollbar.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/smoke/dist/css/smoke.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/notifications/ns-style-other.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/notifications/ns-style-growl.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/sweetalert/dist/sweetalert.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/sha1.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/user.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /css/style.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /css/weather-icons.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/animate.css/animate.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /css/addtohomescreen.css HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/addtohomescreen.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/menu/modernizr.custom.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/push.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/ajax.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /images/organizr-load-w-thick.gif HTTP/2.0" 404 14
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/jquery/dist/jquery.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/bootstrap/dist/js/bootstrap.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/metisMenu/dist/metisMenu.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/Waves/dist/waves.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/moment/min/moment.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/jquery.nicescroll/jquery.nicescroll.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/slimScroll/jquery.slimscroll.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/malihu-custom-scrollbar-plugin/jquery.mCustomScrollbar.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/cta/dist/cta.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/menu/classie.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/menu/gnmenu.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/selects/selectFx.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/sweetalert/dist/sweetalert.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /bower_components/smoke/dist/js/smoke.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/notifications/notificationFx.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/common.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/mousetrap.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/jquery.simpleWeather.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:28 +0000] "GET /js/jquery.mousewheel.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /js/sha1.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /js/user.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /css/style.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /css/weather-icons.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /css/addtohomescreen.css HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /js/addtohomescreen.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /bower_components/animate.css/animate.min.css?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /js/push.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:29 +0000] "GET /js/ajax.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/jquery/dist/jquery.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/bootstrap/dist/js/bootstrap.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/metisMenu/dist/metisMenu.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/Waves/dist/waves.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/moment/min/moment.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/jquery.nicescroll/jquery.nicescroll.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/slimScroll/jquery.slimscroll.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/malihu-custom-scrollbar-plugin/jquery.mCustomScrollbar.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/cta/dist/cta.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/menu/classie.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/menu/gnmenu.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/selects/selectFx.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/sweetalert/dist/sweetalert.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /bower_components/smoke/dist/js/smoke.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/notifications/notificationFx.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/common.js?v=1.75 HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/mousetrap.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/jquery.simpleWeather.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:30 +0000] "GET /js/jquery.mousewheel.min.js HTTP/2.0" 404 38
172.10.0.1 - - [12/Apr/2018:10:58:35 +0000] "GET /images/favicon/favicon-32x32.png HTTP/2.0" 404 14
172.10.0.1 - - [12/Apr/2018:10:58:35 +0000] "GET /images/favicon/favicon-16x16.png HTTP/2.0" 404 14
172.10.0.1 - - [12/Apr/2018:10:58:35 +0000] "GET /images/favicon/android-chrome-192x192.png HTTP/2.0" 404 14
172.10.0.1 - - [12/Apr/2018:10:58:35 +0000] "GET /images/favicon/favicon.ico HTTP/2.0" 404 14
full Caddyfile
# Snippets
####### Snippet 1 #######
(mycommon) {
ext .html .htm .php
root /srv # Change path syntax for your OS or your preferred location!
gzip
header / {
####### Snippet 2 #######
(mylocations) {
# This code allows your browser/server to look at Organizr and verify if the currently logged in user's status is
# admin, user, or neither. This is based on assigned group in Organizer's "Manage users" tab
# Admin allows users to see Admin, User, and guest pages
# User allows a user to see User and Guest pages.
# Guest pages should not be assigned to either of these options.
# each page should only be present in ONE of the blocks if auth is required.
proxy /auth-admin https://sub.domain.com/Organizr/auth.php?admin
proxy /auth-user https://sub.domain.com/Organizr/auth.php?user
# this is where the protection happens. there is one call for users and one for admins
reauth {
path /sonarr # protect what i have set a proxy to be called /sonarr
path /radarr
path /lidarr
path /mylar
path /lazy
path /nzbget
path /hydra2
path /pihole
path /portainer
# if someone is not authorized for a page, send them here instead of allowing them through to the intended page
failure redirect target=https://sub.domain.com/organizr
# The above listed directories with be pretected from anyone not listed in Organizr as an Admin
upstream url=https://sub.domain.com/auth-admin,cookies=true
# This bracket does the same as the above annotated bracket but the minimum required group is User
reauth {
path /ombi
path /tautulliFN
path /tautulliSK
upstream url=https://sub.domain.com/auth-user,cookies=true
proxy /QNAP 172.10.0.1:8080 { # PARTIALLY WORKING
without /QNAP
proxy /organizr 172.10.0.12:80 { #https://organizr.us/ PARTIALLY WORKING
without /organizr
proxy /radarr 172.10.0.4:7878 { # https://radarr.video/
proxy /sonarr 172.10.0.5:8989 { # https://sonarr.tv/
proxy /lidarr 172.10.0.6:8686 { # https://github.com/lidarr/Lidarr
proxy /mylar 172.10.0.8:8090/home { # https://github.com/evilhero/mylar PARTIALLY WORKING
without /mylar
proxy /lazy 172.10.0.7:5299 { # https://github.com/DobyTang/LazyLibrarian
proxy /nzbget 172.10.0.3:6789 { # http://nzbget.net/
proxy /hydra2 172.10.0.2:5076 { # https://github.com/theotherp/nzbhydra2
proxy /ombi 172.10.0.10:3579 { # https://github.com/tidusjar/Ombi NOT WORKING
proxy /tautulliFN 172.10.0.13:8181/home { # http://tautulli.com/ PARTIALLY WORKING
without /tautulliFN
proxy /tautulliSK 172.10.0.14:8181/home { # http://tautulli.com/ PARTIALLY WORKING
without /tautulliSK
proxy /pihole 172.10.0.11:80/admin/index.php { # https://pi-hole.net/ PARTIALLY WORKING
without /pihole
proxy /portainer 172.10.0.20:9000 { # https://portainer.io/ PARTIALLY WORKING
without /portainer
# The code below will proxy PHP requests
fastcgi / 127.0.0.1:9000 php # php variant only
# web domain server block
sub.domain.com {
tls email@address.com { # Email for Let's Encrypt Verification
max_certs 10
log /srv/logs/access.log {
rotate_size 1 # Rotate after 1 MB
rotate_age 7 # Keep log files for 7 days
rotate_keep 2 # Keep at most 2 log files
errors /srv/logs/errors.log {
on startup php-fpm7 # php variant only
redir 301 {
if {path} is / # Only redirect if the request is for the webroot
/ https://www.google.com # Replace with wherever you like
import mycommon # Import code snippet 1 defined above
import mylocations # Import code snippet 2 defined above
# localhost or Machine server block
http://localhost http://192.168.29.2 http://172.10.0.1 {
# Plex subdomain code block
plex.sub.domain.com {
max_certs 10
gzip
# Separate log file for Plex server
log /srv/logs/plexaccess.log {
errors /srv/logs/plexerror.log {
rotate_size 1 # Set max size 1 MB
proxy / 172.10.0.9:32400 {
