Caddy not able to obtain TSL Sertificate for Duck DNS domain
Can resolve and access the ipv4 and domain name from local and external device without Caddy running. Disabled firewall. Opened up ports, 443, 2019, 80, 8096 and pointed at ipv4.
Last login: Wed Apr 10 20:08:09 on ttys000
TJKs-Mac-mini:~ tjkserver$ sudo caddy run --config /Users/tjkserver/Documents/Caddyfile/Caddyfile
Password:
2024/04/10 18:58:18.673 INFO using provided configuration {"config_file": "/Users/tjkserver/Documents/Caddyfile/Caddyfile", "config_adapter": ""}
2024/04/10 18:58:18.675 WARN Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "/Users/tjkserver/Documents/Caddyfile/Caddyfile", "line": 2}
2024/04/10 18:58:18.678 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/04/10 18:58:18.678 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00009fe80"}
2024/04/10 18:58:18.678 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2024/04/10 18:58:18.678 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/04/10 18:58:18.678 DEBUG http.auto_https adjusted config {"tls": {"automation":{"policies":[{}]}}, "http": {"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"127.0.0.1:8096"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
2024/04/10 18:58:18.679 INFO http enabling HTTP/3 listener {"addr": ":443"}
2024/04/10 18:58:18.680 DEBUG http starting server loop {"address": "[::]:443", "tls": true, "http3": true}
2024/04/10 18:58:18.680 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/04/10 18:58:18.680 DEBUG http starting server loop {"address": "[::]:80", "tls": false, "http3": false}
2024/04/10 18:58:18.680 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/04/10 18:58:18.680 INFO http enabling automatic TLS certificate management {"domains": ["tjk-server.duckdns.org"]}
2024/04/10 18:58:18.681 INFO autosaved config (load with --resume flag) {"file": "/Users/tjkserver/Library/Application Support/Caddy/autosave.json"}
2024/04/10 18:58:18.681 INFO serving initial configuration
2024/04/10 18:58:18.702 INFO tls.obtain acquiring lock {"identifier": "tjk-server.duckdns.org"}
2024/04/10 18:58:18.725 WARN tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/Users/tjkserver/Library/Application Support/Caddy", "instance": "1a01afa9-9591-4600-912c-ef86dc3fcc7d", "try_again": "2024/04/11 18:58:18.725", "try_again_in": 86399.999999014}
2024/04/10 18:58:18.726 INFO tls finished cleaning storage units
2024/04/10 18:58:18.805 INFO tls.obtain lock acquired {"identifier": "tjk-server.duckdns.org"}
2024/04/10 18:58:18.805 INFO tls.obtain obtaining certificate {"identifier": "tjk-server.duckdns.org"}
2024/04/10 18:58:18.805 DEBUG events event {"name": "cert_obtaining", "id": "e450f4b9-79c5-423a-9364-d45279f5e2eb", "origin": "tls", "data": {"identifier":"tjk-server.duckdns.org"}}
2024/04/10 18:58:18.806 DEBUG tls.obtain trying issuer 1/2 {"issuer": "acme-v02.api.letsencrypt.org-directory"}
2024/04/10 18:58:18.807 INFO http waiting on internal rate limiter {"identifiers": ["tjk-server.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "caddy@zerossl.com"}
2024/04/10 18:58:18.807 INFO http done waiting on internal rate limiter {"identifiers": ["tjk-server.duckdns.org"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "caddy@zerossl.com"}
2024/04/10 18:58:19.399 DEBUG http.acme_client http request {"method": "GET", "url": "https://acme-v02.api.letsencrypt.org/directory", "headers": {"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["747"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:19 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:19.574 DEBUG http.acme_client http request {"method": "HEAD", "url": "https://acme-v02.api.letsencrypt.org/acme/new-nonce", "headers": {"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Cache-Control":["public, max-age=0, no-cache"],"Date":["Wed, 10 Apr 2024 18:58:19 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioii62OoT3dPMjB5R2lFUFkkvskrmN-WpDKgizOeivehSfY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:19.781 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/new-order", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["348"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:19 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/1664304447/259816184067"],"Replay-Nonce":["0xgp031jrk6xL7eOz834OCLA6NvHpEOyd_dLAZ17RNMckhca0p4"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 201}
2024/04/10 18:58:19.959 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:19 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiil_rxR-7ZKuZJQtBRRdsCrBsc2217Gm-JqGvriOoTx2k"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:19.959 INFO http.acme_client trying to solve challenge {"identifier": "tjk-server.duckdns.org", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2024/04/10 18:58:19.961 DEBUG http.acme_client waiting for solver before continuing {"identifier": "tjk-server.duckdns.org", "challenge_type": "tls-alpn-01"}
2024/04/10 18:58:19.961 DEBUG http.acme_client done waiting for solver{"identifier": "tjk-server.duckdns.org", "challenge_type": "tls-alpn-01"}
2024/04/10 18:58:20.144 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/336914565117/Kn-KmQ", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["191"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:20 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/336914565117/Kn-KmQ"],"Replay-Nonce":["oJ2fioiikQb8xIxfme8pdhjlNL7hGhNIH_5XAIxVrAjiDUlVIwk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:20.144 DEBUG http.acme_client challenge accepted {"identifier": "tjk-server.duckdns.org", "challenge_type": "tls-alpn-01"}
2024/04/10 18:58:20.575 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:20 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jzqDZV1AnrU9nnAS9-XzgShsOeE4i9NB4-Bch__NjyM4"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:21.007 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:20 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiSSY3NeFb_LJUJMNc82EWD4xtVa1UxlccpTygDnltjgY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:21.440 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:21 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jk5_aX6AbjkG27ysVa_es4w3qKV-7gZWLfcLghZEZJIY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:21.881 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:21 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jGTHQ59QQOtwlybrWO3Y7Dq5E2--RzvMIDCosMRUMabk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:22.309 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:22 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jW30Ro8F2LTSh8zcM092YoyDQOLXOVKSyKmfLZJNT8YQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:22.739 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:22 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiSvl3DsYTgW0p0kFf4Y2zOfYm2TI0SoeZ-xf04wYxCYo"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:23.168 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:23 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiBJXmrtBG8KQRnZGtTrEHasgEL_9WugXU0srCIoRCZvo"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:23.609 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:23 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jYklIygCxdXY84k0XewzvVhLqfbDONYEAOJZvjIzjm9k"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:24.037 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:23 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jsRU37_GxrektM71-ybAGsK6WukPh5UJYA2Mv8xANfvU"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:24.467 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:24 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jS6Jm7qNZmd24GB62Vp1q7dd0eYolz62IkMMyd1FS_WE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:24.900 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:24 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiidboU21P_BlEL9-rlkXIPHsMemLQExgKbS2RKmdQIO_k"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:25.341 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:25 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jxY3eActSzRCHz4d7JPWA6_kIa_AaGHDgemI-op-HYu8"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:25.771 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:25 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiKDKTqp7wMJUxC3-XRDhEX0Gz4iHjbSqMihA2UZ0xi50"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:26.201 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:26 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiixnVCDx6xHFKxN6dzFHYLNNeN6rRJ4yC2KIb1fT-T2sE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:26.632 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:26 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jGIizZYlW9Nu5gLipkB_uOjkZFUrY-veukbQHo4WkO5Q"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:27.068 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:26 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiheeW1q5kH4whphUY9PkIOyeaQyao5-Ieh40j_xFTf3I"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:27.497 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:27 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031j7x40Esg2s3cC33f86-MKR9h1BwVP3G7W-OT1xC9-x2U"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:27.956 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:27 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiEZbllOvflgaYHcwm6UL5zaqHlHd14OWXJSLEEXx_s6I"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:28.389 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:28 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jxtXn8VL57_pkA4VQRd1ossFApU35ds00cOtWT5NwWhs"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:28.821 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:28 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiiisgjH99X2SActqBz6VRII1_gLoS_f7gYjGiMHpIgL-8"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:29.250 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:29 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jNmYhsREnKnto5vpZEYlEF4hReTO9aS-DOxSunMxwHW8"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:29.682 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:29 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiivIwc7j8Sx-l_j5uH79lpcEwD1-ar7kXLyX9YvJfoK9Q"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:30.115 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["806"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:30 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0xgp031jOxUQTf7i2ZeF301DFpVtbelvQYWwwuTSXiW_win-GY0"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:30.547 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme-v02.api.letsencrypt.org/acme/authz-v3/336914565117", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Boulder-Requester":["1664304447"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["1169"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:30 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["oJ2fioiipaqFIde77Guysggc3o2XJKmPWBMZIyfuE-x2WB4Nmww"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}, "status_code": 200}
2024/04/10 18:58:30.547 ERROR http.acme_client challenge failed {"identifier": "tjk-server.duckdns.org", "challenge_type": "tls-alpn-01", "problem": {"type": "urn:ietf:params:acme:error:malformed", "title": "", "detail": "Unable to contact \"tjk-server.duckdns.org\" at \"2001:4343:b514:0:405:248e:ad43:36a3\", no IPv4 addresses to try as fallback", "instance": "", "subproblems": []}}
2024/04/10 18:58:30.547 ERROR http.acme_client validating authorizatio{"identifier": "tjk-server.duckdns.org", "problem": {"type": "urn:ietf:params:acme:error:malformed", "title": "", "detail": "Unable to contact \"tjk-server.duckdns.org\" at \"2001:4343:b514:0:405:248e:ad43:36a3\", no IPv4 addresses to try as fallback", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/1664304447/259816184067", "attempt": 1, "max_attempts": 3}
2024/04/10 18:58:30.547 ERROR tls.obtain could not get certificate from issuer {"identifier": "tjk-server.duckdns.org", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "HTTP 400 urn:ietf:params:acme:error:malformed - Unable to contact \"tjk-server.duckdns.org\" at \"2001:4343:b514:0:405:248e:ad43:36a3\", no IPv4 addresses to try as fallback"}
2024/04/10 18:58:30.547 DEBUG tls.obtain trying issuer 2/2 {"issuer": "acme.zerossl.com-v2-DV90"}
2024/04/10 18:58:30.548 INFO http waiting on internal rate limiter {"identifiers": ["tjk-server.duckdns.org"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2024/04/10 18:58:30.548 INFO http done waiting on internal rate limiter {"identifiers": ["tjk-server.duckdns.org"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2024/04/10 18:58:30.903 DEBUG http.acme_client http request {"method": "GET", "url": "https://acme.zerossl.com/v2/DV90", "headers": {"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Content-Length":["645"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:30 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]}, "status_code": 200}
2024/04/10 18:58:31.227 DEBUG http.acme_client http request {"method": "HEAD", "url": "https://acme.zerossl.com/v2/DV90/newNonce", "headers": {"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Type":["application/octet-stream"],"Date":["Wed, 10 Apr 2024 18:58:31 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["Uw2p-E1G98v8wAYnE1IRt6OaDsrq-GJlSlsMoPDFEfg"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]}, "status_code": 200}
2024/04/10 18:58:31.590 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/newOrder", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["284"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:31 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/order/G-AGeT51yJpO-NcYPYeHOA"],"Replay-Nonce":["Z90TwWrD5XAQUUGm_an6udbb7HbyK1vGumf1MEHBIuU"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]}, "status_code": 201}
2024/04/10 18:58:31.932 DEBUG http.acme_client http request {"method": "POST", "url": "https://acme.zerossl.com/v2/DV90/authz/IvcPTUycQfK4R9JK3ZAMsg", "headers": {"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (darwin; amd64)"]}, "response_headers": {"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["472"],"Content-Type":["application/json"],"Date":["Wed, 10 Apr 2024 18:58:31 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["wLgls6P550RgCh4I1GyaLCEx0vVDnyVA51bmgrrYWkY"],"Retry-After":["86400"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]}, "status_code": 200}
2024/04/10 18:58:31.933 DEBUG http.acme_client no solver configured {"challenge_type": "dns-01"}
2024/04/10 18:58:31.933 INFO http.acme_client trying to solve challenge {"identifier": "tjk-server.duckdns.org", "challenge_type": "http-01", "ca": "https://acme.zerossl.com/v2/DV90"}
Downloaded from caddyserver.com/download, with extra DUCKDNS feature. Moved the package from Downloads to bin
sudo mv caddy /usr/local/bin/
Mac OS High Sierra 10.13.6 (17G14042)
# Caddyfile for tjk-server.duckdns.org
tjk-server.duckdns.org {
reverse_proxy 127.0.0.1:8096
