Caddy / NetMaker / Dockerized access ip in host level
  1. I have installed Caddy in Docker Container
  2. I also installed NetMaker
When I read forums it said that ways to reverse proxy a docker is by using
in this case I use portainer port*
domainhere {
       reverse_proxy localhost:9000
But above solutions aren’t working,
so I tried another solutions
domainhere  {
       reverse_proxy 127.0.0.1:9000
Above solutions also are not working
I Do some experiment, I when I run ifconfig I got this prompt :
docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        inet6 fe80::42:26ff:fef0:a145  prefixlen 64  scopeid 0x20<link>
        ether 02:42:26:f0:a1:45  txqueuelen 0  (Ethernet)
From above I see docker0, then I use 172.17.0.1 for the reverse proxy IP. and it worked!
domainhere  {
       reverse_proxy 172.17.0.1:9000
So above is what happened to me,
Here come the question.
How can I access host level IP for me to reverse proxy it?
I want to reverse proxy IPs inside my VPN tunnels.
below is the wg of tunnels connected to my server.
  allowed ips: 10.125.13.2/32
  latest handshake: 30 seconds ago
  transfer: 7.47 KiB received, 2.06 KiB sent
  persistent keepalive: every 20 seconds
None
v2.6.2
I use netmaker express installation.
Ubuntu 20, Docker.
  GNU nano 4.8        Caddyfile        Modified
# Dashboard
https://dashboard.{$NM_DOMAIN} {
        tls /root/certs/fullchain.pem /root/certs/privkey.pem
        # Apply basic security headers
                # Enable cross origin access to *.{$NM_DOMAIN}
                Access-Control-Allow-Origin *.{$NM_DOMAIN}
                # Enable HTTP Strict Transport Security (HSTS)
                # Disallow the site to be rendered within a frame on a foreign domain (clickjacking protection)
                X-Frame-Options "SAMEORIGIN"
                # Prevent search engines from indexing
                X-Robots-Tag "none"
                # Remove the server name
                -Server
        reverse_proxy http://netmaker-ui
# API
https://api.{$NM_DOMAIN} {
        reverse_proxy http://netmaker:8081
# TURN
https://turn.{$NM_DOMAIN} {
        reverse_proxy host.docker.internal:3479
# TURN API
https://turnapi.{$NM_DOMAIN} {
        reverse_proxy http://host.docker.internal:8089
# MQ
wss://broker.{$NM_DOMAIN} {
        reverse_proxy ws://mq:8883 # For EMQX websockets use `reverse_proxy ws://mq:8083`
# Portainer
docker.gementar.com {
        reverse_proxy portainer:9000 #This is not working but working when use the ip I stated above
In what way is it not working?
You didn’t show any of your Caddy logs, nor any errors or example curl -v requests, as asked by the help topic template.
This isn’t valid, ws:// is a scheme only understood by browsers.
Same here, wss:// is not a valid scheme in servers. Remove it.
