I’ve been getting this issue recently where the caddy service is running, but after a few hours, its memory will spike up to near 100% and then crash. I’m not sure what’s causing this, this issue started yesterday. I’m not sure where to get the logs, but I do have this screenshot from my server:
I don’t have logs of when it crashed :
If you need any other logs I can provide you with it
v2.6.2
Installation:
sudo apt update
sudo apt install caddy
I ran caddy with systemctl start caddy && caddy reload
root@doge-network
OS: Debian GNU/Linux 12 (bookworm) x86_64
Host: KVM/QEMU (Standard PC (i440FX + PIIX, 1996) pc-i440fx-7.2)
Kernel: 6.1.0-23-amd64
Uptime: 12 days, 2 hours, 36 mins
Packages: 487 (dpkg)
Shell: bash 5.2.15
Resolution: 1280x800
Terminal: node
CPU: AMD EPYC-Milan (4) @ 3.799GHz
GPU: 00:02.0 Vendor 1234 Device 1111
Memory: 2835MiB / 7906MiB
on_demand_tls {
ask http://localhost:3000/check/
https:// {
reverse_proxy /wisp/* 104.156.150.3
reverse_proxy /bear/* 104.156.150.3
reverse_proxy /epoxy/* 104.156.150.3
reverse_proxy /baremux/* 104.156.150.3
reverse_proxy /uv/* 104.156.150.3
root * /var/lib/caddy/site/public
rewrite /app /index.html
rewrite /portal /loader.html
rewrite /apps /apps.html
rewrite /gms /gms.html
rewrite /info /info.html
rewrite /edu loading.html
on_demand
# cp -r ~/v4/static/* /var/lib/caddy/site/public/
beta.derpman.lol {
reverse_proxy localhost:8001
