Caddy makes certs as directories?
When I start caddy, it frequently creates directories named
mail.dragonmail.social.crt mail.dragonmail.social.json mail.dragonmail.social.key
In the letsencrypt directory: caddy/data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/
This is a recent thing. It just started doing this within the last week or two. When I delete those directories, it switches to the zerossl certificates it already has and everything is fine. Do you know what would cause it to generate directories instead of files? It generates the directories, complains about the path being directories and not files, then closes. I then have to delete the directories manually, restart caddy, and let it automatically switch over to zerossl.
I’m still very new to reverse proxies and all the configs for this, so I’m going to assume I have things setup in my caddyfile and compose file in a way that is very inefficient or irksome. Sorry about that to anyone annoyed by my configs.
dragonmail:/media/configs$ docker compose logs caddy|grep caddy|grep directory|grep mail.dragonmail.social
caddy  | {"level":"error","ts":1735637166.7052178,"logger":"tls","msg":"deleting expired certificates staples","storage":"FileStorage:/data/caddy","error":"loading certificate file certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.crt: read /data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.crt: is a directory"}
caddy  | Error: loading initial config: loading new config: http app module: start: finalizing automatic HTTPS: managing certificates for [trbl.dragonmail.cloud dragonmail.social track.dragonmail.cloud element.dragonmail.cloud firefly.dragonmail.cloud dragonmail.cloud srv.dragonmail.cloud portainer.dragonmail.social mail.dragonmail.social nextcloud.dragonmail.cloud auth.dragonmail.social auth.dragonmail.cloud matrix.dragonmail.cloud chat.dragonmail.cloud]: automate: manage [trbl.dragonmail.cloud dragonmail.social track.dragonmail.cloud element.dragonmail.cloud firefly.dragonmail.cloud dragonmail.cloud srv.dragonmail.cloud portainer.dragonmail.social mail.dragonmail.social nextcloud.dragonmail.cloud auth.dragonmail.social auth.dragonmail.cloud matrix.dragonmail.cloud chat.dragonmail.cloud]: mail.dragonmail.social: caching certificate: read /data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.key: is a directory
caddy  | Error: loading initial config: loading new config: http app module: start: finalizing automatic HTTPS: managing certificates for [element.dragonmail.cloud matrix.dragonmail.cloud srv.dragonmail.cloud auth.dragonmail.social auth.dragonmail.cloud dragonmail.social mail.dragonmail.social dragonmail.cloud track.dragonmail.cloud portainer.dragonmail.social nextcloud.dragonmail.cloud trbl.dragonmail.cloud chat.dragonmail.cloud firefly.dragonmail.cloud]: automate: manage [element.dragonmail.cloud matrix.dragonmail.cloud srv.dragonmail.cloud auth.dragonmail.social auth.dragonmail.cloud dragonmail.social mail.dragonmail.social dragonmail.cloud track.dragonmail.cloud portainer.dragonmail.social nextcloud.dragonmail.cloud trbl.dragonmail.cloud chat.dragonmail.cloud firefly.dragonmail.cloud]: mail.dragonmail.social: caching certificate: read /data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.key: is a directory
caddy  | Error: loading initial config: loading new config: http app module: start: finalizing automatic HTTPS: managing certificates for [track.dragonmail.cloud matrix.dragonmail.cloud chat.dragonmail.cloud auth.dragonmail.cloud firefly.dragonmail.cloud auth.dragonmail.social portainer.dragonmail.social mail.dragonmail.social srv.dragonmail.cloud trbl.dragonmail.cloud dragonmail.social element.dragonmail.cloud dragonmail.cloud nextcloud.dragonmail.cloud]: automate: manage [track.dragonmail.cloud matrix.dragonmail.cloud chat.dragonmail.cloud auth.dragonmail.cloud firefly.dragonmail.cloud auth.dragonmail.social portainer.dragonmail.social mail.dragonmail.social srv.dragonmail.cloud trbl.dragonmail.cloud dragonmail.social element.dragonmail.cloud dragonmail.cloud nextcloud.dragonmail.cloud]: mail.dragonmail.social: caching certificate: read /data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.key: is a directory
It’s hard to get everything you need because the error doesn’t happen every time Caddy starts up. I can delete those directories and it loads using zerossl if I restart it. I also have a decent number of containers loaded up filling the logs. Here’s everything that mentions my mail server.
edit: or not…If I leave all this in, I pass the character limit for posts, so I’ll clip the top.
dragonmail:/media/configs$ docker compose logs caddy|grep caddy|grep mail.dragonmail.social
caddy  | {"level":"info","ts":1735637178.827913,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["element.dragonmail.cloud","matrix.dragonmail.cloud","srv.dragonmail.cloud","auth.dragonmail.social","auth.dragonmail.cloud","dragonmail.social","mail.dragonmail.social","dragonmail.cloud","track.dragonmail.cloud","portainer.dragonmail.social","nextcloud.dragonmail.cloud","trbl.dragonmail.cloud","chat.dragonmail.cloud","firefly.dragonmail.cloud"]}
caddy  | {"level":"debug","ts":1735637894.3101144,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["portainer.dragonmail.social","nextcloud.dragonmail.cloud","element.dragonmail.cloud","firefly.dragonmail.cloud","matrix.dragonmail.cloud","auth.dragonmail.social","mail.dragonmail.social","track.dragonmail.cloud","trbl.dragonmail.cloud","auth.dragonmail.cloud","chat.dragonmail.cloud","srv.dragonmail.cloud","dragonmail.social","dragonmail.cloud"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"portainer:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"static_response","headers":{"Location":["/remote.php/dav/"]},"status_code":301}],"match":[{"path":["/.well-known/carddav"]}]},{"handle":[{"handler":"static_response","headers":{"Location":["/remote.php/dav/"]},"status_code":301}],"match":[{"path":["/.well-known/caldav"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"nextcloud-aio-apache:11000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":["zstd","gzip"]},{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-element:80"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"woah, there are like flies, and they're like....on fire","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Access-Control-Allow-Origin":["*"],"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}}]},{"group":"group6","handle":[{"handler":"subroute","routes":[{"group":"group1","handle":[{"handler":"rewrite","uri":"/"}],"match":[{"path":["/synapse-admin/"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse-admin:80"}]}]}]}],"match":[{"path":["/synapse-admin/*"]}]},{"group":"group6","handle":[{"handler":"subroute","routes":[{"group":"group0","handle":[{"handler":"rewrite","uri":"/"}],"match":[{"path":["/synapse-admin"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse-admin:80"}]}]}]}],"match":[{"path":["/synapse-admin"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_synapse/client/*"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_matrix/*"]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"authentik:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"stalwart-mail:8080"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"ryot:8000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"portainer:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"authentik:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":["zstd","gzip"]},{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-element:80"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"sticker picker not enabled","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"encodings":{"gzip":{}},"handler":"encode","prefer":["gzip"]},{"body":"dragonmail, yaaaay","handler":"static_response"}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv1":{"listen":[":8080"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"nextcloud-aio-apache:8080"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv2":{"listen":[":8448"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_matrix/*"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
caddy  | {"level":"info","ts":1735637894.3218915,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["track.dragonmail.cloud","matrix.dragonmail.cloud","chat.dragonmail.cloud","auth.dragonmail.cloud","firefly.dragonmail.cloud","auth.dragonmail.social","portainer.dragonmail.social","mail.dragonmail.social","srv.dragonmail.cloud","trbl.dragonmail.cloud","dragonmail.social","element.dragonmail.cloud","dragonmail.cloud","nextcloud.dragonmail.cloud"]}
caddy  | {"level":"debug","ts":1735637925.866823,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["portainer.dragonmail.social","nextcloud.dragonmail.cloud","element.dragonmail.cloud","firefly.dragonmail.cloud","matrix.dragonmail.cloud","auth.dragonmail.social","mail.dragonmail.social","track.dragonmail.cloud","trbl.dragonmail.cloud","auth.dragonmail.cloud","chat.dragonmail.cloud","srv.dragonmail.cloud","dragonmail.social","dragonmail.cloud"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"portainer:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"static_response","headers":{"Location":["/remote.php/dav/"]},"status_code":301}],"match":[{"path":["/.well-known/carddav"]}]},{"handle":[{"handler":"static_response","headers":{"Location":["/remote.php/dav/"]},"status_code":301}],"match":[{"path":["/.well-known/caldav"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"nextcloud-aio-apache:11000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":["zstd","gzip"]},{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-element:80"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"woah, there are like flies, and they're like....on fire","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Access-Control-Allow-Origin":["*"],"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}}]},{"group":"group6","handle":[{"handler":"subroute","routes":[{"group":"group1","handle":[{"handler":"rewrite","uri":"/"}],"match":[{"path":["/synapse-admin/"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse-admin:80"}]}]}]}],"match":[{"path":["/synapse-admin/*"]}]},{"group":"group6","handle":[{"handler":"subroute","routes":[{"group":"group0","handle":[{"handler":"rewrite","uri":"/"}],"match":[{"path":["/synapse-admin"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse-admin:80"}]}]}]}],"match":[{"path":["/synapse-admin"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_synapse/client/*"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_matrix/*"]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"authentik:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"stalwart-mail:8080"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"ryot:8000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"portainer:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"authentik:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":["zstd","gzip"]},{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-element:80"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"sticker picker not enabled","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"encodings":{"gzip":{}},"handler":"encode","prefer":["gzip"]},{"body":"dragonmail, yaaaay","handler":"static_response"}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv1":{"listen":[":8080"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"nextcloud-aio-apache:8080"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv2":{"listen":[":8448"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_matrix/*"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
caddy  | {"level":"info","ts":1735637925.8812406,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["element.dragonmail.cloud","track.dragonmail.cloud","srv.dragonmail.cloud","portainer.dragonmail.social","matrix.dragonmail.cloud","nextcloud.dragonmail.cloud","auth.dragonmail.social","firefly.dragonmail.cloud","trbl.dragonmail.cloud","chat.dragonmail.cloud","dragonmail.social","mail.dragonmail.social","auth.dragonmail.cloud","dragonmail.cloud"]}
caddy  | {"level":"debug","ts":1735637925.886009,"logger":"tls","msg":"loading managed certificate","domain":"mail.dragonmail.social","expiration":1738800000,"issuer_key":"acme.zerossl.com-v2-DV90","storage":"FileStorage:/data/caddy"}
caddy  | {"level":"debug","ts":1735637925.8861198,"logger":"tls.cache","msg":"added certificate to cache","subjects":["mail.dragonmail.social"],"expiration":1738800000,"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"48d4b91beedb8581226c2d7f76daa8397475942dd06863ed7f4eea1725143200","cache_size":12,"cache_capacity":10000}
caddy  | {"level":"debug","ts":1735637925.8861349,"logger":"events","msg":"event","name":"cached_managed_cert","id":"d6000df2-e45c-4f17-967d-3c21629a0fd3","origin":"tls","data":{"sans":["mail.dragonmail.social"]}}
caddy  | {"level":"debug","ts":1735637932.007794,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["portainer.dragonmail.social","nextcloud.dragonmail.cloud","element.dragonmail.cloud","firefly.dragonmail.cloud","matrix.dragonmail.cloud","auth.dragonmail.social","mail.dragonmail.social","track.dragonmail.cloud","trbl.dragonmail.cloud","auth.dragonmail.cloud","chat.dragonmail.cloud","srv.dragonmail.cloud","dragonmail.social","dragonmail.cloud"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"portainer:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"static_response","headers":{"Location":["/remote.php/dav/"]},"status_code":301}],"match":[{"path":["/.well-known/carddav"]}]},{"handle":[{"handler":"static_response","headers":{"Location":["/remote.php/dav/"]},"status_code":301}],"match":[{"path":["/.well-known/caldav"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"nextcloud-aio-apache:11000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":["zstd","gzip"]},{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-element:80"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"woah, there are like flies, and they're like....on fire","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Access-Control-Allow-Origin":["*"],"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}}]},{"group":"group6","handle":[{"handler":"subroute","routes":[{"group":"group1","handle":[{"handler":"rewrite","uri":"/"}],"match":[{"path":["/synapse-admin/"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse-admin:80"}]}]}]}],"match":[{"path":["/synapse-admin/*"]}]},{"group":"group6","handle":[{"handler":"subroute","routes":[{"group":"group0","handle":[{"handler":"rewrite","uri":"/"}],"match":[{"path":["/synapse-admin"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse-admin:80"}]}]}]}],"match":[{"path":["/synapse-admin"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_synapse/client/*"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_matrix/*"]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"authentik:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"stalwart-mail:8080"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"ryot:8000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"portainer:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"authentik:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"headers","response":{"deferred":true,"delete":["server"],"set":{"Permissions-Policy":["accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"],"Strict-Transport-Security":["max-age=63072000; includeSubDomains;"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Robots-Tag":["none"],"X-Xss-Protection":["1"]}}},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":["zstd","gzip"]},{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-element:80"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"sticker picker not enabled","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"encodings":{"gzip":{}},"handler":"encode","prefer":["gzip"]},{"body":"dragonmail, yaaaay","handler":"static_response"}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv1":{"listen":[":8080"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"nextcloud-aio-apache:8080"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv2":{"listen":[":8448"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"matrix-synapse:8008"}]}],"match":[{"path":["/_matrix/*"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
caddy  | {"level":"info","ts":1735637932.0101542,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["mail.dragonmail.social","dragonmail.cloud","trbl.dragonmail.cloud","firefly.dragonmail.cloud","chat.dragonmail.cloud","nextcloud.dragonmail.cloud","element.dragonmail.cloud","matrix.dragonmail.cloud","portainer.dragonmail.social","srv.dragonmail.cloud","dragonmail.social","auth.dragonmail.social","track.dragonmail.cloud","auth.dragonmail.cloud"]}
caddy  | {"level":"debug","ts":1735637932.0103917,"logger":"tls","msg":"loading managed certificate","domain":"mail.dragonmail.social","expiration":1738800000,"issuer_key":"acme.zerossl.com-v2-DV90","storage":"FileStorage:/data/caddy"}
caddy  | {"level":"debug","ts":1735637932.010583,"logger":"tls.cache","msg":"added certificate to cache","subjects":["mail.dragonmail.social"],"expiration":1738800000,"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"48d4b91beedb8581226c2d7f76daa8397475942dd06863ed7f4eea1725143200","cache_size":1,"cache_capacity":10000}
caddy  | {"level":"debug","ts":1735637932.0106018,"logger":"events","msg":"event","name":"cached_managed_cert","id":"b6b580db-91da-4dac-8940-4b93392970ac","origin":"tls","data":{"sans":["mail.dragonmail.social"]}}
caddy  | {"level":"debug","ts":1735639698.6886683,"logger":"events","msg":"event","name":"tls_get_certificate","id":"b5fda0cf-d513-46e6-8a41-f5324b43b505","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],"ServerName":"mail.dragonmail.social","SupportedCurves":[4588,29,23,24,25,256,257],"SupportedPoints":"AA==","SignatureSchemes":[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"216.232.245.52","Port":37748,"Zone":""},"LocalAddr":{"IP":"172.19.0.5","Port":443,"Zone":""}}}}
caddy  | {"level":"debug","ts":1735639698.688689,"logger":"tls.handshake","msg":"choosing certificate","identifier":"mail.dragonmail.social","num_choices":1}
caddy  | {"level":"debug","ts":1735639698.6886992,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"mail.dragonmail.social","subjects":["mail.dragonmail.social"],"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"48d4b91beedb8581226c2d7f76daa8397475942dd06863ed7f4eea1725143200"}
caddy  | {"level":"debug","ts":1735639698.6887028,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"216.232.245.52","remote_port":"37748","subjects":["mail.dragonmail.social"],"managed":true,"expiration":1738800000,"hash":"48d4b91beedb8581226c2d7f76daa8397475942dd06863ed7f4eea1725143200"}
caddy  | {"level":"debug","ts":1735639698.6945336,"logger":"events","msg":"event","name":"tls_get_certificate","id":"d5647424-f846-47cb-9d95-4fbfb9a8b0fc","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],"ServerName":"mail.dragonmail.social","SupportedCurves":[4588,29,23,24,25,256,257],"SupportedPoints":"AA==","SignatureSchemes":[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"216.232.245.52","Port":37750,"Zone":""},"LocalAddr":{"IP":"172.19.0.5","Port":443,"Zone":""}}}}
caddy  | {"level":"debug","ts":1735639698.6945462,"logger":"tls.handshake","msg":"choosing certificate","identifier":"mail.dragonmail.social","num_choices":1}
caddy  | {"level":"debug","ts":1735639698.6945536,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"mail.dragonmail.social","subjects":["mail.dragonmail.social"],"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"48d4b91beedb8581226c2d7f76daa8397475942dd06863ed7f4eea1725143200"}
caddy  | {"level":"debug","ts":1735639698.694558,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"216.232.245.52","remote_port":"37750","subjects":["mail.dragonmail.social"],"managed":true,"expiration":1738800000,"hash":"48d4b91beedb8581226c2d7f76daa8397475942dd06863ed7f4eea1725143200"}
caddy  | {"level":"debug","ts":1735639702.0045316,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"stalwart-mail:8080","duration":3.30249475,"request":{"remote_ip":"216.232.245.52","remote_port":"37748","client_ip":"216.232.245.52","proto":"HTTP/2.0","method":"POST","host":"mail.dragonmail.social","uri":"/api/oauth","headers":{"Referer":["https://mail.dragonmail.social/"],"X-Forwarded-For":["216.232.245.52"],"X-Forwarded-Host":["mail.dragonmail.social"],"Accept-Language":["en-US,en;q=0.5"],"Priority":["u=0"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0"],"Authorization":["REDACTED"],"Sec-Fetch-Mode":["cors"],"Sec-Gpc":["1"],"Accept":["*/*"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Content-Length":["58"],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Site":["same-origin"],"Content-Type":["text/plain;charset=UTF-8"],"Origin":["https://mail.dragonmail.social"],"Te":["trailers"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mail.dragonmail.social"}},"headers":{"Content-Type":["application/json; charset=utf-8"],"Content-Length":["3440"],"Date":["Tue, 31 Dec 2024 10:08:21 GMT"]},"status":200}
caddy  | {"level":"debug","ts":1735639722.9986265,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"stalwart-mail:8080","duration":1.517413918,"request":{"remote_ip":"216.232.245.52","remote_port":"37748","client_ip":"216.232.245.52","proto":"HTTP/2.0","method":"POST","host":"mail.dragonmail.social","uri":"/api/oauth","headers":{"Sec-Fetch-Dest":["empty"],"Origin":["https://mail.dragonmail.social"],"Sec-Fetch-Mode":["cors"],"X-Forwarded-Host":["mail.dragonmail.social"],"Content-Type":["text/plain;charset=UTF-8"],"Content-Length":["58"],"X-Forwarded-For":["216.232.245.52"],"X-Forwarded-Proto":["https"],"Sec-Gpc":["1"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0"],"Authorization":["REDACTED"],"Sec-Fetch-Site":["same-origin"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Accept":["*/*"],"Priority":["u=0"],"Accept-Language":["en-US,en;q=0.5"],"Referer":["https://mail.dragonmail.social/"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mail.dragonmail.social"}},"headers":{"Content-Length":["1837"],"Date":["Tue, 31 Dec 2024 10:08:42 GMT"],"Content-Type":["application/json; charset=utf-8"]},"status":200}
caddy  | {"level":"debug","ts":1735639723.0208046,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"stalwart-mail:8080","duration":0.003032554,"request":{"remote_ip":"216.232.245.52","remote_port":"37748","client_ip":"216.232.245.52","proto":"HTTP/2.0","method":"POST","host":"mail.dragonmail.social","uri":"/auth/token","headers":{"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0"],"Accept":["*/*"],"X-Forwarded-Host":["mail.dragonmail.social"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Mode":["cors"],"Te":["trailers"],"Referer":["https://mail.dragonmail.social/"],"X-Forwarded-For":["216.232.245.52"],"Origin":["https://mail.dragonmail.social"],"Content-Length":["108"],"Priority":["u=4"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Gpc":["1"],"Sec-Fetch-Dest":["empty"],"Content-Type":["text/plain;charset=UTF-8"],"Sec-Fetch-Site":["same-origin"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mail.dragonmail.social"}},"headers":{"Content-Type":["application/problem+json"],"Content-Length":["101"],"Date":["Tue, 31 Dec 2024 10:08:42 GMT"]},"status":401}
caddy  | {"level":"debug","ts":1735639730.3962584,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"stalwart-mail:8080","duration":0.001131157,"request":{"remote_ip":"216.232.245.52","remote_port":"37748","client_ip":"216.232.245.52","proto":"HTTP/2.0","method":"POST","host":"mail.dragonmail.social","uri":"/api/oauth","headers":{"Origin":["https://mail.dragonmail.social"],"Accept-Encoding":["gzip, deflate, br, zstd"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mail.dragonmail.social"],"Accept":["*/*"],"Authorization":["REDACTED"],"Sec-Fetch-Dest":["empty"],"X-Forwarded-For":["216.232.245.52"],"Referer":["https://mail.dragonmail.social/"],"Content-Type":["text/plain;charset=UTF-8"],"Sec-Fetch-Mode":["cors"],"Content-Length":["58"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["same-origin"],"Accept-Language":["en-US,en;q=0.5"],"Priority":["u=0"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mail.dragonmail.social"}},"headers":{"Content-Type":["application/json; charset=utf-8"],"Content-Length":["3440"],"Date":["Tue, 31 Dec 2024 10:08:50 GMT"]},"status":200}
caddy  | {"level":"debug","ts":1735639765.2497106,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"stalwart-mail:8080","duration":0.000641123,"request":{"remote_ip":"216.232.245.52","remote_port":"37748","client_ip":"216.232.245.52","proto":"HTTP/2.0","method":"POST","host":"mail.dragonmail.social","uri":"/api/oauth","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0"],"Origin":["https://mail.dragonmail.social"],"X-Forwarded-For":["216.232.245.52"],"X-Forwarded-Proto":["https"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Content-Type":["text/plain;charset=UTF-8"],"Content-Length":["58"],"Sec-Gpc":["1"],"Accept":["*/*"],"Authorization":["REDACTED"],"X-Forwarded-Host":["mail.dragonmail.social"],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Mode":["cors"],"Te":["trailers"],"Accept-Language":["en-US,en;q=0.5"],"Referer":["https://mail.dragonmail.social/"],"Sec-Fetch-Site":["same-origin"],"Priority":["u=0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mail.dragonmail.social"}},"headers":{"Content-Type":["application/json; charset=utf-8"],"Content-Length":["3440"],"Date":["Tue, 31 Dec 2024 10:09:25 GMT"]},"status":200}
caddy  | {"level":"debug","ts":1735639829.9917073,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"stalwart-mail:8080","duration":0.000865706,"request":{"remote_ip":"216.232.245.52","remote_port":"37748","client_ip":"216.232.245.52","proto":"HTTP/2.0","method":"POST","host":"mail.dragonmail.social","uri":"/api/oauth","headers":{"Content-Type":["text/plain;charset=UTF-8"],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Site":["same-origin"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Origin":["https://mail.dragonmail.social"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mail.dragonmail.social"],"Accept":["*/*"],"Referer":["https://mail.dragonmail.social/"],"Te":["trailers"],"Content-Length":["58"],"X-Forwarded-For":["216.232.245.52"],"Sec-Gpc":["1"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Fetch-Mode":["cors"],"Authorization":["REDACTED"],"Priority":["u=0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mail.dragonmail.social"}},"headers":{"Date":["Tue, 31 Dec 2024 10:10:29 GMT"],"Content-Type":["application/json; charset=utf-8"],"Content-Length":["3440"]},"status":200}
Caddy v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
I build caddy this way because I followed a tutorial that said if you want to get certificates, you need to build with the correct plugins:
  dragonio:
    driver: 'bridge'
    external: true
  matrix_net:
    driver: 'bridge'
    external: true
  firefly:
    driver: 'bridge'
    external: true
#  wger_net:
#    name: 'wger_net'
#    driver: 'bridge'
#    external: true
  nextcloud_aio_mastercontainer:
    external: true
  nextcloud_aio_nextcloud_data:
    external: true
  nextcloud_aio_backupdir:
    external: true
    #image: caddy:2.8.4
    build: ./dockerfile-caddy
    #  context: .
    #  dockerfile: Dockerfile
    image: deeweb:latest
      - 443:443
      - 443:443/udp
      - /media/configs/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /media/configs/caddy/config:/config
      - /media/configs/caddy/data:/data
      - /media/configs/caddy/site:/srv
      PUID: '1000'
      PGID: '1000'
      TZ: 'America/vancouver'
      LINODE_TOKEN: ****
      dragonio:
        aliases: []
    # depends_on:
    # - portainer
  postgresql:
    image: docker.io/library/postgres:16-alpine
    container_name: postgressql
    healthcheck:
      test: ["CMD-SHELL", "pg_isready -d $${POSTGRES_DB} -U $${POSTGRES_USER}"]
      start_period: 20s
      interval: 30s
      retries: 5
      timeout: 5s
      - /media/configs/authentik/database:/var/lib/postgresql/data
      POSTGRES_PASSWORD: ${PG_PASS:?database password required}
      POSTGRES_USER: ${PG_USER:-authentik}
      POSTGRES_DB: ${PG_DB:-authentik}
    env_file:
      - .env
      dragonio:
        #ipv4_address: 10.10.10.2
        aliases: []
    depends_on:
     - caddy
  redis:
    image: docker.io/library/redis:alpine
    command: --save 60 1 --loglevel warning
    healthcheck:
      test: ["CMD-SHELL", "redis-cli ping | grep PONG"]
      start_period: 20s
      interval: 30s
      retries: 5
      timeout: 3s
      - /media/configs/authentik/redis:/data
      dragonio:
        aliases: []
    depends_on:
     - caddy
  authentik:
    image: ${AUTHENTIK_IMAGE:-ghcr.io/goauthentik/server}:${AUTHENTIK_TAG:-2024.12.1}
    container_name: authentik
    command: server
      AUTHENTIK_REDIS__HOST: redis
      AUTHENTIK_POSTGRESQL__HOST: postgresql
      AUTHENTIK_POSTGRESQL__USER: ${PG_USER:-authentik}
      AUTHENTIK_POSTGRESQL__NAME: ${PG_DB:-authentik}
      AUTHENTIK_POSTGRESQL__PASSWORD: ${PG_PASS}
      AUTHENTIK_EMAIL__HOST: mail.dragonmail.social
      AUTHENTIK_EMAIL__PORT: 587
      AUTHENTIK_EMAIL__USERNAME: *****
      AUTHENTIK_EMAIL__PASSWORD: *****
      AUTHENTIK_EMAIL__USE_TLS: true
      AUTHENTIK_EMAIL__FROM: *****
      - /media/configs/authentik/media:/media
      - /media/configs/authentik/custom-templates:/templates
      - /media/configs/authentik/web_customizations/logo2.svg:/web/dist/assets/icons/dragonmaillogo.svg
      - /media/configs/authentik/web_customizations/icon.ico:/web/dist/assets/icons/dragonmailicon.ico
      - /media/configs/caddy/data/caddy/certificates/acme.zerossl.com-v2-dv90:/certs/caddy
    env_file:
      - .env
    expose:
      - 9000
      - 9443
    # ports:
    #   - 85:9000
    #   - 9445:9443
    # #  - "${COMPOSE_PORT_HTTP:-9000}:9000"
    # #  - "${COMPOSE_PORT_HTTPS:-9443}:9443"
    depends_on:
      - postgresql
      - redis
      - caddy
      dragonio:
        aliases: []
  worker:
    command: worker
      COMPOSE_PORT_HTTP: 80
      COMPOSE_PORT_HTTPS: 443
    user: root
      - /media/configs/authentik/certs:/certs
      - /media/configs/authentik/web_customizations/mail-dragonite_4x.png:/web/dist/assets/icons/icon_left_brand.png
    env_file:
      - .env
    depends_on:
      - postgresql
      - redis
      - caddy
      dragonio:
        aliases: []
  portainer:
    container_name: 'portainer'
    image: 'portainer/portainer-ce:latest'
    restart: 'always'
      dragonio:
        aliases: []
    #   #- 7000:9000
      - '/media/configs/portainer/_data:/data'
      - '/var/run/docker.sock:/var/run/docker.sock'
  stalwart-mail:
    container_name: 'stalwart-mail'
    image: 'stalwartlabs/mail-server:latest'
    restart: 'unless-stopped'
      dragonio:
        aliases: []
        #ipv4_address: 172.19.0.65
    expose:
      - 443
      - 8080
      - 25
      - 587
      - 465
      - 143
      - 993
      - 4190
      - 110
      - 995
    #  - 8443:443 # 443 is critical for web admin, jmap, rest, and oauth
      - 25:25 # smtp - receiving incoming emails from other mail servers.
      - 587:587 # smtp submission with starttls. Prefer 465 with implicit tls
      - 465:465 # smtps - smtp with implicit tls
      - 143:143 # imap4
      - 993:993 #imaps - imap4 with tls
      - 4190:4190 #seive scripts
    #  - 110:110 #pop3
    #  - 995:995 #pop3 tls secure
      - '/media/mail_storage/stalwart_mail:/opt/stalwart-mail'
      - '/media/configs/caddy/data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.crt:/certs/mail.dragonmail.social.crt'
      - '/media/configs/caddy/data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/mail.dragonmail.social/mail.dragonmail.social.key:/certs/mail.dragonmail.social.key'
      PUID: '1000'
      PGID: '1000'
      TZ: 'America/Vancouver'
  nextcloud-aio-mastercontainer:
    container_name: 'nextcloud-aio-mastercontainer'
    image: 'nextcloud/all-in-one:latest'
    init: true
      dragonio:
        aliases: []
      APACHE_PORT: 11000
      APACHE_IP_BINDING: 0.0.0.0
      # SKIP_DOMAIN_VALIDATION: true
      TALK_PORT: 3478
      BORG_RETENTION_POLICY: --keep-within=7d --keep-weekly=4 --save-space
    #  NEXTCLOUD_TRUSTED_CACERTS_DIR: /certs
      - 'nextcloud_aio_mastercontainer:/mnt/docker-aio-config'
      - 'nextcloud_aio_nextcloud_data:/mnt/docker_nextcloud_data'
      - '/var/run/docker.sock:/var/run/docker.sock:ro'
      - 'nextcloud_aio_backupdir:/root/nextcloud_backups/borg'
    depends_on:
      - caddy
      - authentik
  matrix-synapse:
    container_name: 'matrix-synapse'
    image: 'matrixdotorg/synapse:latest'
    init: true
    pull_policy: always
      matrix_net:
        aliases: []
        ipv4_address: 10.10.10.4
      dragonio:
        aliases: []
      SYNAPSE_SERVER_NAME: 'matrix.dragonmail.cloud'
      SYNAPSE_REPORT_STATS: 'yes'
      allow_unsafe_locale: true
      - '/media/matrix/synapse:/data'
    depends_on:
     - matrix-postgres
     - caddy
     - authentik
  matrix-element:
    container_name: 'matrix-element'
    image: 'vectorim/element-web:latest'
    #pull_policy: always
      - '/media/matrix/element/element-config.json:/app/config.json'
    #ports:
    #  - 8180:80
      dragonio:
        aliases: []
      matrix_net:
        ipv4_address: 10.10.10.3
        aliases: []
    depends_on:
      - matrix-synapse
      - matrix-postgres
      - caddy
  matrix-postgres:
    #image: 'docker.io/library/postgres:16-alpine'
    image: 'postgres:14'
    container_name: 'matrix-postgres'
    healthcheck:
      start_period: 20s
      interval: 30s
      retries: 5
      timeout: 5s
      - '/media/matrix/database:/var/lib/postgresql/data'
      POSTGRES_USER: 'synapse'
      POSTGRES_DB: 'synapse'
    env_file:
      - .env
      matrix_net:
        aliases: []
    container_name: matrix-synapse-admin
    hostname: matrix-synapse-admin
    image: awesometechnologies/synapse-admin:latest
      - "8195:80"
      matrix_net:
        aliases: []
      dragonio:
        aliases: []
    depends_on:
     - caddy
  ryot:
    image: ghcr.io/ignisda/ryot:latest
    env_file:
      - ./ryot/env.env
      DATABASE_URL: postgres://postgres:postgres@ryot-db:5432/postgres
      FRONTEND_URL: https://track.dragonmail.cloud
      SERVER_OIDC_ISSUER_URL: https://auth.dragonmail.cloud/application/o/ryot/
      FRONTEND_OIDC_BUTTON_LABEL: "Login with Dragonmail"
      USERS_ALLOW_REGISTRATION: true
      USERS_DISABLE_LOCAL_AUTH: true
      TZ: America/Vancouver
    container_name: ryot
    pull_policy: always
      - /media/configs/ryot/icon.ico:/var/www/favicon.ico
      - /media/configs/ryot/icon.png:/var/www/apple-touch-icon.png
    #ports:
    ##  - 3000:3000
    #  - 8000:8000
      dragonio:
        aliases: []
    depends_on:
     - caddy
  ryot-db:
    image: postgres:16-alpine
    env_file:
      - ./ryot/env.env
    container_name: ryot-db
      - /media/nextcloud/ryot_db:/var/lib/postgresql/data
      POSTGRES_PASSWORD: postgres
      POSTGRES_USER: postgres
      POSTGRES_DB: postgres
      dragonio:
        aliases: []
  firefly-core:
    image: fireflyiii/core:latest
    hostname: app
    container_name: firefly-core
    restart: always
      - /media/nextcloud/firefly/core_upload:/var/www/html/storage/upload
    env_file: ./firefly/.env
      - dragonio
      - firefly
    depends_on:
      - firefly-db
      - caddy
      - authentik
  firefly-db:
    image: mariadb:lts
    hostname: db
    container_name: firefly-db
    restart: always
    #env_file: ./firefly/.db.env
      - firefly
      - /media/nextcloud/firefly/db:/var/lib/mysql
  firefly-cron:
    image: alpine
    restart: always
    container_name: firefly-cron
    command: sh -c "echo \"0 3 * * * wget -qO- http://app:8080/api/v1/cron/*****;echo\" | crontab - && crond -f -L /dev/stdout"
      - firefly
#  firefly-importer:
#    image: fireflyiii/data-importer:latest
#    hostname: importer
#    restart: always
#    container_name: firefly_importer
#    networks:
#      - firefly
#    ports:
#      - '8096:8080'
#    depends_on:
#      - firefly-core
#      - caddy
#    env_file: ./firefly/.importer.env
FROM caddy:2.8.4-builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/linode \
    --with github.com/caddy-dns/godaddy
FROM caddy:2.8.4
dragonmail:/media/configs$ cat caddy/Caddyfile
  #admin :2019
  email *****
  acme_dns linode {env.LINODE_TOKEN}
#(matrix-well-known-header) {
#  header {
#    Access-Control-Allow-Origin "*"
#    Access-Control-Allow-Methods "GET, POST, PUT, DELETE, OPTIONS"
#    Access-Control-Allow-Headers "Origin, X-Requested-With, Content-Type, Accept, Authorization"
#    Content-Type "application/json"
#(matrix) {
#  handle /.well-known/matrix/server {
#    import matrix-well-known-header
#    respond `{"m.server":"matrix.dragonmail.cloud"}`
#  handle /.well-known/matrix/client {
#    respond `{"m.homeserver":{"base_url":"https://chat.dragonmail.cloud"}}`
dragonmail.social {
  respond "dragonmail test works, yaaaay! It lives!"
  #tls {
  #  #email *****
  #  #acme_dns linode {env.LINODE_TOKEN}
  #  dns linode {env.LINODE_TOKEN}
#dragonmail.cloud {
#        respond `{"m.server":"matrix.dragonmail.cloud:443"}`
#        respond `{"m.homeserver":{"base_url":"https://matrix.dragonmail.cloud"}}`
portainer.dragonmail.social {
  reverse_proxy http://portainer:9000
trbl.dragonmail.cloud {
auth.dragonmail.social {
  reverse_proxy http://authentik:9000
auth.dragonmail.cloud {
  #reverse_proxy http://authentik:9000
  reverse_proxy authentik:9000
mail.dragonmail.social {
  reverse_proxy http://stalwart-mail:8080
https://nextcloud.dragonmail.cloud:443 {
  redir /.well-known/carddav /remote.php/dav/ 301
  redir /.well-known/caldav /remote.php/dav/ 301
  reverse_proxy nextcloud-aio-apache:11000
nextcloud.dragonmail.cloud:8080 {
  #redir /.well-known/carddav /remote.php/dav/ 301
  #redir /.well-known/caldav /remote.php/dav/ 301
  reverse_proxy nextcloud-aio-apache:8080
#vault.dragonmail.cloud {
#  respond "Not setup yet"
#  #reverse_proxy http://vaultwarden
matrix.dragonmail.cloud {
  #@matrix {
  #  path /_matrix/* /_synapse/client/*
#        #import matrix-well-known-header
  # new, testing...
  handle /synapse-admin {
      rewrite /synapse-admin /
      reverse_proxy http://matrix-synapse-admin:80
  # Why does it only work when I have both /synapse-admin and /synapse-admin/*   ???
  handle /synapse-admin/* {
      rewrite /synapse-admin/ /
   reverse_proxy /_matrix/* matrix-synapse:8008
   reverse_proxy /_synapse/client/* matrix-synapse:8008
      Referrer-Policy strict-origin-when-cross-origin
      Strict-Transport-Security "max-age=63072000; includeSubDomains;"
      Permissions-Policy "accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"
      X-Frame-Options SAMEORIGIN
      X-XSS-Protection 1
      X-Robots-Tag none
      -server
dragonmail.cloud:8448 {
element.dragonmail.cloud {
  encode zstd gzip
  #reverse_proxy element:80
  #reverse_proxy 10.10.10.3:80
  reverse_proxy matrix-element:80
  #reverse_proxy 192.168.3.50:8090
    X-XSS-Protection 1
    X-Robots-Tag none
    -server
chat.dragonmail.cloud {
  encode zstd gzip
    X-XSS-Protection 1
    X-Robots-Tag none
    -server
track.dragonmail.cloud {
  reverse_proxy http://ryot:8000
# not setup yet. Placeholder.
firefly.dragonmail.cloud {
  respond "woah, there are like flies, and they're like....on fire"
  #reverse_proxy http://firefly-core:8080 {
        #        header_up Host {http.request.host}
        #        #header_up X-Real-IP {http.request.remote}
        #        #header_up X-Forwarded-For {http.request.remote}
        #        #header_up X-Forwarded-Port {http.request.port}
        #        #header_up X-Forwarded-Proto {http.request.scheme}
        #        #header_up Connection {http.request.header.Connection}
        #        #header_up Upgrade {http.request.header.Upgrade}
srv.dragonmail.cloud {
  respond "sticker picker not enabled"
It isn’t Caddy creating the directories. It’s this segment in your stalwart_mail service:
Mounting non-existing paths in Docker Compose initializes them as empty directories (StackOverflow explainer), which is why Caddy suddenly finds directories. You’ll need to rewire how you share the certificates. I’ve seen at least 1 user in the forum using events with an exec handler to copy the generated certificates into a known, static location. You may come up with another idea.
Ohhh, I see! Thank you very much!
