$ caddy version
I’m running Caddy and the service I’m trying to proxy to (deluge-web) in LXC containers.
- The host is Ubuntu 20.04
- The LXC container running Caddy is running Caddy as root in a fresh install of Ubuntu 20.04
- The LXC container running deluge-web is running as root in a fresh install of Ubuntu 18.04
- deluge-web is listening on 0.0.0.0:8112 and can be accessed from the LXC container running caddy via it’s interal network
- A proxy device is listening to 0.0.0.0:80 and 0.0.0.0:443 on the host and forwarding it to the LXC container running caddy
# caddy run
my.domain.net, http://192.168.1.204 {
route /deluge* {
uri strip_prefix /deluge
reverse_proxy deluge.lxd:8112 {
header_up X-Real-IP {remote}
header_up X-Deluge-Base "/deluge"
This setup works fine, the only problem is that delige-web only see’s the requests coming from 10.140.228.220, which is the IP of the Caddy server. Looking at the DEBUG output form caddy I can see that it’s listing 127.0.0.1 as the remote IP:
2020/08/13 02:45:03.665 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "deluge.lxd:8112", "request": {"method": "GET", "uri": "/", "proto": "HTTP/2.0", "remote_addr": "127.0.0.1:59876", "host": "home.jpolny.net", "headers": {"Sec-Fetch-Site": ["none"], "Sec-Fetch-Mode": ["navigate"], "S
ec-Fetch-User": ["?1"], "X-Forwarded-Proto": ["https"], "Upgrade-Insecure-Requests": ["1"], "Accept-Encoding": ["gzip, deflate, br"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"], "X-Real-Ip": ["127.0.0.1:59876"], "X-Deluge
-Base": ["/deluge"], "Accept-Language": ["en-US,en;q=0.9"], "X-Forwarded-For": ["127.0.0.1"], "User-Agent": ["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.108 Safari/537.36"], "Sec-Fetch-Dest": ["document"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "p
roto": "h2", "proto_mutual": true, "server_name": "home.jpolny.net"}}, "duration": 0.015309671, "headers": {"Server": ["TwistedWeb"], "Date": ["Thu, 13 Aug 2020 02:45:03 GMT"], "Content-Type": ["text/html; charset=utf-8"], "Content-Length": ["2395"]}, "status": 200}
I tried adding the PROXY protocol to the LXC proxy device, but that results in the following:
# caddy run
2020/08/13 02:47:37.297 INFO using adjacent Caddyfile
2020/08/13 02:47:37.298 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["127.0.0.1:2019", "localhost:2019", "[::1]:2019"]}
2020/08/13 02:47:37 [INFO][cache:0xc00058c2a0] Started certificate maintenance routine
2020/08/13 02:47:37.299 INFO http server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv1", "http_port": 80}
2020/08/13 02:47:37.299 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2020/08/13 02:47:37.299 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2020/08/13 02:47:37.299 WARN http user server is listening on same interface as automatic HTTP->HTTPS redirects; user-configured routes might override these redirects {"server_name": "srv1", "interface": "tcp/:80"}
2020/08/13 02:47:37.301 INFO tls cleaned up storage units
2020/08/13 02:47:37.301 DEBUG http starting server loop {"address": "[::]:443", "http3": false, "tls": true}
2020/08/13 02:47:37.301 DEBUG http starting server loop {"address": "[::]:80", "http3": false, "tls": false}
2020/08/13 02:47:37.301 INFO http enabling automatic TLS certificate management {"domains": ["home.jpolny.net"]}
2020/08/13 02:47:37.315 INFO autosaved config {"file": "/root/.config/caddy/autosave.json"}
2020/08/13 02:47:37.315 INFO serving initial configuration
2020/08/13 02:47:44 http: TLS handshake error from 127.0.0.1:59896: tls: first record does not look like a TLS handshake
2020/08/13 02:47:44 http: TLS handshake error from 127.0.0.1:59898: tls: first record does not look like a TLS handshake
2020/08/13 02:47:45 http: TLS handshake error from 127.0.0.1:59900: tls: first record does not look like a TLS handshake
2020/08/13 02:47:45 http: TLS handshake error from 127.0.0.1:59902: tls: first record does not look like a TLS handshake
2020/08/13 02:47:50 http: TLS handshake error from 127.0.0.1:59904: tls: first record does not look like a TLS handshake
2020/08/13 02:47:50 http: TLS handshake error from 127.0.0.1:59906: tls: first record does not look like a TLS handshake
Based on Proxyprotocol plugin for caddy 2? and the lack of activity on the proxyprotocol module I assume this is something caddy doesn’t directly support, but is there any way to get the real remote IP from the original request?
