Caddy / Localhost / HTTPS = "This site can’t provide a secure connection"
v2.0.0-rc.1 h1:DxUlg4kMisXwXVnWND7KEPl1f+vjFpIOzYpKpfmwyj8=
Windows 10
paste full file contents here
localhost
respond "Hello, world!"
Just trying to get started with the very first example here:
I can’t get it working over HTTPS?
run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
start: caddy process exited with error: exit status 1
The above error happens any time I include localhost or 127.0.0.1. If I use just a port number (implied localhost?) the error goes away
Tried changing Caddyfile to:
:2016 {
respond “Hello, world!”
which works over HTTP but HTTPS errors with:
Chrome: This site can’t provide a secure connection - ERR_SSL_PROTOCOL_ERROR
CURL: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
Also tried
https://:2016 {
with the same results.
The Caddy certificate is installed in Trusted Root Certification Authorities
It would seem the RC (or the documentation) has a bug since the example doesn’t work. How do I specify the address in a way that allows HTTPS to work without using port 443?
The first error:
Means that caddy doesn’t have permission to bind to port 80 (or 443, presumably). On some systems, low ports are privileged so you need to add permissions to do that – how you do that is up to you and depends on your OS, and isn’t really unique to Caddy.
This is because automatic HTTPS does not get activated because there is no hostname in the address, which is necessary for a certificate.
This is because, again, there is no hostname, so there is no automatic certificate available.
Basically, just change the address in your config to localhost:2016 for HTTPS, or just :2016 if you want to use HTTP. Or http://localhost:2016 for roughly the same thing.
I guess I should add a note in that tutorial about the permissions thing. I kind of thought most people knew that when running a web server (since it’s not special to Caddy).
Hi! Thanks for the fast reply
I just tried the options you suggested:
localhost:2016 - “run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: An attempt was made to access a socket in a way forbidden by its access permissions.”
http://localhost:2016 - Works for HTTP. Fails for HTTPS: “This site can’t provide a secure connection - ERR_SSL_PROTOCOL_ERROR”
So I still have the same problem
Oh, right – that’s because of the automatic HTTP->HTTPS redirects. You also have to change the HTTP port:
    http_port 8080
or whatever you choose.
By the way, this will never work with HTTPS because you’ve set the scheme to http://.
SUCCESS! Thanks Matt.
