I am trying to run Caddy natively on Debian 12. Ideally I can run docker-compose instances and route them through a reverse-proxy configuration. This works but it “leaks” data from the non-https container:
Good (insecure due to LE Staging):
curl -vL --insecure https://whoami.lapre.com
* Trying 5.161.195.89:443...
* Connected to whoami.lapre.com (5.161.195.89) port 443 (#0)
* ALPN: offers h2,http/1.1
* ALPN: server accepted h2
* subject: CN=whoami.lapre.com
* start date: Jun 24 13:37:14 2024 GMT
* expire date: Sep 22 13:37:13 2024 GMT
* issuer: C=US; O=(STAGING) Let's Encrypt; CN=(STAGING) False Fennel E6
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: whoami.lapre.com]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x56210ed6f400)
> GET / HTTP/2
> Host: whoami.lapre.com
> accept: */*
< HTTP/2 200
< content-type: text/plain; charset=utf-8
< date: Thu, 27 Jun 2024 03:02:48 GMT
< server: Caddy
< content-length: 317
Hostname: 2fa99d1e2c77
IP: 127.0.0.1
IP: ::1
IP: 192.168.80.2
IP: fe80::42:c0ff:fea8:5002
RemoteAddr: 192.168.80.1:33010
GET / HTTP/1.1
User-Agent: curl/7.88.1
Accept: */*
Accept-Encoding: gzip
X-Forwarded-For: 5.161.195.89
X-Forwarded-Host: whoami.lapre.com
X-Forwarded-Proto: https
* Connection #0 to host whoami.lapre.com left intact
Bad:
curl -vL http://whoami.lapre.com:2400
* Trying 5.161.195.89:2400...
* Connected to whoami.lapre.com (5.161.195.89) port 2400 (#0)
> GET / HTTP/1.1
> Host: whoami.lapre.com:2400
< HTTP/1.1 200 OK
< Date: Thu, 27 Jun 2024 03:06:21 GMT
< Content-Length: 206
IP: 127.0.0.1
IP: ::1
IP: 192.168.80.2
RemoteAddr: 5.161.195.89:51126
GET / HTTP/1.1
Accept: */*
I am forwarding port 80 from the whoami container to port 2400.
Why is this happening? How can I work around it? Can this be handled via ufw or a redirect possibly? What would be the best approach to prevent the “bad” scenario above? Am I running a non-standard configuration?
No real errors or misconfigurations, I just wish for some guidance.
sudo apt install caddy
Then I modified /etc/caddy/Caddyfile and ran sudo systemctl reload caddy.service.
Debian 12 on x86_64, Docker 26.0.0, docker-compose v2.25.0.
whoami:
# A container that exposes an API to show its IP address
image: traefik/whoami
lapre.com,
www.lapre.com {
root * /usr/share/caddy
whoami.lapre.com {
reverse_proxy localhost:2400
paperless.lapre.com {
reverse_proxy localhost:8000 {
header_down Referrer-Policy "strict-origin-when-cross-origin"
